BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
European Auto Source (EAS)
      01-09-2018, 04:11 PM   #221
WaqasRiyami
Oman
45
Drives: BMW F10 ( 535i )
I just finished flashing Stage 0 - it took 27 min , using bimmer geeks pro cable
For power source, i used my other car to charge the bmw while flashing.
Didnt flash OTS Map , since i have the JB4 and will flash A BackEnd Map.
_______________________________________
2011 F10 535i N55 PWG AT | JB4 - BT.Rv3 | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler |
View post on imgur.com
      01-09-2018, 04:55 PM   #222
KevDon92
Drives: 2014 435i
Originally Posted by GatorF30 View Post
$249 for the license and $99 for a map pack...all in all cheaper than JB4, without the cheap shitty wiring that falls apart on them, without tapping into OEM connections and causing them to go bad, and will actually remove the check engine light for catless downpipes.
I don't give a crap about resale value. It's ~$350 for a good running car without worry or cheap components. If you can't afford that, don't buy a BMW.
The newer JB4 does not require any taps nor have “wiring that falls apart.” I didn’t ask for your opinion on it, I simply asked if there was any option to resell down the line as competition offers. Thanks for not even remotely answering my question
      01-09-2018, 05:21 PM   #223
CTDrifter
Drives: 14' 335i
Read the first post by MHD it?s answered there. If you?re worried about release value then you should stick to the show and shine threads...
GatorF30339.50
      01-09-2018, 05:26 PM   #224
GatorF30
Drives: EBII F30
Trust me, it definitely has wiring that falls apart.
MHD Tuning1550.00
FSociety2997.00
      01-09-2018, 05:30 PM   #225
kevinjt
kevinjt's Avatar
131
Drives: 335i M-Sport 14'
Hey, glad that everything went good!.
For flashing with jb4 installed, u had to switch to map 0 and then flash correct?
After you.flash the BEF, should.the JB4 stay in map 0?
      01-09-2018, 05:32 PM   #226
BeeEyez
Drives: 435i Dinan Stage 3
Would I have to remove my dinan software before flashing stage 0? I want to get set up for flashing stage 2+ and didn’t know if the dinan piggyback would cause issues on the stage 0 flash
      01-09-2018, 06:50 PM   #227
f32_027
Driver
f32_027's Avatar
Drives: 435i
Originally Posted by BeeEyez View Post
Would I have to remove my dinan software before flashing stage 0? I want to get set up for flashing stage 2+ and didnÂ’t know if the dinan piggyback would cause issues on the stage 0 flash
You should definitely remove it, at least to err on the side of caution
      01-09-2018, 06:53 PM   #228
valve float
Drives: 335i
Originally Posted by chaungo View Post
And they are correct.
I was running stock gap and my timing was way off, I was asked if my plugs were changed recently and gapped to their recommended specs. I told them they had around 25,000km on them. I swapped the plugs and gapped to .018 and the timing has never been better, it actually fixed the low timing with no map changes at all.
It seems the sweet spot for higher boost is between .018-.020.
I trust the guys at PTF who have been doing this for a long time and tuning and testing thousand of cars with different plugs and gaps to know what they are talking about. If you really want to test the theory, run a OTS map on stock plugs and gap and then regap them to .018 - .020 and relog.
this is the MHD thread...BM3 has their recommendations....so be it...great...
MHD has their own...so keep your BM3 specs to the BM3 thread...
bye bye...
      01-09-2018, 07:04 PM   #229
Kennedy28
Drives: 2014 335i
kevinjt After the BEF is completed through the MHD app you just use your jb4 as you always would. The BEF is just allowing more parameters of the engine to be tuned that the DME can only do and the jb4 cant alone.
kevinjt131.00
      01-09-2018, 07:31 PM   #230
SeanWRT
SeanWRT's Avatar
2255
Drives: E90 M3 & F87 M2
Originally Posted by Twisted Tuning View Post
i don't think its been two years. More like a year this month. I think first posts about his kit were made last January. but i could have missed a post.
What specifically would you like to know?
Can't really give a date of completion as the speed at which they send logs are what dictates that. But the kits have no fitment issues that i have seen except for a t needing to be made for DCT fitment which Jeff has already handled. RHD cars are currently unconfirmed fitment. Scans were done of the locations, but no physical fit tests were completed on those yet.
But i will be sure to post results and etc. when things complete. but there are out there.
Thanks, Justin. Interested to know the builds (including different EFR variants) of the cars that's being tuned and power goals of them.
PS2 needs some competition. Great to have you guys take on the job!
Lemania 2320
      01-09-2018, 08:52 PM   #231
harkes
harkes's Avatar
China
647
Drives: M135i, NSX and AE86
Sorry, let me be a bit more clear. For stock turbo power ranges there is no need to go one step colder to the 97506's. Those plugs are one step colder than the common upgrades that we use on the N54 (yes, i know, different engine) which i have personally run up beyond 700whp with no issues. The plug we use on the N54 as upgrades over stock are 95770. The 97506's are 1 step colder than those.
Infact, i distinctly remembering a few times where i had N55 customer car run and log significantly better on the 95770 plug than on the 97506 plug. So that's another reason i don't really recommend going to a colder plug for stock turbo power. hell even PS2 type power levels.
However, you can pick whichever plug you wish to use and try them out. But for gaps, i try to never recommend a smaller gap than .022
When it comes to plug gaps, realistically you want to run the largest gap possible for each respective setup where spark blowout and corrections are minimal to none. Why? better combustion and larger spark front to ignite the mixture. Albeit, i do know the ignition systems on these cars are not the greatest, so people have become accustomed to small gaps. This platform runs some of the smallest gaps I've seen. as i tune on several other platforms. I have a 800+whp twin turbo and nitrous car sitting in my garage with a plug gap of .030 for reference. no issues.
I'm not saying PTF is wrong by anymeans, we just seem to have differing opinions on the matters.
Hope this helps.
I can fully support this. Been running factory BOSCH ZR5TPP33S at factory 0.03 gap for aound 30000km maxing out the PS2 on methanol - NO ISSUES!
The whole spark plug thing is over-hyped in my opinion!
My proof that the 97506 are not worth the money
http://f30.bimmerpost.com/forums/sho....php?t=1434415
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      01-09-2018, 08:55 PM   #232
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
27 mins! jeepers. Time to be on the lookout for a trickle charger
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current
      01-10-2018, 04:48 AM   #233
ceedawg
ceedawg's Avatar
420
Drives: 2k15 335i xdrive MSport 6spd
Originally Posted by Insane435 View Post
This thread was extremely helpful in deciding between the 3 turbo options we have: http://www.n54tech.com/forums/showthread.php?t=50451
IMO i would never mess with a turbo that will have fitment issues, especially on the x-drive cars. That eliminates the Speedtech. The big boost is way too much money, although there may have been a price drop on one of their models. That leaves the classis PS2 option. IMO this guy is right. Why not set your goals at 450-500wheel? I cant imagine the PS2 will fail when you are running the boost levels to achieve those goals. If you are building a fun street car, I would say the PS2 is the way to go. Plus its a bolt on part!
Sorry to hijack,It will make power but you will be beating up your motor making it with PS2. You need to run alot of boost to make power. Pro is the fact that everything looks stock.So if you have a warranty in effect that's the main advantage I see. End price plus core charge I've seen members quote about 4k to $4200.00
      01-10-2018, 05:36 AM   #234
WaqasRiyami
Oman
45
To flash just unplug the JB4 from the OBDII port while flashing and plug it back in when done. No other maps changes or setting changes are required.
Right now since i am in Stage 0 - i went back to Map 5
But when i flash the BEF , i am not sure what the processes will be or which map should i use , Maybe @Twisted Tuning can answer this question ?
kevinjt131.00
      01-10-2018, 05:39 AM   #235
WaqasRiyami
Oman
45
Since it's a one time long flash only , i didn't want to waste money and buy a Charger.
that's why i used my other care to keep the BMW on while flashing.
      01-10-2018, 11:42 AM   #236
yoandry
yoandry's Avatar
Drives: 13 F30 335i & JGC
Send a message via AIM to yoandry Send a message via MSN to yoandry
With stock turbo you will have to push more boost to archive the same power on ps2 with less boost. So, who you think is beating more the engine?
PS2+ WMI + MHD Bef+JB4, VRSF DP, CP, FMIC Race 6, AFE Mtum Intake, MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-interior trim, MP-Alcantara Steering Wheels W/race display, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats.
      01-10-2018, 11:51 AM   #237
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
You do know that you run less boost to make the same power as stock turbo that needs to run much higher boost right?
Not to mention you also hold MUCH more power top end.
On pump gas (91 and 93) you can make 400-450whp easily, where on stock turbo you will need to run meth/e85 and not to mention, you're also maxing out the stock turbo, which is not safe at all.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3
GatorF30339.50
Insane435198.00
FSociety2997.00
      01-10-2018, 01:15 PM   #238
Insane435
Insane435's Avatar
Drives: 435ix M Sport EWG
Hows your PS2 setup treating you? Still on pump? Any new dyno numbers?
2014 EBII 435ix - Armytrix Catback, Evolution Racewerks Downpipe - Chargepipe - Intercooler, Bootmod3, NGK 97506's, AFE Dry Filter, KW V1, Forgestar F14 19s, Potenza S-04's, M Performance Brakes, PowerStop Track Day Pads
2011 BSM 328ix
IG: @f32_rmacher
      01-10-2018, 01:21 PM   #239
GatorF30
Drives: EBII F30
Sent an email to MHD...but really curious to hear if they have any plug recommendations other than stock. Looking at the logs I've pulled thus far, it does not appear to have any timing issues. But that may change as the beta program evolves and the boost gets turned up.
      01-10-2018, 03:32 PM   #240
zole2112
Modder of everything I own
zole2112's Avatar
86
Drives: 2013 335i Xdrive
I agree with you and am very wary about fitment in my xdrive. I contacted Speedtech about that and I received this email from Speedtech on 12/29, looking forward to an update from them soon...
"The F chassis 8374 kit will fit on xdrive, but we need to verify waterpump hose routing for that specific subframe, due to tight clearances with the much larger turbo. We have that exact kit going on that exact car here in the next 3 weeks or so. After that we should be good to go for that configuration. I'll get back to you after that one is up and running."
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stage 2 LPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & JB4 BEF, Summer 2019: Speedtech BW8374, Trebila Tune, PI
      01-10-2018, 03:38 PM   #241
MHD Tuning
MHD Tuning's Avatar
Drives: M2 # M3 # M135i # 340i
Originally Posted by lukeiswright View Post
Well if you guys decide to make it N20 compatible you have my money and a lot of other's as well. Seems like the JB4 is somewhat unsafe for the N20 and everyone is slowly switching to Bootmod3, but they basically have a monopoly on the N20 flash tuning market and their product is more expensive than yours. Just sayin'
N20 is definitely on our radar.
Originally Posted by 135iDCT View Post
Any plans to release a web version of MHD flasher? so no need to buy android device
or IOS App?
No sorry. It's hard to beat the convenience of a mobile device, ajust a flash option and reflash, log on the go etc.
[QUOTE=ABPReader;22616245]Can't wait to read some feedbacks and to pull the trigger later this year ! If you some people have tablets to recommend that would great
MHD Tuning Do you have something planned for the $50 Digiland 7" at best buy is enough. The choice depends more on your taste.
How could we resist the v8
Originally Posted by mbanks21 View Post
Any update on using jb4 to BEF mhd?
Terry (BMS) started to work on his maps. Twisted too.
Originally Posted by JSiri335I View Post
Stage 1 on a completely my stock 335i worth it? Lol
Of course!
GatorF30339.50
mbanks21765.50
      01-10-2018, 04:13 PM   #242
MHD Tuning
MHD Tuning's Avatar
Originally Posted by Mountain_Commando View Post
98 octane here. I'm licking my chops!
Reminder: 98ron is not 98 aki. So pls use the 93oct / 98ron variants.
I’m between this and a JB4...the only thing I don’t like is lack of resale-ability compared to the JB4
Try to ask you this: why is the JB4 maker currently developing flash maps to "complement" the jb4?
Originally Posted by Rayzor View Post
Hi, what would be the best file for me to purchase, i have a f30 335i PWG with a catless DP and ER Chargepipe.
You don't purchase a file, but you purchase a license to use a set of maps, including futures updates. In your case, the Stage 2 pack. Which also include stage2+, if you add a fmic you'll change map for free to 2+.
Will there be anything in terms of resalability like BM3 offers?
It may come, but not at the current price point.
Maybe its been covered, but does the "full unlock" give you the same abilities as an in person unlock like you need with BM3? I know BM3 will be offering remote unlock but this comes with less abilities.
The unlock is the file signature check. The same hack used to be injected by opening he DME. Now we can inject it directly through OBD. The rest is the same.
Not too sure for Dinan units. You can try but what is the point of keeping it?
flash, mhd, tune
