09-07-2021, 03:31 AM | #1 |
Rep 179
Small Vibration - normal driving
I've had some small vibration feel for some time now, brakes have been done, suspension checked.
Could it be something as simple as wheel balancing. Its very subtle, hardly noticable but i know its there. |
09-07-2021, 05:08 AM | #2 |
Bird Flu and Cat Aids combined
857
Rep 1,122
Is it there constantly or just when you get to certain speeds? certain speeds would typically indicate it's a balancing issue.
Instagram: BIFCAIDS
09-15-2021, 06:40 AM | #4 |
Rep 179
Had my wheels balanced. Slight improvement but still there. Seems to be that the suspension is just too hard and road imperfection is felt. When i put it in sport mode its terrible.
Next step is to ditch the run flats, but before my discs were done it never felt like this. |
09-16-2021, 04:31 AM | #6 | |
Rep 179
I am also ditching the run flats, hopefully will make the ride much better. |
09-21-2021, 11:03 AM | #7 |
Rep 179
Anyone got any thoughts on this?
At low speed over uneven ground seems to be the worst. Like a gravelled area - feels like the wheels are going to fall off! |
09-21-2021, 11:23 AM | #8 | |
Rep 15,858
Low speed... doesn't fit with wheel balance or typical driveline vibrations. |
BIFCAIDS857.00 |
09-21-2021, 11:53 AM | #9 | |
Rep 179
Adaptive suspension standard. Control arms checked etc Alignment done by bmw, wheels balanced New discs and pads. This only seemed to start after I did the discs the first time which subsequently warped |
09-22-2021, 02:35 AM | #11 |
Rep 179
09-22-2021, 03:30 AM | #12 |
Rep 15,858
Your sequence of events (new discs) and the current low speed feeling, does hint at something adrift with the suspension. Are you sure the front tension struts, or control arms are not showing softness or wear in the bushings. Possibly disturbed when jacked up for the disc change. At 111k miles wouldn't be surprised, unless parts already changed.
09-22-2021, 06:43 AM | #13 | |
Rep 179
I’ll get them to check again |
02-09-2023, 06:38 AM | #14 |
Rep 1,255
