07-30-2020, 06:26 PM | #573 |
Rep 692
This showed up!!
Bimmercode best coding options (Basic and Advanced):
https://g20.bimmerpost.com/forums/sh...5#post29807925 |
07-30-2020, 09:39 PM | #574 |
Rep 379
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop |
08-01-2020, 08:56 PM | #575 |
Rep 266
So guys let me get this straight. The one from Bimmer8 will show it at MPH correct? Can it not display it in the red circle for the US version like the European version? What does it show on the HUD? I bought one from China and it is showing it at KPH and it is driving me crazy. My HUD speed turns red in KPH as well. Please help and give advise guys. I would like it to work a little better as my OCD is killing me with this KPH. Thank you.
08-01-2020, 09:41 PM | #576 | |
Rep 379
The bimmer8 unit i have shows MPH with white square on both cluster and HUD. If you want MPH but red circle contact the ebay seller.
steelerfan163.00 Burniksapwet50.00 |
08-02-2020, 09:07 AM | #578 | |
Rep 692
And it's cheap!!!! Hurry before they raise price mate.
08-03-2020, 07:24 AM | #579 |
Rep 266
Ok last question guys. Is the square one the standard "look" you see if you actually have the option in your BMW for for the US? I'm just asking as I want to make it look as OEM as possible. I like the circle for the minimalistic look but if it is not the OEM look for the US then I'll go with the square. Thank you.
08-03-2020, 08:34 AM | #580 |
Schmollbraten
12512
Rep 1,985
As you may know, the US speed signs are originally squared and so are the display, its 1:1.
Roundels are only for Europe or fans of the circled one signs.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
08-11-2020, 03:24 PM | #581 |
Rep 266
Bought the module freespirit was selling. Here is how it looks like on g30. I'm satisfied with how it turned out. Thanks again bro.
freespirit82.50 Dang3r12512.00 |
08-11-2020, 04:49 PM | #582 |
Rep 379
I am glad it worked to your satisfaction
x-m4n148.00 Burniksapwet50.00 |
08-17-2020, 10:10 AM | #584 |
Rep 128
No. It needs VO coding (so esys is required)
F82 M4 CP Retrofitted: HUD + CS Dash, Fully adaptive/HBA LED headlights, shadowline LCI taillights, KAFAS2 / pedestrian detection / Speed Limit Info / Front Collision Avoidance, Fullscreen CarPlay / ID6, latest iStep. Mods: Carbon diffuser. Carbon side skirts. Bootmod3 Stage 2. BMS intakes. Decat downpipes. AA midpipe. Custom exhaust with akrapovic tips.
MetzgerMeister16.00 |
08-18-2020, 07:29 PM | #585 | |
Rep 379
If u r referring to Kafas2 camera, then you need to VO code 8TH option and also need an FSC code. So yes you need esys. If u r referring to rearview mirror camera, then there is no way you can enable SLI without emulator. Based on my experience emulator don't need VO coding. I used bimmercode and did FDL coding directly and it worked.
08-28-2020, 10:50 AM | #586 |
Rep 8
In my drive I don’t get the option to change from kph to mph. Can this be coded?
I can change other values just not the speed one Apparently you can switch the speed one in certain cars Thanks |
08-28-2020, 11:01 AM | #587 |
Rep 692
09-15-2020, 10:19 AM | #588 |
Rep 2
Drives: M4 Comp 20'
Is the Bimmer8 unit plug and play for an M4 with HUD? (non Kafas just high beam assist and icons)
Coding not an issue ive got bimmercode cheers |
09-15-2020, 10:23 AM | #589 |
Rep 843
09-15-2020, 10:25 AM | #590 |
Rep 2
Drives: M4 Comp 20'
09-16-2020, 12:06 AM | #592 |
Rep 464
Any one successfully done this on a car with ID6?
Mine is a 2018 M3 with ID6, I have the FLA camera (for automatic high beam). I got the Taiwanese Bimmer8 emulator. I did the following coding with Bimmercode: SPEEDLIMIT_INFO = Aktiv HUD_CB_SPEEDLIMITINFO = Aktiv Couldn't find any other parameters listed by the seller. I got the options to turn on SLI on HUD and Instrument display in iDrive display settings, I checked both options however nothing showed up on either HUD or dash, not even the three dashes. Anyone have an idea what's going on? Thanks!
Instagram:catpupu_f80 |
09-16-2020, 11:17 AM | #593 | |
Rep 379
09-16-2020, 11:37 AM | #594 | ||
Rep 464
