06-30-2012, 05:58 PM | #309 | |
Rep 1,879
Drives: 2012 F30 328i
But, like you said, it most likely wont work without comfort access
Note: Many PM me for links to the software needed to code. Please note that I do not have download links to this software. Your best bet is using the search function in the coding thread |
06-30-2012, 10:19 PM | #310 | |
Rep 1,892
The work is in getting the cable purchased/built and then getting/installing/setting up the software. After it's all setup on the PC, coding is just a few minute process, thanks to the F10 guys and svache. Taking money for doing some coding implies taking responsibility if something goes wrong; that's not something I think most people would be willing to do. |
06-30-2012, 10:37 PM | #311 | |
Rep 1,892
Note that depending on the date your car was built, the KOMFORTSCHLIESSUNG_FB needs to be set to atkiv (as shown in the cheat sheet), but the werte value will be set to 00, not 01. My 328i was built in April and I ran across that. I was going to set it to 01 (as the cheat sheet shows), but decided that the software was probably right and I left it alone (changed to 00). I've seen others reporting the same thing. Did you force the wetre value to 01? If so, try setting aktiv again and werte to 00 and see if that helps. I didn't have to change the KOMFORTSCHLIESSUNG_PA value and that werte value was 0 also. Also, you changed the ASP_...KOMFORTSCHLIESSUNG status to aktiv/01 too, right? Good luck! |
07-01-2012, 01:26 AM | #312 | |
Rep 1,879
I'm willing to code for people, to help them out, but I can't take that kind of responsibility. That's why I'm offering it for free, the risks are always there and it is up to the car owner if he/she wants to have that risk Regarding the KOMFORTSCHLIESSUNG_FB and werte thing.. I just checked and you're right, nicht_aktiv = 01 and aktiv = 00. I should change this in the cheat sheet
07-01-2012, 03:49 PM | #313 |
Rep 18
Thanks FROGMAN and SVACHE that did work. I also tried to enable windows going up when closing the door but it does not work. There sure is a lot to investigate. Have a great Sunday!
07-01-2012, 05:30 PM | #314 |
Rep 226
Is there a way on the f10 to code the fog lights to stay on when the headlights are on? So if i turn my headlights on and the fog lights are on, that the next time I turn the lights on the fogs are on?
07-01-2012, 05:40 PM | #315 |
Rep 1,879
Check your pm
07-01-2012, 07:35 PM | #316 |
Rep 1,044
07-02-2012, 09:36 PM | #318 | |
Rep 1,892
That all may be moot as the torrent psdzdata files are an older version (46.1) compared to the rapidshare ones (46.3). I don't know if that makes a difference or not. I'm using the ones from rapidshare and they work fine on my F30. |
07-03-2012, 08:27 PM | #319 | |
Rep 1,044
I very much want to use the Esys and pszdata files that svache has been so successful with, so it was worth it to me. Let me ask this question to F30 coders: if I were to zip all the RapidShare files together into a single archive, create a torrent file that I upload here and seed the torrent for a couple of days, would that help others? Are there others out there who would help me seed it? I'm willing to seed it for a week or so, but after that, I can't afford the bandwidth. |
07-05-2012, 09:49 AM | #320 | |
Rep 34
I also download and installed the torrent version. Now realizing the data files in it are an older version. Anyone know if 46.1 should work fine with 2012 F30, or do I need to download the 46.3 version from RapidShare? Still waiting for delivery of my car, so can't test it yet.
Thanks, Erik Quote:
07-05-2012, 10:39 AM | #321 |
Rep 13
hi
hello f30 fans...
i have a new one f30 320 d Sport Edition... But i have a lot of questions... 1. its possible to read the FailureMemory from Car with the enet cable? 2. its possible to change the vMax 3. when i switch of the Auto Start STop function the car shows a failuremessage in Display with Car with less power, drive carfully... where is the trick to became no error Message... 4. its possible to coding the bmw aps function ? 6NR I have navi prof with bluetooth and telephone.... & connected drive etc... I hope my english is okay THX a LOT for your time... marcell from Germany Last edited by mmanes1; 07-05-2012 at 10:47 AM.. |
07-05-2012, 09:01 PM | #324 |
Rep 802
Hi guys ...
I'm a bit stuck on the software installation. Following the steps in the PDF, step 4 states: 04) Copy "est" folder from "\\E-sys 3.18.4\est" to "C:\ESysData\e-sys est" I have the "est" folder ... but I do not see a folder named "e-sys est" in C:\ESysData to copy the folder to? Am I suppose to create this folder? or am I supposed to rename the "est" folder to "e-sys est"? See file hierachy screenshot below? Any help would be appreciated - want to ensure I'm doing this correctly.
07-05-2012, 09:37 PM | #325 |
Rep 18
It is sort of a typo it should read C:\ESysData\EST make sure in the EST folder that you have an EST File that is named Cde Away.est Sorry I am responding from my desktop and all my files are on my laptop so no screenshots. But the folder you are showing should have the EST folder in it.
07-05-2012, 09:41 PM | #326 |
Rep 18
Also just to let everyone know I have coded using a Netbook with a 1.6 gHz processor and 1.5G RAM running Windows 7 and also a Netbook with a 1.6gHz processor and 2G RAM running Windows 8 preview.
07-05-2012, 09:47 PM | #327 |
Rep 18
@ martinf79 when you finally get E-sys up and running go to "options" drop down box to settings and then tab to EST. Once there browse for Code Away.est where you put it. Should be Whatever drive you have it on I'll use x as the example X:\ESysData\EST\Code Away.est I also recommend in the same settings box going to "Program" and uping the RAM in increments of 512MB at least to 1024. E-Sys will need to restart after you bump that up.
07-05-2012, 10:02 PM | #329 | |
Rep 802
07-05-2012, 10:04 PM | #330 | |
Rep 802
06) Copy the contents of the "C:\ESysData\psdzdata\swe" folder into the "C:\ESysData\SWE" folder. Can I delete the files in "C:\ESysData\psdzdata\swe" once I move them. Files are about 15GB and running on an ultrabook (120GB SSD), so don't want to use up more space if I don't need to. Can you please let me know. Also - can I actually run all of the folders off of an extneral drive as opposed to my C: drive?
