08-16-2018, 12:26 PM | #1 |
Rep 51
N20 upgraded turbo differences.
Hey guys, im looking for some insight on the differences between the compressor sizes on the n20 stage 2 turbos.
I’m aware the stock Cast compressor wheel is 42mm And the MHI turbo is 56mm Dinan and purr turbo do not state the compressor size. Only that the compressor is billet. Are all exhaust turbines on the turbos the same size as stock? I wouldn’t mind having a little more lag at low rpm to avoid bending my rods. I’m looking to buy one, mhi sees to be the best priced. But price isn’t everything. |
08-17-2018, 12:52 AM | #2 |
Rep 107
From my notes....
*Note the sheet may not be clean. There could be errors, do your due diligence. Also, Delta (Comp ind&Turb ex) refers to this: http://turbolabofamerica.com/turbo-upgrade-2/ ).* Last edited by F30328iN202013; 08-17-2018 at 01:54 AM.. |
08-17-2018, 09:50 AM | #3 |
Rep 2,382
Great sheet ^
Depends on your goals. MHI alone will not shift your torque much. MHI is great for the simplicity of it as it's a direct bolt-on and decently priced. Get a custom tune with it and have them push it right. An OTS map alone isn't going to get you to the rod throwing stage. If your goals are to make more power (A lot more) and you plan to build the car, get a bigger turbo. Otherwise, stick with something that's going to give you a better flow rate and keep you under 24PSI. Another reason I went MHI.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit |
08-17-2018, 02:11 PM | #4 | |
Rep 51
08-17-2018, 02:24 PM | #5 | |
Rep 51
08-20-2018, 09:02 AM | #6 | |
Rep 2,382
09-28-2023, 08:08 AM | #7 | |
Rep 64
On the dyno the numbers where Stock NO JB4 (With FBO) = 167 WHP FBO with JB4 map 5 = 231 WHP FBO custom Etuner tune= 242 WHP My target was somewhere around 280WHP no ethanol, I was planinng on buying now the MHI N20 big turbo which doesn't look THAT agressive it actually looks like and oem turbo but with better response and more capable of handling boost, Do you guys think that if I upgrade the turbo and do a conservative tune to 270 - 280 ish whp, forged internals would be required? |
09-28-2023, 10:40 AM | #8 | |
Rep 215
In my opinion, without ethanol, forging interior for 280WHP is necessary. This is like buying insurance, if there is a knock, the stock parts will definitely be damaged. Forged components can withstand occasional knocking during tuning without damage, and replacing worn out components together will give you a nearly brand new engine. Otherwise, you may lose the engine during tuning and wait for lengthy repairs |
09-28-2023, 06:38 PM | #9 | |
Rep 1,055
Also list your mods. You’ll need EVERY PART to get close to 270-280 whp.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
09-28-2023, 09:01 PM | #10 | |
Rep 64
CTS Intake VRSF DP MAD FMIC MAD CHARGE PIPE FTP INLET MAD BOOST PIPE CTS COILS 2 STEP COLDER NGK PLUGS JB4 custom exhaust straight from down pipe no restrictions and the Etuners Tune that gave me only like 10 more whp am I missing any bolt ons? I have no problem switching to BM3 and running 95ron |
09-28-2023, 09:52 PM | #11 |
Rep 1,055
You need bm3. That’s what you are missing. Seriously
11-23-2023, 10:40 PM | #13 | |
Rep 13
11-23-2023, 10:42 PM | #14 | |
Rep 13
stock N20 can't handle boost over 24 psi for a long time, you need to upgrade your piston and rods then it will be fine as long you kept boost under 30 psi , over 30 psi that open deck of N20 will start to cause some issue . also important note after you upgrade stg2 turbo is that octane , you will easily find your engine is very octane limited on 98 , this N20 engine hate 98 octane for livin 8 deg of timing + 24psi of boost you will start to see some timing correction if your IAT is over than 110f and you will not be happy with the gain from 98 tunes because it's very octane limited if your only plan is to do 98 then this stg2 turbo upgrade is simply a waste of money , you will start to have some smile on your face once you start ran Emix tune , if you want to go any higher than E30 you will need to change the HPFP TO B58TUHPFP it's 90%PnP to N20 then you good to go up to E60 . for E85 you need to change the injector to S63TU injectors but , there's the big but here if your car is older something like 2012/2013 your ecu might not be tune able for these injectors they simply don't have the table for tuner to edit that , you need to speak with your tuners about this so he could check your dme's ROM to make sure it's tune able with this injectors hope this helps you feel free to ask a question mate thanks |
11-23-2023, 10:45 PM | #15 | |
Rep 13
