09-19-2021, 10:42 AM | #1 |
Rep 424
I have 8.5j ET30 19s square and I'm running stock sizes 225/255.
I wonder if I go 245/35 up front if it will rub? The overall diameters for 225/40 and 245/35 are 26.1" vs 25.8" so technically it won't rub? Ps: I tried running 235/40 initially upfront and it was slightly rubbing on reverse but I did have some chunky winters on at the time. Technically 245/35 is smaller diameter so it shouldn't rub? I see people running 245/35 with 255/35 so I'm thinking of going this route. Thoughts? EDIT: stock M susp RWD
//'17 F36 440i Mineral Grey
//MPPSK w/carbon tips //Apex ARC8 255/40/18 //MST intake //AutoTechnik brace |
09-25-2021, 08:28 AM | #3 |
Rep 424
Bump
Anyone run 19" ET30 with 245/35 tire?
09-25-2021, 09:10 AM | #4 |
Rep 880
I’m currently running 245/35-19 PS4S in front on my 19x9 et30 SM-10s. No rubbing or other fitment issues with original THP suspension. Since your wheels are 8.5” vs 9.0” with same offset, you’d have 6.4mm more clearance on both sides…
obzen188.00 |
09-25-2021, 09:16 AM | #5 | |
Rep 424
So I should be good to run 245s without rubbing. What's your back tire size?
09-25-2021, 11:52 AM | #6 |
Rep 880
THP (Track Handling Pkg) is basically M Sport plus the EDC dampers, VSS, M Brakes, etc.
I’m running 255/35-19 in the rears. I originally had these four PS4S tires on my OE 442M 19” staggered wheels with spacers. I had switched out the original 225 fronts as they seemed undersized, and the 245 upfront was a big improvement). I’ll probably go with 255s all around with the next set on these SM-10s. |
obzen188.00 |
09-29-2021, 07:39 AM | #7 | |
Rep 424
Your comment on this thread is enough for me to get the 245s since your setup is pretty much the same as mine without issues
