09-24-2021, 02:52 AM | #1 |
Rep 2
Wheels offset/ET suggestion
Hi all, Looking for some opinions and advice regarding the rims offset/et
currently running on my f30 : Front : R19 8.5 ET 32. 245/35/19 Rear : R19 9.5 ET 35. 275/30/19 I'm planning to change the rims to : Front :R19 8.5 ET 30. 245/35/19 Rear : R19 9.5 ET 40. 275/30/19 or front ET 35 rear ET 40 I dont like using any spacer. Any suggestion for the ET fitment without spacer? Thanks for the read and Help (sorry for my bad english) now using eibach Pro kit |
09-24-2021, 05:05 AM | #2 | |
Rep 32
I'm unable to comment on the 19" wheel diameter as I'm running 20". But, my current setup is: Car is sat on H&R Supersports (reds) Front is 8.5j ET32 no spacer required. Rear is 10j ET48 (10mm spacer so ET38) I've ordered a new set of wheels with the following configuration: Front: 9j x 20 ET26 Rear: 10j x 20 ET42 I hope these will be a direct bolt on, no spacers. Yes fitment is on the aggressive side but that's what I'm looking to achieve. I think you'll be fine. |
09-24-2021, 01:25 PM | #3 |
Rep 343
I am not lowered and on m adaptive suspension and rear wheel drive so my setup might not be exactly as yours.
I find offsets of 25 ET front and 35 ET rear to be perfect for my car, again you are lowered so you might want to be even more aggressive it just depends on what you are trying to achieve. Good thinking about trying to avoid spacers, I have spacers in the front and I have slight vibrations at certain speeds which I hate. |
