05-03-2018, 09:31 PM | #1 |
Rep 40
ARP Rod bolts
Hey guys,
New to the forum! I've been a long time lurker and I've been wanting to join the 300+ whp power club I would like to be sitting at 300 whp or just below it with some reliability. (Timing chain and guides are in the process of being changed as well.) Anyway, I've seen some talk of ARP rod bolts, but can't seem to find them specific to the N20. Do the M52 bolts work because they have the same measurement? Or am I wrong? Current set up: BMS stage 1 piggyback, Borla catback exhaust, AFE momentum intake, VRSF downpipe, H&R lowering springs, EC-7 APEX wheels, Cooper RS-3 tires Dyno'd at 262whp/292wtq on 93 octane Looking to get: BM3, intercooler, charge pipes, GFB DV+ |
05-03-2018, 10:16 PM | #2 | |
Rep 3,680
This thread talks a lot about rod bolts if you haven't already seen it: http://f30.bimmerpost.com/forums/sho....php?t=1476978 BunkerJ and D041987 are your guys for this stuff.
05-04-2018, 12:16 AM | #3 | |
Rep 2,382
Are you planning to track the car? I've been sitting at 300whp for about 6 months with no issues and it's unlikely you will either, unless you track and put her under constant high heat/torque. That being said, if you want to do it, by all means, do it! I'll be ordering mine here tomorrow and swapping them in the coming week. Now if I could just get tuned for this bigger turbo already lol....
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
M2_MEDUSA664.00 |
05-04-2018, 05:43 AM | #4 | |
Rep 40
05-04-2018, 09:19 AM | #5 |
Rep 2,382
Yeah, if you don't plan to track it, stock bolts are more than enough at 300WHP, but I get why you'd be worried and it always pays (literally) to be safer.
05-05-2018, 12:25 AM | #6 | |
Nemo banks
65
Rep 253
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
05-05-2018, 12:50 AM | #7 |
Rep 2,382
ARP bolts are damn good (Hence why they cost so much compared to the $4 a bolt OEM ones
Again, if you don't plan on passing 300WHP (Stage 2), then I wouldn't worry about it unless tracking a lot.
05-10-2018, 03:00 AM | #8 |
Big Turbo Boys N Girls
327
Rep 579
Yes, the bolts are the same as the N54. Also stock rod bolts are stretch bolts and have like 3 or 4 torque progressions before finial torquing is complete which is really a pain and why they are prone to failure under heat and constant loads. So changing them out if wanting to push the car more is cheap security. Also while you are in there, might as well upgrade to stronger bearings.
I feel with this setup the block should be good for around the high 300 mark with a bigger turbo and supporting mod and a flash tune before a rebuild is needed. |
05-10-2018, 03:02 AM | #9 |
327
Rep 579
OP I would ditch the stage 1 piggy and get a flash tune. Or upgrade to the JB4 and see if you can run a backend flash. You will see and night and day difference in power delivery and driving with a flash and reliability :-)
05-10-2018, 05:46 AM | #10 | |||
Rep 3,947
05-10-2018, 08:59 AM | #11 | |
Rep 2,382
Also, disagree with JB4, but agree with the flash, haha.
05-10-2018, 09:00 AM | #12 |
Rep 2,382
Unfortunately, some are stuck with the car for now and just trying to make the best of it. If I could just seamlessly have upgraded to an N55 when I was first building the car, I would've lol.
05-11-2018, 06:16 PM | #13 |
327
Rep 579
If you get a JB4 and have a backend flash stacked it is the best of both worlds as you have the smooth ECU control for the power and all benfits of the Flash and you than have all the monitoring and fail safes in place and more options to tune with different fuels and upgraded fuel rails that might come later on etc.. with the JB4.
But if you have to choose just one. I would go with an flash. If you want to have the options for more customization than go with JB4 stacked with back end flash for ultimate setup! Not sure if this is released yet but the BMS guys are working on these I think. |
07-25-2018, 06:28 AM | #14 | ||
Rep 1,074
Instagram: M2_Medusa
07-25-2018, 07:54 AM | #15 | |
Rep 184
Drives: F30 N26
M2_MEDUSA664.00 |
08-03-2018, 02:47 PM | #16 |
Rep 184
Drives: F30 N26
So which set of rod bolts do I get? BunkerJ D041987
201-6303 Rod Bolt Kit: BMW 2.8L (M52/M52TU) & 3.0L (M54) inline 6, M9, 47mm, ARP2000 or 201-6201 Rod Bolt Kit: BMW 2.8L (M52Euro), 3.0L (S50US) & 3.2L (S52US) inline 6, M9, 44mm UHL, ARP2000
-2013 F30 328i xDrive Melbourne Red- Injen CAI | GFB DV+ | FTP CP & TP | CW DP | G-Plus Oil Cooler | Mishimoto CC | VSRF FMIC | BM3 Stg 2| H&R Rear Sway Bar | H&R SS & Bilstein B8 | Carbon Fiber Dealibobs | 525 LPFP | Soon to come upgraded HPFP (B58TU) and Navardi Tune |
08-03-2018, 04:41 PM | #17 | |
Rep 2,382
LordRuxpin103.50 |
08-14-2018, 05:21 AM | #18 |
Rep 56
Hi .. did u get the link for these bearings ?
The link for the APR Rod Bolts for the N20 was given as; https://arp-bolts.com/kits/ARPkit-de...?RecordID=1114 But i cant see the link for these bearings ? |
08-14-2018, 08:05 PM | #19 | |
Rep 184
Drives: F30 N26
08-14-2018, 09:18 PM | #20 |
Nemo banks
65
Rep 253
08-15-2018, 09:24 AM | #21 |
Rep 2,382
May not be any or you may not need them honestly.
08-15-2018, 09:40 AM | #22 |
Rep 56
Thanks.
I finally know how they look like now... here are a couple links ... they are 30USD each. They sit in the conrod. https://www.ecstuning.com/b-genuine-...h/11247628034/ http://www.bimmerzone.com/category/B...d_Bearing.html |
