11-14-2023, 10:34 AM | #1 |
Rep 79
2017 340ix Brake Pads (340mm front & 320mm rear)
Hello, I have a 2017 340ix with 340x300 vented discs in the front and 320x20 discs in the rear, the gray brakes.
I've previously had the akebono, currently on the hawk 5.0. Haven't been a fan of either and was interested in trying ebc redstuff pads. It doesn't appear that they make pads for the rear single-piston rotors, am I wrong? |
11-15-2023, 03:26 AM | #2 |
1942
Rep 2,115
Personally I wouldn't pi$$ on EBC brake pads if they were on fire; absolute crap. Used to run them and towards the end kept having issues with both Redstuff & Yellowstuff. Never again
ATE Ceramic and Ferodo DS2500s would get my vote for aftermarket But have you tried OEM BMW (probably Textar); they're absolutely fine for every day driving but probably a bit dusty if you drive your car hard etc
g340ix31.50 |
11-15-2023, 07:44 AM | #3 | |
Rep 79
11-15-2023, 08:00 AM | #4 | |
1942
Rep 2,115
But I'd still run OEM pads over EBC any day personally; they've been nothing but crap for a good while The Ferodo DS2500s would be a good shout IMO; they can be dusty, but a good ceramic coat of your wheels will soon help with that
11-19-2023, 09:30 AM | #5 | |
Rep 1,372
11-19-2023, 09:59 AM | #6 | |
1942
Rep 2,115
I've had a number of unfortunate issues with them on various cars and never again Have stuck with OEM BMW, Ferodo and ATE since - depending on which car I owned etc... But having been in BMWs since 2010 and ran EBC Redstuff & Yellowstuff all round on my first 2 E39s before realising they were shit and moving to ATE; I've avoided them since I think they get more likes & buys via their marketing than anything else; you see them recommended all the time. A lot of car channels on YT use them as they're 'sponsored' by EBC - so basically they're getting free brakes etc; maybe they know no better as they've ventured elsehwhere
11-19-2023, 12:28 PM | #7 |
Rep 98
Just to chime in. Anything under EBC BLUE stuff is absolute crap. YELLOW is worst than many stock options. I personally use Bluestuff on my Audi Q5 and love them. Orange stuff for street/track use on my F30 335 with front M3 380mm Brembo brakes and love them also and Orange stuff on my Volvo S60 T5 . All the Yellow EBC pads I used came off in a month or sooner if I had time. I laugh when people say they did a track day with EBC Yellow stuff.
11-19-2023, 12:31 PM | #8 | |
Rep 98
danb19791941.50 |
11-19-2023, 12:33 PM | #9 | |
Rep 98
11-19-2023, 01:03 PM | #10 | |
1942
Rep 2,115
I've heard good things re the Bluestuff; but only on lighter cars (Hondas etc) and deffo not road use Personally Ferodo and ATE have always done me for fast road pads; some tack time (when I was younger and had more track related cars etc) and now; ATE or OEM BMW for road going/fast road pads Never had any issues with them; more so partnered with decent braided lines and fluid etc
11-19-2023, 03:59 PM | #11 |
Rep 2,048
The issue isn't necessarily that EBC can't make decent pads, but they can't make them consistently, and they very much under spec them for their intended use (reds aren't even 'hot hatch' territory). I mean how many pads have they released and called them either a track or a race pad, only to then bring out another pad above and call it the same thing. Yellows are passable, Blues work well when they work but fall off a cliff when they overheat, and Oranges are good but inconsistent batch to batch. I've used many of their pads in various cars over the years, and the only ones I quite liked were the Orangestuff, but then the second set I had were terrible with little bite and inconsistent feel. They also wear pretty quickly. I certainly wouldn't go recommending EBC red stuff - if you're after a good performance pad for fast road then I'd be looking at either HP2000 or DS2500. Up front you can definitely get both of those options as it's the same fitment as I have, but the rears might be more of an issue.
I always liked Carbon Lorraine RC5+ (and even RC7+) as a fast road pad where you only really did hard driving, less so as an all rounder where there was more daily driving as they're aggressive on discs when cold and would soon lose 'bed in'. The RC7 was even worse in that regard but the performance was utterly amazing when they were hot and in their working window (as were Mintex M1166). DS2500's are the classic fast road pad and are a good all rounder but I always found they weren't so good at chilled dailying as they took a few stabs at the pedal to get some bite out of them, especially the first time out after a hard run. The Brembo HP2000's might not have quite the same peak performance, although that said I haven't compared them on the same car (and the BMW is a heavy car, so I suspect that most realistic fast road pads would fade on or before the same point), but they are outstandingly good cold too which for me is a crucial consideration with the number of deer up here that you need to avoid. And when they do start to fade, they do so very progressively rather than one corner working and the next not, like some do. I've pushed them to the point of fading quite a few times, but then I also got less than 10k out my rear PS4S on XD which might give an indication of how they get used at times, and when they have gone to fade I've generally gone 'yeah, fair enough, I've been taking liberties'. I really like them for both what the car is, and how it gets used. The problem with pad recommendations is that everyone's driving is different (both in style and the roads you're on), and cars are different too. My 335Xd estate is nudging two tons with me, a tank of fuel and a few bits in the boot. In contrast my Impreza is 1450kg with the same (and the same power). That 500kg mass can be hidden by bigger brakes to an extent, but unless your cooling's spot on the heavier car will fade quicker if they're not getting much chance to cool off between corners. And you can always go up the temperature range on pads, but then the trade off is usually the daily/cold performance. The stock 294mm Impreza Sumitomo brakes were god awful for a 'performance' car with stock pads, but can be made to work with proper Carbon Lorraine RC8 rally pads, but they literally don't work cold. A bigger syestem with gentler pads will provide a bigger window of operation, but at the expense of consistency during harder use. |
