01-24-2020, 04:42 PM | #1 | |
Rep 28
N20 boost leaks - Where to start?
My 328i is not hitting its boost targets.
Bootmod3 LOG Where do I start? This is my first turbocharged engine, and I am unfamiliar with it. Seeing as im able to build up to 1 psi under target before it starts dropping, surely its just a small leak? I was told to check the vacuum lines pressure, which would give me the ability to rule out certain parts based on the vacuum. Is this relevant on the n20 engine? Perhaps im completely off and theres an obvious reason as to why im not reaching target boost, please take a look at the log and give me some feedback I am still running stock chargepipe on 21.5PSI boost, could it possibly have bursted? I do not have any fault codes. Thanks in advance. Edit: Quote:
01-24-2020, 07:14 PM | #2 |
Rep 5,457
Drives: F30
Start with inspecting the complete induction tract including seals. All made of plastic from factory.
Five pieces essentially: Intercooler Diverter valve* Charge side pipe Turbo side pipe Turbo inlet pipe *not pictured |
Chris05099911.50 |
01-24-2020, 08:04 PM | #3 |
Rep 681
You should do a pressure test to see where things are leaking. It'll be the fastest and more effective way to figure out where the leak is happening.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
01-25-2020, 11:35 AM | #5 |
Rep 28
No noise. Atleast nothing that can be heard over the engine noise.
I've got no fault codes, but I wasnt expecting any either, as the tune would override them. I find it odd how im able to reach ~19 psi, but not able to hold it. Perhaps someone could do a 101 on turbo systems as I cant imagine the reasoning behind this? I deal with pressure testing daily, and if im able to reach 19psi, then it should have no problem holding it, seeing as the same amount of air is being "pumped" in, even if there was a leak. The curves shown in the log look like the air is being "pumped" to 19 psi before it stops and allows it to leak off, until I change gear and its "pumped" back up. Could this possibly be a tune issue? Wastegate control? I've sent the logs over to the tuner to ask for a clarification. Last edited by Chris050999; 01-25-2020 at 11:47 AM.. |
01-28-2020, 09:44 AM | #6 |
Rep 108
Boost drops with RPM, that's normal, happens on every turbo, just by different amount depending on turbo construction. My log looks similar, and I already asked this on PTF support site. They told me that's normal, and if I had a leak Wastegate Duty Cycle would be high:
"If wastegate duty cycle goes 100% at WOT you have a leak, wastegate duty cycle is for how much the turbo pushes to build pressure. I checked logs, looks fine." this was their response But since you already asked, please let us know what they said. Your car has Pneumatic wastegate? I would say so judging by wastegate duty cycle curve... |
sspade2466.00 Chris05099911.50 |
01-29-2020, 03:40 PM | #7 | |
Rep 28
My tuner said the same thing, that my logs appear normal seeing as I have a pneumatic wastegate. I find it odd that I have significantly more lag now than earlier, but I suppose it is nothing to worry about yet. My wastegate duty cycle seems to stay around 50% at WOT, and peaks at 65. |
01-30-2020, 01:00 PM | #9 | |
Rep 28
Currently 0 - 5 celsius here, and i've coded the thermostat to open earlier. Going to change it back to stock as im still at stock temperatures, even with the stage 2 tune under hard load. I do not feel like the 800€ investment for an ever so slightly bigger intercooler is necessary. |
01-30-2020, 10:05 PM | #10 |
Rep 170
Yea your wastegate duty cycle makes no sense to me. Is that how the pneumatic acts?
EDIT: I don't see any clear correlation of what is going on here. The MAF even shows decreasing flow high up in 4th gear. Kind of odd. I guess I would start by taking apart intake, inspect turbo shaft for play, then reassemble intake with a little bit of silicon grease on joints? It really doesn't take long to do. |
01-31-2020, 08:05 AM | #11 |
Rep 108
This is how pneumatic WG acts... mine is doing the same. See here
Although now that you mentioned MAF, mine is acting a bit differently, no such drop with rpm's. Some drop is to be expected in high rpm's because turbo is small and not very efficient in high rpm's... |
01-31-2020, 12:34 PM | #12 | |
Rep 28
01-31-2020, 01:51 PM | #13 |
Rep 170
The MAF isn't horribly off but its just didn't seem right to me. I could be wrong though. Curious to hear if sealing up the intake helps at all or if the log looks any different after.
EDIT: On the other hand if MAF was misreading the DME should get sort of unhappy about AFRs. Especially since your STFT is dead on. Is your LTFT around 1 as well? |
01-31-2020, 02:18 PM | #14 | |
Rep 170
Also MAF dropping wouldn't usually be a boost leak. A boost leak would drop PSI but intuition tells me increase flow. I suppose the diverter valve would make sense in this case as a leaking one would lead to air being dumped into the turbo inlet reducing the need for fresh air from the intake. Is this car an auto? A manual would also drop boost and flow on shifts. |
02-03-2020, 11:54 AM | #16 |
Rep 170
