03-08-2021, 10:59 AM | #1 |
Rep 1,119
Drives: 2015 BMW 435i Xdrive MSport
Removing PPF from Headlights
Hi everyone,
I have to have my headlight PPF redone. my question is, will removing Xpel PPF damage the headlight in the process. I know Porsche has this issue but couldn't find anything on it with BMW. Thanks.
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
03-08-2021, 08:12 PM | #2 |
Rep 2,197
If you know the PPF is from Xpel I'd try contacting them. Good luck!
03-09-2021, 05:20 AM | #3 |
Rep 1,119
Yeah it's Xpel.
03-09-2021, 05:50 AM | #4 |
Rep 3,872
It should not. But it can, potentially.
I doubt Xpel would commit to anything much different than the statement above. This was the very reason that sopped me from applying PPF on them, after I had already bought it.... Please do write back about Xpel's response and your experience with the removal! I may reconsider applying it... Also why do you need to have them redone and how long has the PPF been on them?
03-09-2021, 06:51 AM | #5 | |
Rep 1,119
03-09-2021, 07:16 AM | #6 |
Rep 83
i had xpel tint foil on my headlights for a few days.
removed it without any problems, just heat it up a bit with a hairdryer and peel it off slowly. |
Boostedphil698436.00 |
03-09-2021, 07:28 AM | #7 |
Rep 3,872
4 days is nothing. I wouldn't expect any problems whatsoever. Just heat them up before removing and you should be fine.
My concern is what happens after 1-2-3-4 years.... baked in the sun, frozen in the winter... etc.
03-09-2021, 07:36 AM | #8 |
Rep 1,119
They're gonna steam it off I know that. I want the PPF to protect the headlights. At $1,600 apiece, I'm not looking to replace them again.
03-09-2021, 07:58 AM | #9 |
Rep 3,872
That was/is my dilemma.... Since I don't drive much these days, I am unsure whether a PPF will protect €1600 headlights in the long run... or damage them once the film is to be removed in a X years time... (due to age or degradation)
Was it easy to shape it and apply it? I only put if on the fog lights, which was easy. Low risk there too, in comparison.
03-09-2021, 08:02 AM | #10 |
Rep 16,081
It will still come off when heated. The problem with aged films is that they may have developed cracks, so instead of coming off in one piece they may come off in small sections.
03-09-2021, 08:12 AM | #11 | |
Rep 1,119
Yeah, they're gonna steam it off and use new film and then let the film sit over night under heat because of the weather.
03-09-2021, 08:12 AM | #12 |
Rep 3,872
Oh it will come off, that's a given. But there are reports on the net (specifically from Porsche, but not exclusively) that they occasionally come off together with the headlight top-coat, effectively damaging the headlights.... That would be extremely nasty....
03-09-2021, 08:13 AM | #13 |
Rep 1,119
Xpel says they're products are safe, now if both my headlights get damaged, I'm sure not going to be paying for brand new OEM headlights.
03-09-2021, 08:17 AM | #14 | |
Rep 3,872
I wax them for the same reason. Neither wax, nor ceramic coating however will protect them from stone chips... which is actually the most important protection they need, if any, in the long-run.... Only a PPF can do that.
03-09-2021, 08:19 AM | #15 |
Rep 3,872
May I also kindly ask you for some photos of how the PPF looks on the headlights... specifically how visible the edges are.
Much appreciated.
03-09-2021, 08:31 AM | #16 |
Rep 1,119
The stuff is basically invisible. For some reason, the pictures won't attach.
03-09-2021, 08:47 AM | #17 |
Rep 3,872
You can use Imgur ... would be very curious to see.
03-09-2021, 09:15 AM | #18 |
Rep 1,119
It's basically invisible.
09-18-2021, 12:32 PM | #19 |
Rep 3,872
Thanks to the encouragement here, I finally went ahead and installed my XPEL headlight protection film.
The videos in youtube make it look so easy.... Except that it is not! The F3x headlights must be in the "hardcore" category in terms of difficulty, due to their 3D shape! As a result, I got a lot of small water-bubbles and some "orange skin" stretch marks on top, where the material had to be compressed. Worth noting that the bubbles appeared within about 15-30 min of application. I did not just leave them in there. The film was mostly flat and bubble-free when I initially applied it. Did you guys have similar bubbles after the installation and did they go away in time, as they say? [IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG][IMG] View post on imgur.com [/IMG]The second headlight came out better, as good as no stretch-marks and less bubbles but still plenty.
09-18-2021, 04:11 PM | #20 |
Rep 881
If it’s real Xpel, it won’t crack or yelllow. And it should be removable with no damage to the underlying paint/plastic even after a long service life. That must be some especially sensitive coating on the P-car lights, BTW.
I was never a PPF fan previously, but I’m so glad my 435’s whole front fascia, incl headlights, was Xpel’ed professionally when new. It’s now obvious to me Xpel make a superior product. It’s coming up on 6 years now, and I’m amazed how well the front has held up. It’s not babied by any means, and it’s mainly parked outside year-round. Rocks, bugs, winter sanded roads, ice/slush and what have you have been all over it repeatedly — though it’s hard to tell. ;D It’ll often look better than much newer yet unprotected cars front-ends at the meets I attend. Everything in this pic is Xpel covered except the grilles and sidemarker… Note: their Headlight Protection Film is an entirely different product than their PPFs. Last edited by visionaut; 09-18-2021 at 08:32 PM.. Reason: Added HPF note… |
09-19-2021, 08:21 AM | #21 | |
Rep 1,641
09-19-2021, 08:28 AM | #22 | |
Rep 1,641
Good luck! |
