BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Injen Intake For BMW 230,330 & 430
      11-09-2018, 07:26 PM   #1
mike@x-ph.com
mike@x-ph.com's Avatar
Drives: 2007 e92 335i / 2013 F30 328
Talking Injen Intake For BMW 230,330 & 430
Add some more horsepower to your BMW with this Injen Technology SP performance short ram air intake! The Injen engineers spent an abundant amount of time designing, testing, and perfecting the SP1123 to produce serious bolt-on power with amazingly killer Horsepower gains. In addition to the impressive power increase, the Injen team has ensured that a safe Air fuel (A/F) ratio has been maintained throughout the powerband. The soul of this short ram intake it is our mandrel-bent aluminum air intake tube that presents a smooth uninterrupted path for highly efficient airflow. Additionally, the SP1123 also includes a fully serviceable Injen SuperNano-Web dry air filter, which provides increased filter surface area, allowing for greater airflow and unbeatable filtration. This Injen SP performance intake provides power you can hear! It is a truly an upgrade for intake sound and provides an aggressive throaty tone, especially when you smash the hammer down. Do you want to add a personalized touch? Well, you are in luck, the SP1123 is offered in a polished (SP1123P) finish or a powder-coated wrinkle black (SP1123WB) or wrinkle Red (SP1123WR) finish. Plus, just like all other injen performance air intake systems, this intake kit includes the unbeatable Injen limited Lifetime Warranty!
KEY FEATURES
• Dyno-proven maximum gains of up to 12 HP and 14 ft. lbs. of Torque
• Aggressive intake tone under acceleration
• Stainless steel band clamps with inner protective liner
• Automotive grade silicone couplers
• Designed to work with stock calibration
• Air filter placed to receive coolest densest air charge with maximum airflow
• SuperNano-Web Dry air filter requires no oil
• Heat shield helps to keep unwanted hot air from entering the air filter
• Mandrel bent 6061-T6 aluminum induction tube
•Available with a polished (SP1123P), wrinkle black (SP1123WB) or wrinkle red (SP1123WR) tube
HP GAINS 12 HP
TORQUE GAINS 14 ft-lb of Torque
UPC 843115026257C46
SHIPPING WEIGHT 8 Lbs.
BOX SIZE 36" x 13" x 8"
Polished
Black
Red
Solidjake490.00
N26Ghost436.00
      11-10-2018, 05:21 PM   #2
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
This may be a dumb question but would I expect any low-end torque loss with this intake? I'm currently running muffler delete on my 430 and ended up getting the JB+ because it initially felt a bit more sluggish on the low-end after deleting my muffler. Just don't want to back-track any further.
      11-10-2018, 06:06 PM   #3
mike@x-ph.com
Check dyno below, it shows TQ before and after intake. No loss of power at any point, in fact you will be gaining power with this intake
      11-10-2018, 08:15 PM   #4
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
And I'm assuming it shouldn't throw a CEL or anything right? Could you PM me with price please?
      11-10-2018, 08:18 PM   #5
mike@x-ph.com
No CEL
      11-10-2018, 09:31 PM   #6
Sweeney921
Sweeney921's Avatar
90
Drives: 2000 BMW E39 M5
It's listed on their website
https://x-ph.com/injen-intake-for-bmw-b48-230-330-430/
2017 BMW 330i Sport Wagon - M-sport, EBII, THP, DHP
Supersprint cat-back exhaust (resonated, dual outlet) - H&R rear sway bar - ER charge pipe
Waiting for: Bootmod3 - xHP Flashtool - xDelete
      11-11-2018, 02:56 PM   #7
mike@x-ph.com
Originally Posted by Sweeney921 View Post
      11-28-2018, 12:10 AM   #8
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
Just waiting on shipment/arrival but I'll be sure to post a sound clip and brief review upon installation!
2019 F32 430i Sport Line MG/CR: BM3 Stage 2 91 AGG | Injen SP1123 SRI | ER Anodized CP | ER 4" Catless DP | Resonated Straight Exhaust
Past: 2015 F30 328i AW
      11-28-2018, 06:05 AM   #9
N420i
Drives: 2016 420i lightly modded
Man we europeans take a HEAVY price hit with this... It's 300 bucks with free shipping in the US and 389€ + shipping in the EU... That comes to about 420€ so just under 500 bucks. WTF?
      11-28-2018, 07:19 AM   #10
Sweeney921
Sweeney921's Avatar
90
Please do! Very excited to learn more about this product for my B46.
By chance do you also have a way to log intake air temps? Wondering how they look in real world use, because the dyno graph doesn't indicate whether testing was done with the hood up or down.
      11-28-2018, 07:31 AM   #11
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
I don't, but it looks like Injen's dyno with the intake installed was running at almost 15 degrees hotter than the stock dyno run. Honestly I have no idea how much of a temperature difference there typically is running with the hood open vs. hood closed but perhaps that difference at least partially makes up for it?
Speaking completely hypothetically here.. but that was my way of rationalizing the purchase without having further details on the dyno conditions
      11-28-2018, 04:43 PM   #12
Sweeney921
Sweeney921's Avatar
90
I'd say that the ambient conditions were favorable for comparing the Injen intake vs OEM. They did a great job picking the right day for their install. It's also easier to justify and advertise higher power levels when the conditions were actually worse with the aftermarket intake, so kudos on Injen for doing it right.
That being said, whether or not the hood is raised has a HUGE impact on intake air temps with a pod filter. Conversely, it wouldn't have a major impact with the OEM intake. My take is that these dyno measurements would be drastically favored towards Injen's intake if they were done with the hood opened.
Still, looks like a nice intake. Still considering it for my car. Let us know what you think!
      11-28-2018, 04:56 PM   #13
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
Will do! My order status still says Awaiting Shipment but it should hopefully be on its way to me soon. I did place the order a few days before Black Friday so I'm sure they're swamped. Honestly, I bought it looking for a full intake rather than the BMS attachment for the B48 really just to balance out the occasionally-rough sound of my muffler delete set-up, so any notable power gain at all will be a plus
I tend to pay little attention to company dynos on aftermarket intake and exhaust set-ups as we all know the gains tend to be rather minimal, if any. With the intake my only concern would be potential heat-soak, which hopefully the heat-shield will help avert.
      11-30-2018, 11:01 AM   #14
chums
Drives: 328
How does it sound? Similar to the original F30 328 injen intake?
      11-30-2018, 07:44 PM   #15
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
Just installed. Based on the clips I've seen of the 328i intake it sounds very similar. How do I post a video on here?
The clip doesn't do the sound much justice but it's pretty loud and audible inside the car while driving. Pedestrians turned heads every time I let off the gas so I'm sure it's even louder outside the car. Drove about 20 miles on the way home and my mileage range and MPG actually went up. Car feels like it pulls harder and even my exhaust is giving me more pops and burbles.
Definitely worth the money
      12-01-2018, 09:15 PM   #16
idontsave
idontsave's Avatar
Drives: B46 F32 LCI
Here's the clip. As I said, it doesn't do the sound much justice.
      12-03-2018, 10:50 AM   #17
KC328_F30
KC328_F30's Avatar
Drives: F30 328i xDrive
Love the open design for this one!
MG F30 328i / M-Performance Aero Package / M-Performance Big Brakes / M-Performance 340 Exhaust Retro / M-Performance CF Interior / F80 CF Mirrors / F80 CF Trunk Spoiler / Dinan Springs / 405M Wheels and Forged Alum. Spacers / Falken FK510 Tires / Avin 12” Android Screen Retofit / BM3 Stage 1 (94 Octane) / ER DP and TIC / VRSF FMIC
Instagram : MG.328_F30
      12-03-2018, 11:42 AM   #18
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
      10-18-2019, 12:08 PM   #19
mike@x-ph.com
Thank you Atri for the pictures
      11-04-2019, 09:10 PM   #20
pops430i325ci
pops430i325ci's Avatar
Drives: 2006 E46 325CI; 2018 F33 430i
Anyone know of a comparison between this Injen Intake and the MST Performance Intake for B48/F33? Been considering an MST.
