08-21-2021, 06:38 PM | #1 |
Rep 487
I have the CTS catted DP and the CEL came on not too long after installation.
Gotta get this thing pass emission in OR. Questions: 1. do spacers work long term? 2. which one (please attach links) has been proven to work well? 3. anything else I should know before going this route? 4. I only need to install the spacer for A (in the pic), NOT B right? 5. Do I have to take the downpipe down or is it a pretty simple add? Thank you! |
08-22-2021, 09:49 AM | #2 |
Rep 85
The 90 degree spacer fits well and a lot of them come with a tiny catalyst in them. They are not vehicle specific and a quick Google search turns up quite a few. I think fabspeed sells one for a couple hundred dollars but it appears to have the biggest mini catalyst, although they don't claim to be CEL free. It is for the O2 sensor after the cat which only monitors the cat efficiency. I really think it's hit or miss with these but a 90 deg with mini cat is probably your best bet.
lixiang7349283.50 |
08-25-2021, 10:24 AM | #4 |
Rep 116
I just grabbed a pack of O2 spacers from autozone (think they're called something else for legal reasons), stacked them together and I haven't had a CEL for over a year
09-24-2021, 09:22 AM | #6 |
Rep 85
The post cat O2 sensor lives only to taddle on you. It doesn't have anything to do with engine management.
lixiang7349283.50 |
09-27-2021, 08:12 PM | #7 |
Rep 4,902
Don't think it will work well on these newer cars unfortunately
10-10-2021, 08:20 AM | #8 |
DisplacementReplacement
406
Rep 1,100
i'm running the CTS catted and used a small spacer on 02 sensor #2/rear/ in your illustration A and i have no MIL but more importantly have satisfied readiness which is the key in my state for inspection...
2020 X3M /// MHD Tune
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 |
10-10-2021, 08:35 AM | #9 | |
Rep 487
I'm 2+ and I have 3 incomplete (INC) showing up. Fuel is due to the tu hpfp I guess but it's "OEM" supposedly. Was hoping to not run into this issue. The other 2 are cat related I'm guessing |
10-10-2021, 02:05 PM | #10 |
Rep 1,004
i have cts catted and tu pump on bm3 with O2 spacer, i could never get readiness unless i flashed back to stock. it was driving me nuts, fuel system and cats were never ready.
lixiang7349283.50 |
10-12-2021, 05:27 PM | #11 | |
406
Rep 1,100
Curious question is::: Do you have factory cat or aftermarket cat checked off in options? I have factory cat checked... Edit, just checked, set readiness with the 95 map also...
Prior Bimmers 2017 240XI Hybrid / FBO / MHD E40 2015 235XI FBO / MHD E30 2009 335XI FBO / COBB / E30 Last edited by Jnat; 10-12-2021 at 06:23 PM.. |
10-12-2021, 05:58 PM | #12 |
Rep 163
10-12-2021, 06:21 PM | #13 |
406
Rep 1,100
Yes...
10-13-2021, 12:38 AM | #15 | |
Rep 163
10-13-2021, 03:57 AM | #16 |
Rep 1,004
i had problems trying to pass on stage 2, fuel system was never ready and either were cat monitors even though i turned them on. i banged my head for a while and finally someone suggested to flash to stock, after that i was ready, all monitors. never had an issue on my n54 with leaving my custom tune and catless dp, i would just have 1 monitor not ready which is ok in NY.
leew10283.00 |
10-13-2021, 08:10 AM | #17 | |
Rep 163
04-17-2023, 05:18 PM | #20 |
Rep 20
O2 Sensor spacer
Hey I am having the same trouble with passing Inspection and am tired of wasting money and time switching back to stock downpipe. Which o2 sensor spacer would I be able to try to get passed inspection. I have CTS high flow catted down pipe.
04-17-2023, 05:24 PM | #21 | |
406
Rep 1,100
btw, with this spacer on my kittyless downpipe all monitors set, i can't explain it...
