05-21-2020, 02:01 AM | #23 | |
Rep 63
I only have a picture of the front of my NBT EVO HU, found it in photo library- 2505754 is in bold in the top right, perhaps thats a part number. So ATM was priorly active but still bad in latest problem? Last edited by Ddayan97; 05-21-2020 at 02:01 AM.. Reason: @ |
06-01-2020, 12:18 AM | #24 | |
Rep 63
07-01-2020, 06:58 AM | #25 |
Rep 184
Drives: 435i xDrive
Ddayan97 any updates?
E9x picture game: 1 point
07-05-2020, 10:03 PM | #26 |
Rep 63
07-06-2020, 01:36 AM | #27 | |
Rep 526
But what happens in the options and prices you are offered for services? Services are based on VIN number and technology available at the time, not a retrofit. For example, Over the Air Navigation updates were not offered for your VIN. Are they now? Do they offer you Apple CarPlay? Can you post screenshots of what BMW Connected Drive Store is actually offering you for your non-ATM VIN and at what prices? |
07-08-2020, 07:04 PM | #28 | ||
Rep 63
07-10-2020, 11:52 AM | #29 | |||
Rep 526
Again, as services offered are based off the VIN and OEM Equipment, it will be interesting to see if you are offered the NBT EVO services in Connect Drive. Check attachments: if you are really getting the NBT EVO Options you should see these options and prices. If you do not see all these, then it seems that this is a big drawback of a BMW Dealer installing a new retrofit ATM coded to your vehicle. as opposed to retrofitting an eligible used unit. |
09-03-2020, 07:32 AM | #30 | |
Rep 208
Drives: San Marino blue 435i Gc
09-04-2020, 12:01 AM | #31 | |
Rep 63
So I actually have to replace brakes this week at 37k miles, a little early but not too bad. Going to also swap emblems from silver to black (not so simple on vert). Going to check out the connection with the harness and get back to you. DM me for my cell let’s connect |
06-11-2021, 07:30 PM | #32 | |
Rep 10,256
Did your dealer have any concerns about VIN / equipment mismatch? Please share more details. |
08-01-2021, 01:44 AM | #33 | ||
Rep 63
Dealer initially pushed back but after explaining what I was doing they were okay with it. I also explained that the ATM was already in the vehicle |
08-01-2021, 09:34 PM | #34 | |
Rep 526
Still waiting for answer to my question 13 months ago. New ATM coded to VIN worthless if BMW Connected Drive will not offer you service for the ATM in a TCB vehicle. |
08-09-2021, 07:02 PM | #35 | |
Rep 106
Drives: 2014 428i F32
connectivity? SOS, Lock unlock etc...Any issues that you encountered? Thank you |
08-24-2021, 02:42 PM | #36 |
Rep 12
ATM WLAN_Status missing
Hi,
I'm trying to activate the wifi hot-spot on my F36 with OEM NBT Evo ID4 and ATM with connected services active.(Not retrofitted) The wifi menu is accessible under settings/connections but for some reason, I can NOT click it to activate it. noticed in BMWAI Code software that ATM has WLAN_status but the actual FDL in my car ATM module doesn't have this parameter. can someone help? thank you. |
08-28-2021, 02:53 PM | #37 | |
Rep 526
If you did not replace ATM hardware with WLAN version, then you cannot activate hotspot as it isn’t there, which sounds like your problem. As you say this is not retrofitted, then it should be active from factory if your F36 is equipped with the proper ATM. No coding required. |
08-30-2021, 08:38 PM | #38 | ||||
Rep 12
thanks for getting back to me. how can I check whether the ATM installed is with wifi or without wifi? is it by part number or sticker on the module? |
09-23-2021, 08:56 AM | #39 | ||
Rep 63
02-24-2022, 01:30 PM | #40 |
Rep 8
Hey Guys,
today I installed a brand new ATM without activation in my car. PB-Coding did activate it, now I have all options 😍 RTTI, Wheater, CarPlay Fullscreen etc. It is no longer important that the ATM is used without connected services or a brand new without activation. https://www.personalize-bimmer.de/ |
02-26-2022, 03:39 PM | #41 | |
Rep 5
02-28-2022, 10:52 AM | #42 | |
Rep 1,117
And you cannot get any Remote Services, App Features or Send to Car commands as all coded units using someone else’s VIN (for now). |
12-22-2023, 06:08 PM | #43 |
Rep 18
I have retrofitted ATM and ID5 (with graphics ID6).
Work all (lock/unlock/clacson/position/weather/bmw online etc). NOT WORK: RTTi and LSC (state door/window in app)... can anyone help me? New, original ATM coded on my original VIN |
12-25-2023, 06:29 AM | #44 |
Rep 593
Drives: 2018 F48 X1 xDrive 18D
Does anyone have more info on the microphones part?
