03-07-2022, 02:12 PM | #683 | |
Rep 106
06-18-2022, 10:36 AM | #684 |
Rep 45
I would like to add the SLI emulator to my F31
I have NBT professional with newest nav update and 6WA dash. Can anyone confirm if the speed limits can be shown at the same time as the nav turn instructions.? I used the nav turn instructions daily and while I would like the speed limit info shown I wouldn’t want it at the expense of the turn instructions. |
06-18-2022, 01:25 PM | #685 | |
Schmollbraten
12512
Rep 1,985
The signs would appear at the left or right border of the navigation symbols.
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
06-18-2022, 03:35 PM | #686 |
Great Teacher
1088
Rep 1,305
Drives: 06 e91 325ix
Yep. Make sure you get the bimmer8 module and not the china/ Alibaba one
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
06-18-2022, 05:43 PM | #687 |
Rep 144
Hi,
I have a 2016/17 F26 X4 35d with Nav Pro that initially didn't have SLI in Australia. Initially I added 8TH and a chinese SLI emulator and it worked fine but decided to spend the extra to buy the FSC files so I could use KAFAS2 cameras to detect speed using speed signs as a priority over NAV PRO EVO maps imbedded speed limits. After I installed the SLI FSC files, all I got was the circle with ---. (3 dashes) I had to update the KAFAS2 ECU with the latest firmware at the time and SLI speeds display perfectly in both the HUD and 6WA kombi (dash) if selected. My only issue with SLI in Australia is that the cameras don't change the SLI speed when it sees a 25 Kph sign, it must be that BMW in Australia has omitted 25 Kph speed as our schools and most temporary road works use 25. Cheerz
2016 BMW F26 X4 35d, H&R spring lowered 30mm, QUAD exhausts
06-19-2022, 06:28 AM | #688 |
Rep 45
06-19-2022, 02:11 PM | #689 |
Great Teacher
1088
Rep 1,305
I wouldn’t know, I don’t live in the UK. Got both mine from bimmer8 via eBay.
06-20-2022, 05:34 AM | #690 |
Rep 766
I think your only option in the UK would be somebody selling it here in the forum.
https://f30.bimmerpost.com/forums/fo...play.php?f=648 |
08-22-2022, 06:32 PM | #691 |
Rep 270
Drives: 2015 X5d M Sport Metallic Whit
I got an emulator and the coding that accompanied it is quite good and extensive. The easiest is to FA code to your car but if you need to FLD code it, here are some thing to look for (not all are needed in every car model).
F-Series - KOMBI Ecu ANZEIGE_NPI = aktiv KI_PIA_SPEED_LIMIT = aktiv SPEED_LIMIT = aktiv SPEED_LIMIT_GENERATION = sli_gen_2_npi RCOG_TRSG_APPL = aktiv RCOG_TRSG_TIMEOUT = aktiv G-Series KOMBI Ecu ADDITIONAL_SIGN_ENABLE = aktiv ANZEIGE_NPI = aktiv CB_TACHOZEIGERBAND = aktiv CB_SLI_NPI = aktiv PIA_SLI_NPI = aktiv RCOG_TRSG_APPL = aktiv (* See Notice below) RCOG_TRSG_TIMEOUT = aktiv (* See Notice below) SLI_PERMANENT_ENABLE = aktiv SPEED_LIMIT_ENABLE = aktiv TACHOZEIGERBAND_ENABLE = aktiv NO_PASSING_ENABLE = aktiv SPEED_LIMIT_UNIT_ENABLE = Wert_02( If you don't want to display speed unit kmh or mph, please set Wert_0 ) F / G Series - KOMBI Ecu If your vehicle has a HUD (Head-Up Display) do these. Just ignore if you don’t have a HUD. HUD_NPI_ENABLE = aktiv HUD_PIA_SPEED_LIM = aktiv HUD_SPEED_LIMIT_ENABLE = aktiv HUD_SLI_ENABLE = aktiv PIA_HUD_SLI = aktiv PIA_HUD_SLI_NPI = aktiv PIA_HUD_SLI_PORTIERUNG = aktiv PIA_HUD_VSLI = aktiv Coding to be modified for HU_NBT or HU_NBT2 ECUs SPEEDLIMIT_INFO = aktiv SLI_NAVI_DISPLAY = nicht_aktiv Check "Speed Limit Information" in the Instrument cluster settings for the HUD - check box as needed. |
10-18-2022, 02:10 AM | #693 |
Rep 23
Speedlimit info disappear on Cluster
11-22-2022, 01:35 PM | #695 |
Rep 3,056
Yes, it works
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
11-22-2022, 04:45 PM | #696 |
Rep 7
Drives: BMW M140i F20
Hello guys
I’m trying to retrofit the sli module on my bmw f45 (2015) i have the half digital cluster and it does support sli and i also have the kafas camera already installed from the factory, i have connected the sli module correctly and coded correctly aswell but i only cannot find the [SPEED_LIMIT_GENERATION] i can see the speed limit info in my hud and also on the cluster but my problem is that it does keep flickering and not staying as it should. I testdrive it and it changes correctly the speedlimit if i make a turn to a different speedzone. I have recorded but i cannot upload it here for some reason? You can ask me for the video. Can anyone help me out with this problem i hope the module is broken or something. Last edited by ilhankurudere; 11-22-2022 at 04:53 PM.. |
12-03-2022, 04:22 AM | #700 |
AH3 Owner
201
Rep 305
Drives: BMW 335i ActiveHybrid 3
12-04-2022, 11:43 AM | #701 | |
Rep 105
12-04-2022, 02:09 PM | #702 |
Rep 3,056
Injected FSC as well?
scouse stelth36.50 |
12-04-2022, 02:16 PM | #703 |
Rep 105
Don't get what you mean??
