10-25-2020, 01:47 PM | #199 |
Rep 928
got my Vader solutions inlet installed only thing that cracked was the coolant line. Will still pass visual cause we cut factory inlet so looks factory. i'm happy as cost was only 60 bucks.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
10-26-2020, 11:28 AM | #200 |
Rep 7,607
Get the v2, which is for hybrid turbo, even if you are on stock turbo. The stock turbo adapter is literally just a thicker piece of metal - i.e., smaller inner diameter with the same outer diameter (outer diameter determine by fitting into turbo). So you are just necking down the flow area sooner if you get the stock turbo version. Indeed the actual turbo itself will still have a smaller diameter where the air enters the cold side than the metal piece on the inlet if you get the v2, but you still get the extra volume and eliminate the unnecessary reduction in flow area with the v2 version. Also, the articles posted earlier in this thread from bench testing inlets (for VWs but same idea) basically showed that the bigger the better even if it means an abrupt 'step down' in inner diameter near the turbo.
itsrichierich186.50 |
10-26-2020, 11:30 AM | #201 |
Rep 7,607
10-26-2020, 11:38 AM | #202 | |
Rep 928
10-26-2020, 03:07 PM | #203 |
Rep 963
is the turbosmart dv install any easier to do with the inlet taken out?
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
10-26-2020, 03:10 PM | #204 |
Rep 928
i believe so. While we were in there we had the water pump out to so i changed dv, wp, and inlet all at the same time.
aps335.50 |
10-26-2020, 03:11 PM | #205 | |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
11-23-2020, 11:45 AM | #206 |
Moto Lover
187
Rep 591
Anyone have cold start issues after installing?
To begin, I have never had cold start issues. Untill recently after I installed my MST turbo inlet and Turner Motorsport Intake. Car idles pretty rough and some times shuts off when trying to idle. I have to keep it revved up (not much) to keep the car on. |
11-23-2020, 12:08 PM | #208 |
Moto Lover
187
Rep 591
11-23-2020, 12:24 PM | #209 | |
1296
Rep 3,533
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
11-23-2020, 01:02 PM | #210 | |
Rep 870
11-23-2020, 01:22 PM | #211 |
Moto Lover
187
Rep 591
And it's normal for the car to start up normally once it's warm? Because that's what I'm dealing with.
On an actual cold start, it's rough/hard to stay idling. But once it's warmed up and driving, no issues. Do I unplug the MAF from the intake before starting the car or while it's running? |
11-23-2020, 01:37 PM | #212 | |
Rep 870
11-23-2020, 01:41 PM | #213 |
Moto Lover
187
Rep 591
11-23-2020, 01:56 PM | #214 |
Rep 870
Did you adjust you're tune? Cause the most likely cause of the slow start up or hesitant is from the e tune when it gets cold that's what tends to happen.
11-23-2020, 02:54 PM | #215 |
Rep 1,115
Before looking at replacing the MAF, spray it down with this to clean it.
https://www.homedepot.com/p/CRC-11-o...5110/205021972 |
11-23-2020, 04:35 PM | #216 | ||
Rep 7,607
Step 1 is to remove the intake and put the stock one back on. You can also try unplugging the MAF, but i would try the above first personally. Quote:
You can also do a log and check if your MAF readings are reasonable or the intake is throwing them off. Finally, you can try resetting adaptations, but if you've already driven ~50+ miles with the new intake on that probably isnt going to make a difference. I would scan for codes then put the stock intake back on and drive around for a bit, then let the car sit overnight and test cold start the next day with stock intake. |
11-23-2020, 06:24 PM | #217 | |
Moto Lover
187
Rep 591
Speaking of PCV, I do see some oil seepage up top. And looking at it, there was suppose to be a clip that needs to be pressed in correct? There's the 4 prongs but there's also a U-clip that locks the PCV into that nipple? That might be an issue. |
11-23-2020, 09:51 PM | #218 | |
Rep 7,607
11-23-2020, 11:51 PM | #219 | |
Moto Lover
187
Rep 591
Just swapped over to my OEM intake, hopefully this will fix it. |
11-24-2020, 12:04 AM | #220 | |
Rep 7,607
