07-11-2018, 10:50 PM | #1 |
Rep 553
PWG N55 vs N54 boost control setup
This may be a dumb question but I can't find the answer anywhere. I just came from the N54 world which of course uses vacuum canisters etc for wastegate control. How does this different from the pneumatic/vacuum wastegate N55, or does it? I haven't seen a canister on the N55, and the N54 doesn't have control issues that some have with the PWG N55, so something has to be different. Anyone know? Thanks.
07-12-2018, 12:48 AM | #2 | |
Rep 504
N55 vacuum canister is in the valve cover. canisters are not for boost control, they are just vacuum accumulators. What control issues does N55 have which does not have N54?
07-12-2018, 10:13 AM | #3 |
Rep 553
Interesting, no wonder I couldn't find it. I understand they're not directly responsible for control but they are part of the system. Some people with tuned PWG N55s have issues with holding boost target and fluctuating boost. N54 has no such issues, so I was wondering what the difference is.
07-12-2018, 10:33 AM | #4 | |
Rep 504
07-12-2018, 06:13 PM | #5 |
Rep 1,127
Electronic waste gate is just a motor opening and closing the waste gate. It's just faster and more adjustable than using vacuum based control strategies.
07-14-2018, 04:27 AM | #7 | |
Rep 1,693
If you're talking about the inability to make much boost at high RPM, that's simply because the turbo is tiny. The EWG turbo has a bigger compressor wheel which helps it make a little more boost at high RPM. |
cookiesowns587.00 |
07-14-2018, 01:08 PM | #8 |
Rep 504
thats right, just its not “a little more” its about 300mbar or ~15% more. about overboosts - people forget one thing, ecu controls boost not with wg only but with throttle also. throttle is way faster method to kill unwanted boost than wg.one more thing - in ewg case you can see wgdc% up to 100% and up to 90% at high rpm. in pwg you will see max ~80% in spool up (while its 100.0% in pwg case) and ~70% max at high rpms. check mhd ewg/pwg stage2/2+ logs and you’ll see. not sure why is it so, believe ecu control strategy is different ewg vs pwg.
cookiesowns587.00 |
07-15-2018, 10:57 PM | #9 | |||
587
Rep 898
The WG Pos table documents this quite accurately. I've experimented with tricking this table a teeny bit to try and have dme target more duty cycle on the pressure converter, and it worked.. kind of. Got more boost, but I didn't want to have trickery showing on logs so avoided doing this on stock turbo... Stock turbo becomes a heat pump quite quick anyways so what's the point. Quote:
Most N54 guys don't tune on PID purely but rather wg commanded... which is not bad as you still have some PD control. Unfortunately it's a short cut... and F series N55 don't have this luxury. Quote:
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2023 X5 45e Frozen Marina Bay Blue
07-16-2018, 03:03 AM | #10 | |
Rep 504
07-16-2018, 03:23 PM | #11 | |
587
Rep 898
no, not talking about compressor power map. There are many tables that allows you to control spool WGDC, even based on eco/dyn/sport maps I'm spooling at PS2 at 17psi by 3300rpm using about 83-85% WGDC. There's about 2-5 tables that you need access to in order to do this. I unfortunately don't know the labels on N55 DAMOS.. since I mostly do custom tuning for friends on BM3.
07-18-2018, 12:26 PM | #12 | |
Rep 504
07-18-2021, 02:32 PM | #13 |
Rep 69
Bringing this back from the dead. Anyone have an answer? I'm seeing 84% wgdc on spool up for a PS2 PWG N55. Long ago I figured out how to get 95%, but can't remember how. I'm hoping someone will share.
I expect there is a table not defined that provides a spool WGDC max value. I think I can trick it by adjusting the WG Pos - fur Vorsteuerung table to be 100% for everything over 80, but am worried that would cause unexpected issues somewhere else. |
07-19-2021, 03:57 AM | #14 | |
Rep 2,357
(A Dane in China) |
08-13-2021, 10:43 PM | #15 | |
Rep 69
E-n55 PS2 |
08-16-2021, 01:29 AM | #16 | |
Rep 2,357
OTS PS2 is running ~70% during spool https://datazap.me/u/harkes/ots-ps2-...0&data=3-17-23
(A Dane in China) |
