11-10-2021, 11:37 PM | #1 |
M-Experienced
47
Rep 196
Drives: 2024 BMW X5 xDrive50e AWD SUV
Do BMW tires have a TPMS system inside the rim?
Hi all,
I have a 2020 BMW F36 (Grand Coupe) and I need to purchase Winter Tires. BMW is quoting me $3500 CAN (I'm in Calgary) all in. However, I have found some cheaper OEM ones on Kijiji. I am concerned and confused about TPMS though. I am hearing mixed comments. Does BMW use TPMS inside the rims, or is it installed somewhere else? I don't wanna get screwed on buying tires for winter, but I can't be without a TPMS monitor. Any advice? Derek |
11-10-2021, 11:43 PM | #2 |
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Yes, the monitor is inside the rim of the wheel attached to the valve stem.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
11-10-2021, 11:58 PM | #4 |
M-Experienced
47
Rep 196
I gotta be so careful. Lot of crooks out there who "claim" to be selling BMW tires, but when I push them about the TPMS they say "BMW does't use TPMS"... So I know they are full of crap.
11-11-2021, 06:38 AM | #5 |
Rep 33
Drives: 2016 328ix
OP, AFAIK, in Canada we use a flat tire monitor system not TPMS. Check out thread below:
https://f30.bimmerpost.com/forums/sh....php?t=1764847 |
Th3Walrus340.50 |
11-11-2021, 07:14 AM | #6 |
Rep 1,798
You can get by without (in Canada anyways). I'm currently not running any in my winters but also coded them out to avoid running into any problems.
Downside is that you wont be able to check pressures on your computer or anything else TPMS related obviously. It's still good practice to check your cold pressure temperatures manually once a month or so. |
11-11-2021, 07:21 AM | #7 |
Rep 4,877
Are you sure you have TPMS? Can you see individual tire pressures on the iDrive? My 2016 and 2008 just used rotational measurements from the ABS to detect low pressures. They are just regular rims and regular tires.
I had bought winters from 1010tires (they are in canada), with Replika rims from them. They arrived pre-mounted, pricing was much better than the dealer (I want to say $2000 for the mounted set). |
11-11-2021, 07:33 AM | #8 | ||
Rep 16,086
https://f30.bimmerpost.com/forums/fo...play.php?f=423 |
11-11-2021, 12:01 PM | #9 |
Rep 1,798
I'm not sure, my 2017 car is "stupid" too, not even a reverse camera. I think the newer 2018+ tech packages have more standard gadgets like that.
11-11-2021, 12:59 PM | #10 | |
Rep 4,877
I'm assuming the law dictates "some sort of pressure monitoring" for Canada, so they go the easy route. Honestly, it's good enough. |
11-11-2021, 04:25 PM | #11 |
Rep 283
If you want you could save a ton of money and buy winter tires for your current wheels and have the tire shop swap them out for the winter. Then when winter is over go back and have them swap the original tires back on. That way you don't need to worry about buying or moving sensors.
11-12-2021, 08:27 AM | #12 | |
Rep 4,877
The disadvantage of have rubber swapped spring/fall is you need to load up the tires in your car, drive to a shop, wait, drive home. If you have storage space for the winter tires, then you can swap them at your leisure in the driveway/street. But yes, you need to buy wheels with is $$. My Replika wheels cost $170CAD each a couple years ago, but look like they are sold out due to supply chain issues : https://www.1010tires.com/Wheels/Rep...80-12SN-35C726 |
11-12-2021, 09:10 AM | #13 |
Rep 16,086
If you have large summer rims you shouldn't be using them for winters, as they're far more prone to pothole damage than smaller rims with higher aspect tires. Winters also work better when they're narrower, so wide summer rims are counter productive in that respect as well.
11-12-2021, 03:44 PM | #15 |
Rep 234
Older BMWs used the ABS system to calculate tire pressure (as in my e83 and e38). AFAIK newer models all have valve stem sensors in the US market. This is how it's able to measure exact pressure and tire temperature.
It's my understanding that non-US market cars may still use the ABS system for tire pressure.
11-12-2021, 10:39 PM | #16 |
M-Experienced
47
Rep 196
Thanks all. I took my car down to BMW Gallery today here in Calgary and they confirmed the wheels do have the TPMS inside them.
11-13-2021, 07:45 AM | #17 |
Rep 16,086
You could have confirmed that yourself. On your iDrive Control Display:
1. "Vehicle info" 2. "Vehicle status" 3. "Tire Pressure Monitor (TPM)" A VIN check would show it as well. |
11-13-2021, 09:04 AM | #18 | |
Rep 546
Also check your valve stems, if they're traditional rubber ( they flex) then your don't have tpms sensors. If they're metal, you probably do. But sounds like dealer is trying to pull a fast one to me. |
11-13-2021, 09:15 AM | #19 |
Rep 4,877
I wouldn't trust BMW Gallery with a 10 foot pole. That place is as slimy as it comes.
If you go into your iDrive, and go to tire pressures, you will see 4 pressures for 4 tires if you have TPMS. If it just has a tire pressure reset and no actual numbers, you do not. And as i128 said, the sensors come with metal valve stems. |
11-13-2021, 10:30 AM | #20 | |
Rep 115
11-13-2021, 12:02 PM | #21 | |
Rep 283
Having it shown on your infotainment screen is very nice to have I love this feature.. I check my tire pressure pretty often on screen. |
11-13-2021, 12:31 PM | #22 |
Rep 16,086
tpms |
