BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > "9 Colour Ambient" aliexpress kit DIY & Coding
proTUNING Freaks
      04-28-2024, 12:07 AM   #23
BillNguyen
BillNguyen's Avatar
Drives: F83 M4
how did you attach the the light around the radio
      04-28-2024, 10:54 AM   #24
fortythirtyfive
Drives: 435i MS
I just dropped the light strip into the recess, it holds on it's own once bent but I knew as soon as summer arrived things would begin to start flexing so I stuck some butyl in spots to make sure it didn't shift.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru)
      04-28-2024, 09:12 PM   #25
BillNguyen
BillNguyen's Avatar
Drives: F83 M4
Also for this strip did you use double side tape
      05-01-2024, 07:54 PM   #26
fortythirtyfive
Drives: 435i MS
Something like that will work yeah, it will need to be the real thin transfer stuff though not foam backed, otherwise it'll squash and damage the strip. I originally used butyl to hold it in place, that way I could stretch it nice and thin but you'll need to clean it off the white diffuser part if you get any on it so I'd probably just recommend double sided tape.
2015 435i - 401whp
