08-02-2018, 04:28 PM | #1 |
Rep 302
Weird (bad odor) Smell Inside Car
Hey all - for the past couple of days, I've noticed the inside of my car smelling horribly. It's not food or any type of odor a human being can leave. I'm putting blame on possibly the cabin filter or anything coming out of the AC vents.
Could the aforementioned things be it? What are other possibilities? Thanks in advance! |
08-02-2018, 04:36 PM | #2 |
Rep 1,047
I had a squirrel build a nest in my E39 engine compartment. He or she didn't do well when I started the car. There was squirrel debris that quickly rotted. I opened the hood to a real mess when it started to smell
08-02-2018, 04:37 PM | #3 |
Rep 302
That's actually hilarious. I popped the hook and no living animals there lol
08-02-2018, 04:39 PM | #4 |
researcher
40
Rep 129
I second this. My brother in law had a situation where a rodent crawled into the engine bay for heat. When the engine started up, things didn't work out so well for the little guy & it funked up the car.
08-02-2018, 04:40 PM | #5 | |
researcher
40
Rep 129
08-02-2018, 04:55 PM | #6 |
Rep 302
08-02-2018, 05:15 PM | #7 |
Rep 479
From what I've been told at the dealer, mold builds up on the A/C coils after periods of intermittent use. Sales advisor said it's about a 3 hour job to take it out and have it cleaned but it will happen again. Someone on the forum recommended buying a new cabin filter and spraying the cr*p out of it with your favorite scented Lysol (or any other non toxic antibacterial spray. Then let it sit for a 24 hour period to dry and install. The problem should not occur within the 2 year replacement limit of the cabin air filter. Bad engineering on BMW's part. Condensation drips onto the coils and creates the mold.
08-02-2018, 11:25 PM | #9 |
Rep 776
My cabin air filter will suddenly wreak of vinegar after about 9-10 months of use. It also takes a few days for that smell to go away 100% after changing the filter.
M240i | Mineral White | Coral Red
08-02-2018, 11:26 PM | #10 |
Rep 4
I really hope the cabin air filter fixes it.
About a month ago, I had a bad smell in my car. After doing some digging, I found mice had built a nest under the dash! I ended up having to put in an insurance claim and they have to remove the whole interior including the dash to get it all cleaned out. |
08-03-2018, 04:56 AM | #11 |
Big Beaver Smile
2101
Rep 3,791
Is your sunroof vented or open? Lots of us have had issues with a bad smell coming in when it's open. Mine was from the grease in there. It's been described as a truffle oil smell (I agree), and it's gross.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
08-03-2018, 06:28 AM | #12 |
Rep 1,247
It's probably mildew / mold from your A/C.
Whenever you have A/C running, especially on a humid day, you need to turn it off for the last 2-3 minutes of having the HVAC on to get all the moisture out. You will be surprised at how much water comes out of the thing. Your steering wheel will get soaking wet where the vents are hitting it. |
08-03-2018, 07:16 AM | #13 |
Rep 71
Drives: 2016 435i xDrive Gran Coupe
I experienced the same thing yesterday, and I thought the smell was like glue or a petroleum smell, like grease. I just had my car in the dealer for a steering wheel replacement, and they performed the "world class inspection". Do they grease the sunroof as part of this?
I live in the high desert of Utah so I don't think mold or mildew is my problem. And the smell isn't a dead animal smell. |
08-03-2018, 07:35 AM | #14 |
Rep 16,065
08-03-2018, 10:31 AM | #16 | |
Rep 41
07-25-2021, 04:48 AM | #18 |
Rep 6
bad smell issue is solved
Solved, latest update to the interior/cabin smell :
the smell is confirmed to be the insulation material , mainly the front insulation under the dashboard. My car is BMW 2013 M135i, bot from BMW dealer in 2021 with extended warranty. The smell mainly come from the gap between the window and the dashboard. the smell is strong when the carbin is hot , eg. switch to hot A/C facing up or just put the car under the sun for a few hours. the smell is weak when A/C temperature is cool or use a big towel to block all the gaps on top of the dashboard . Took 2 weeks to oder the new sound insulation boards from BMW Germany . Cost only around $200 Then took around 8~12 hours to install the new parts. cost $2500 for labour. all paid by BMW dealer under warranty. Good luck everyone, don't buy old BMW, they used faulty material in old models. especially F20,F30 Last edited by ziyfan; 07-25-2021 at 04:55 AM.. |
