03-11-2019, 05:27 PM | #287 |
Rep 4
Can I download CarPlay from the ConnectedDrive Store?
I am looking to purchase a pre owned 2018 BMW X3. The car unfortunately does not have CarPlay pre-installed.
Looking at this thread, people are installing CarPlay via coding. I am a noob to BMWs and how this coding works so want to prefer installing via the BMW recommended ConnectedDrive process. Would I be able to download CarPlay from the BMW ConnectedDrive store? The preowned 2018 BMW X3 has navigation with the big touch screen display on the center dash. My decision to buy the car depends on whether it has carplay or not, so wanna make sure I understand the compatibility before buying. |
03-12-2019, 05:30 AM | #288 | |
Rep 6
Out of interest, is the only difference between the standard and pro nav units on these cars then that the pro nav has the wider screen fitted? If so, is it possible to buy and fit the wider screen and is the touch screen version of the wider screen compatible (I've seen a lot of conflicting info about upgrading the screen saying that you have to get the non touchscreen version to get it to work)? |
03-15-2019, 02:21 PM | #289 |
Rep 1,101
My 2018 car has just gone into BMW for a software update (engine - 440i). It had carplay installed from wibbles. Unfortunately the car came back with non-functioning Navigation and no carplay. The car has been back to BMW for two days and they cannot get the Nav working. What gives?
03-15-2019, 05:17 PM | #290 | |
Rep 468
Did you also have the lifetime Nav FSC code flashed? |
03-16-2019, 05:52 AM | #291 | |
Rep 1,101
Now the Nav just shows loading and they can't sort it... I feel that they may end up replacing the HU. Perhaps they haven't got a clue what they are up to... |
03-16-2019, 09:59 AM | #292 | |
Coding ECU's remotely
445
Rep 1,176
It can be sorted easily, the headunit does not need to be replaced.
Author of Car Connector - remote ICOM & ENET tool - Built in VPN for easy coding and remote diagnostics
Car Connector on YouTube |
03-18-2019, 05:25 PM | #294 |
Rep 1,894
03-20-2019, 02:54 PM | #295 |
Rep 14
Bimmerpost friends - forgive me. I've been reading and re-reading this post and still am a little unsure of what to do re: CarPlay.
Looking at picking up a 2016 F31 (1/16 build date). Car is an odd spec (has track package, but not PDC or Backup camera). S609A Nav System - S6NHA Hands Free with USB So: I can code this for full CarPlay if I add the antenna? Is there anyone in the US that can help with this? Thank you so much for the support! Matt |
04-08-2019, 03:39 AM | #297 |
Rep 1
Hi,
I am new in this forum and would like support. Father has bought X6 (20180 model, received it a month ago) which has navi but surprisingly no airplay option (only mirrorlink for android). Is it possible to do this USB coding for this version? Also does it require wifi antenna? |
04-11-2019, 01:40 PM | #298 |
Rep 4
I have a 2018 330e with a 6.5 inch screen that has NBT Evo ID6. I have been given conflicting advice on what's needed to enable CarPlay but ultimately it seems that you need nav.
I can install wifi if needed, don't care about touch screen, but not interested in a $2500 project to upgrade the nav. But as far as I can tell, CarPlay doesn't need nav on other cars so I'm wondering if its truly needed on BMW also. Can someone explain why nav is required for CarPlay? |
04-11-2019, 01:56 PM | #299 | |
Rep 31
Fortunately it wasn't a deal breaker for me, and thanks to EHB I can still do all I need via the iDrive.
CCR
Current: 2018 435d M Sport+ in MG (lightly mapped!) Previous: E92 330d Coupe, E46 320d Coupe |
04-13-2019, 07:14 AM | #300 |
Rep 4
Hi everyone. First post here. Looking to find someone to get my FSC codes for me for car play full screen mode please.
X3 2018 G01 NBTevo_018184I genuine car play installed can anyone here do this for me and send me the files for USB install please? Thanks |
04-13-2019, 10:51 AM | #301 | |
Rep 8
https://cgi.ebay.co.uk/ws/eBayISAPI....=2437953436015 I had to buy a cable for £9.95 also off eBay to use with my laptop as the version in my Nov 18 car was too new to work with a USB. The seller was very helpful as it was my first time doing anything like this. |
04-13-2019, 01:52 PM | #302 | |
Rep 4
04-13-2019, 02:07 PM | #303 |
Rep 8
04-13-2019, 02:39 PM | #305 | |
Rep 4
Curious about the lead you mentioned. What set up did you install it on? I was under the impression the USB method was fine except if you had letter evo P onwards? |
04-13-2019, 03:26 PM | #307 |
Rep 4
I managed to get him to accept PayPal direct while eBay is being weird, so literally just done this now. Worked via USB method (I'm on evo O) and took literally 2 mins to do. Looks great. Thanks for your help my friend.
