01-27-2020, 01:15 PM | #1 |
Rep 360
N20 320I X drive 100k miles service
Hi,
Carrying out a 100k service over the next few months and ticking off the following: Drivetrain fluids/filters Fuel filter (external euro model maybe) Intake valves - CRC direct, engine off clean Water pump Thermostat + bmw coolant Anything else required? Is the water pump a good idea at 100k. I've not had any warnings and ISTA shows it maintaining at 90c along with the oil temps at 90c (halfway between left reading and top reading) Thanks |
01-28-2020, 01:54 AM | #2 |
Rep 500
The old E90 water pump failed normally around 100k-120k km. As for thermostat, check your error log. My F10 N20 thermostat failed open and replace around 70k. Check your engine mounting and absorber mounting too.
01-31-2020, 09:37 AM | #3 |
Rep 420
When you say drivetrain, you mean the transmission? You definitely should do an automatic transmission, drain, fill and filter/pan change by 100k. I do not know the specifics of the transfer case though...
I would add to that: engine air filer power steering fluid, drain and fill engine coolant drain and fill spark plugs diff fluid drain and fill cabin air filter the windshield cowl if the weather strip is damaged take the brake calipers apart, clean, polish the slides, regrease bleed a quart or two of new fluid through until it comes out clean from every caliper Also, sorry to tell you, this is around the time that the timing chain guides fail and take out the engine. Best to replace everything before that happens. Last edited by CandyRedRC46; 01-31-2020 at 09:44 AM.. |
