04-26-2022, 08:57 PM | #2267 |
Rep 1,457
MHD Flex Fuel with E35-E36
Dorch Stage 2 HPFP ER Catted DP AFE drop-in-filter XHP Stage 1 Added another 2 gallons of E in today and was able to get up to E35-E36. Ill be adding in another 3 gallons tomorrow to bring it over 40% and log again, but its def pulling better than being on the original E25-E26. I see more timing advance. Once I get over 40% I'm going to try out the Stage 2+ HPFP tune and compare the difference with the flex-fuel auto adjusting logs. https://datazap.me/u/n54tt/b58-mhd-f...32-33-34-35-37 Last edited by B58; 04-26-2022 at 09:03 PM.. |
04-26-2022, 09:45 PM | #2268 |
Rep 20
If you are seeing corrections with a flex-fuel map, is there anything you can do to help?
In the log you posted above, there are some corrections. If you increase the E content, the map will get more aggressive so I’m assuming you would still get corrections? |
04-26-2022, 10:43 PM | #2269 | |
Rep 1,457
This was a post made a while back when people were worried about timing corrections with the N54: https://blog.protuningfreaks.com/201...eliable-power/
2024 X3 M40i
2014 BMW M5 |
04-26-2022, 11:35 PM | #2270 |
Rep 298
17 BMW 340iX / DAW UF/ DS2 HPFP
04-27-2022, 11:36 AM | #2271 | |
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
04-27-2022, 07:40 PM | #2272 | |
Rep 20
https://datazap.me/u/ciaran2903/flex...48-49-50-51-53 Definitely not as quick as the Stage 2+ E40 map, but MHD said they are releasing Flex Fuel Stage 2+ Maps very soon. |
04-27-2022, 09:10 PM | #2273 | ||
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
04-27-2022, 09:22 PM | #2274 | |
Rep 20
Yes, running xHP and checked the “Manual or xHP flashed 8AT”. Last edited by Ciaran2903; 04-27-2022 at 09:36 PM.. |
04-27-2022, 09:58 PM | #2275 | ||
Rep 1,457
2024 X3 M40i
2014 BMW M5 |
04-27-2022, 10:54 PM | #2277 |
Rep 1,457
Interesting. Maxed out stock turbo on the E40 HPFP map? With 17 psi it's already close to 90% WGDC.
2024 X3 M40i
2014 BMW M5 |
04-27-2022, 11:50 PM | #2278 |
Rep 20
04-28-2022, 12:03 AM | #2279 | |
Rep 1,010
Interesting, timing increased while boost almost the same.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - Stock HPFP
-------- Tunes: Self Made Tunes - MHD ------ Fuel: 92RON/87OCT -------- |
04-28-2022, 12:26 AM | #2280 |
Rep 1,457
Boost figures are based on the Stage 2 ots. They are working on releasing the flex fuel Stage 2+ HPFP map so I'm sure that one will have more boost when you go under the multi map selection. It sounds a bit confusing as I was confused myself, but its slowly starting to make sense.
04-28-2022, 12:27 AM | #2281 | |
Rep 1,010
I have to correct Ken's statement: if you're not getting minor timing corrections WHILE HAVING GOOD TIMING ADVANCE you're leaving potential power.
04-28-2022, 12:31 AM | #2282 |
Rep 1,457
Lets keep IAT out of this, but has anyone tested a open filter intake and the closed stock air-box with a drop in filter to see if it helps the turbo WGDC drop?
04-28-2022, 06:53 PM | #2283 |
DisplacementReplacement
409
Rep 1,102
My latest log of MHD E40 STG2+
Boostane plus E40 https://datazap.me/u/nat/log-1666525...35-36-37-38-47
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 02-04-2023 at 08:00 AM.. |
04-28-2022, 10:57 PM | #2284 |
Rep 1,457
1 more log. Running cleaner with a bit more of ethanol reading around 43-44%
2024 X3 M40i
2014 BMW M5 |
04-29-2022, 08:07 PM | #2285 |
Rep 1,457
Stage 2 HPFP E40 log file. It still seems to be shy on boost with target. Maybe overall it doesn't like my ER catted down-pipe even though it's a 200 cell.
https://datazap.me/u/n54tt/b58-stage...30&mark=27
2024 X3 M40i
2014 BMW M5 |
04-29-2022, 08:57 PM | #2286 |
Rep 554
Stage 2 91 BM3 tune. I flashed it a while ago and had come knock in the logs, so reverted to Stage 1. I'm at altitude, and the stock turbo has a lot of trouble hitting stage 1/2 boost levels, so I figured the compressor was just at terrible efficiency and it caused high IATs.
But now that PTF released the max boost slider I was able to bring the Stage 2 tune down by 1 psi to go easier on the turbo and got the following logs. 3rd gear pull with some timing at the beginning but all resolving by redline (redline weirdness is from me not shifting) https://www.bootmod3.net/log?id=626c...90c66c2a210f28 4th gear pull that's super clean with the exception of cylinder 1. https://www.bootmod3.net/log?id=626c...0b433ba3a4fcff Any thoughts are welcome.
2019 X3 M40i | TU Pump | AA DP | VTT GC | xHP Stage 2 | Dorch ECA | MHD Odin FF | Carbon Black | Adaptive Suspension | M-Sport Rear Diff | 20" staggered
SOLD! 2015 X1 35i | Alpina Trans Tune | Dinan Stage 2 | Bilstein B6 |
04-30-2022, 12:36 AM | #2287 | ||
Rep 1,010
Boost relatively low in both maps.
04-30-2022, 02:56 AM | #2288 | |
Rep 1,010
Log looks safe but yeah turbo working very hard and also low timing.
