07-16-2018, 07:02 AM | #1 |
Rep 279
liqui moly oil
Hey guys,
I'm debating which oil to stick with try out the liquimoly leichtlauf high tech or the molygen (green) for f30 n55 Thanks for the input |
07-16-2018, 03:48 PM | #2 |
Rep 799
I use the Leichtlauf High Tech
07-21-2018, 09:27 PM | #3 |
Rep 16,079
Molygen. If your car is old enough that you're doing your own changes it's old enough for gasket leaks to develop, which are easily traced with Molygen.
07-22-2018, 09:42 AM | #5 | |
Rep 10,351
"Drive more, worry less. "
07-22-2018, 10:57 PM | #6 |
Rep 279
08-06-2018, 03:32 PM | #7 |
¯\_(ツ)_/¯
945
Rep 1,762
My first oil change was with Molygen. Going to send it in to Blackstone for testing next oil change.
08-20-2018, 02:01 AM | #11 |
Rep 10
Going to do my first liqui moly oil change tomorrow we will see what the difference is!
08-20-2018, 09:16 AM | #12 |
Rep 3,211
08-20-2018, 12:54 PM | #13 |
Rep 5,457
Drives: F30
Where are y'all getting the Liqui Moly?
Might try some on my next change coming up at 60k... Currently using M1 0w40. Live in NorCal. 2014 N26 motor. Which Liqui Moly (specifically) would you guys recommend for me? |
08-20-2018, 02:00 PM | #14 |
Rep 479
Just went to the Molly side today! I have a 3 hour road trip tomorrow so we will see what my fuel usage is. Last trip to the same spot I averaged 34mpg on BMW dealer oil.
08-20-2018, 06:26 PM | #16 |
Rep 864
Wow -- You Guys Are Good
I have never changed my oil and really noticed a difference outside changing the viscosity of the oil - 5W-30 to 5W-40 noise reduction / turbo spool.
. If the oil is really better or worse for the car -- I guess an oil analysis over a multiple oil changes would show the oil's merit. . |
08-20-2018, 06:55 PM | #17 | |
Rep 5,457
Drives: F30
Im running 40 weight right now (M1) and trying to decide if I should go with Liqui Moly 30 or 40 for my next oil change... What are N20/N26 guys using, appreciate any responses. |
08-21-2018, 07:07 AM | #18 |
Rep 16,079
08-21-2018, 11:20 AM | #19 |
Rep 5,088
My local indy used to use Special Tec LL 5W30 LiquiMoly but has since changed to Total. My old bimmer had a couple oil change with that oil and it worked ok for OCI 6-7k miles.
10-09-2018, 11:42 PM | #20 |
Rep 279
I just poured in the liqui moly molygen (green bottle)
I figure in the long run I could just use a blacklight to find any oil leaks or what not, catch em before it becomes major |
10-11-2018, 02:35 PM | #22 |
¯\_(ツ)_/¯
945
Rep 1,762
Oil change is due. Will try to get it done in the next week or two then I'll send it in to get tested.
