05-13-2020, 10:02 AM | #1 |
Rep 70
Do I have an N20 or N26 engine?
I have what I think is an N26 engine for a few reasons:
- the emissions sticker on the inside hood says SULEV - I installed an evolution racewerks N26 downpipe that was the same general shape (O2 sensor and bracket placements) as my stock downpipe and fit perfectly fine - mdecoder said I have an N26 I went to tune my car with bootmod3, and it was detected as an N20-EWG-L-P. My TIC pipe also says N20 on it, but not sure if that's just a reused part between the two engines. Is bootmod3 just reporting N20 even though it's an N26? Should I reach out to PTF? |
05-13-2020, 10:51 AM | #4 |
Rep 414
Don’t worry it’s the right map. BM3 doesn’t differentiate between N20/N26 as they are the same engine and programming. You’re good to go with those N20 maps.
05-13-2020, 11:27 AM | #5 |
Rep 70
05-13-2020, 07:04 PM | #6 |
Rep 3,680
Won't matter for tuning because N20/N26 are tuned the same as mentioned above, but if a VIN decoder says you have an N26 and an N26 downpipe fit on your car, you probably have an N26
05-18-2020, 08:10 AM | #8 |
Rep 3,680
Go to mdecoder.com and run your VIN, it will tell you basically everything about your car.
05-18-2020, 09:16 AM | #9 |
Rep 70
05-18-2020, 12:33 PM | #10 |
Rep 3,680
No problem! Bootmod3 tunes N20 and N26 the same as they are basically the same as far as tuning goes, so they just list N20's as N26.
05-18-2020, 12:53 PM | #11 |
Rep 191,109
The best way to tell if you have an N20 or N26 engine is to check the engine bay. Underneath the factory hood (bonnet), there will be a sticker showing the emissions specs of the car. The sticker will look like this:
If you have an N20 engine, it will say ULEV. If it is an N26 engine, it will say SULEV. +1
