05-06-2021, 06:42 PM | #2 |
Rep 2
Hi. I have a late 2015 build that is (or was) running NBTevo_E16382A.
My system was upgraded to iDrive 6 + carplay by Easy Bimmer Coding. The unit only has 2GB but I’ve had no rebooting or crashing issues. It actually works pretty well. Thanks, Rod |
05-11-2021, 02:42 AM | #3 | |
Rep 3,056
We have tested and stable solution that works really well without reboots on this headunit.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
05-11-2021, 07:00 PM | #4 | ||
Rep 200
05-12-2021, 12:08 PM | #7 |
Rep 1,976
Drives: 2020 G20 320i M Sport
We offer this as part of our Level 3 Remote Support Session and have done over a hundred of these already without any issues.
You will however need a battery tender that can keep the vehicle battery above 12v throughout the 1.5 hour flash along with a Windows laptop with at least 25GB of available space and an ENET cable.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 05-12-2021 at 12:16 PM.. |
05-13-2021, 08:53 PM | #8 | |
Rep 287
and 2 laptops wit The the available space. i hav3 a Obd kline cable to usb/otg that i use to flash mhd i would have to obtain an enet cable Last edited by e38740imd; 05-15-2021 at 06:48 PM.. |
05-14-2021, 09:06 AM | #9 |
Rep 1,976
Would this be for the 2016 640i or another vehicle because that vehicle would be on the older NBT system.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-15-2021, 06:47 PM | #10 |
Rep 287
05-18-2021, 05:55 AM | #11 |
Rep 1,976
That would be NBT and not EVO but you can still replace the HU to have ID6 with Apple CarPlay.
05-19-2021, 04:40 PM | #13 | |
Rep 25
Also is it reversible/traceable by dealer if I were to revert back for warranty issues? |
05-23-2021, 07:00 AM | #14 | |
Rep 30
Update only if you plan to use Carplay only for directions.
Apple Carplay Fullscreen
Android Screen Mirroring ///M Coding |
05-25-2021, 10:46 AM | #15 |
Rep 4
06-15-2021, 12:04 PM | #16 |
Rep 30
Everything works well except BMW Navigation. You can pm me for more info if needed.
06-15-2021, 10:49 PM | #17 |
Rep 1,976
We've been doing this flash since 2017 and I have personally done this on my own 2016 328i xDrive at the time so as stated above, if you plan on using Waze, Google Maps and Apple Maps as a substitute to the stock BMW system, there will not be any issues.
06-16-2021, 12:04 PM | #18 |
Rep 3,056
As others pointed, when using CarPlay Fullscreen it works just fine. No issues, lags, reboot. Problems may appear when using OEM nav.
11-15-2021, 01:14 PM | #20 |
Rep 3,056
08-13-2022, 12:20 PM | #22 |
Rep 3,056
PM sent
