08-09-2018, 01:55 PM | #4 |
Rep 322
You can use the f32 bumper if you also change to the 4 series headlights.
08-10-2018, 03:50 AM | #5 |
Rep 864
I like that. However i would have thought the bonnet and side fenders would also need replacing. Similar to the m3 as it has slightly different headlight design and so all the panels that meet the headlights need to be changed
08-11-2018, 12:32 AM | #6 | |
Rep 322
Here is the conversion : May be the only one. My BMW "F37" https://f30.bimmerpost.com/forums/sh....php?t=1330524 |
08-11-2018, 04:43 AM | #7 | |
Rep 864
Im curious if the mounting points line up so its a easy swap. Or im wondering it requires extra bits and bobs from the f32 to mount If this just needs headlights then this is no different to a m3 style bumper upgrade. Headlights being the only additional cost |
08-16-2018, 02:51 AM | #9 |
Rep 864
right so real OEM states that the part numbers for the hood on a F30, F32 and F36 is the same #41007290944. Which is great
However part numbers for the side fenders are different for F30, F32 and F36. Even between the f32 and F36 its a different part number. I would have though they would be the same between a f32 and a f36 at least That guy doesn't mention changing the side fenders. im skeptical. |
08-18-2018, 10:54 PM | #12 |
Rep 864
Hmmm if thats the case its not a simple job and just got a lot expensive.
So the one guy says welding and another guy says the opposite and they both have done the same f32 retrofit. |
08-18-2018, 11:32 PM | #13 | |
Rep 322
As for me I'm sold on this one. My plan is to use: F32 headlights F32 bumper F80 fenders (already figured out how to line up the fender to bumper) F30 hood. I've found custom 2" flares for the rear and I'm already working on a custom rear bumper. So at the end it's a widebody f30 but not an f80 clone. |
08-19-2018, 02:14 AM | #14 | |
Rep 864
Keep us posted how you make the side fenders work. The fenders is the last piece of the puzzle. |
awmenard142.00 |
09-28-2018, 04:31 PM | #15 |
Big Turbo Boys N Girls
327
Rep 579
Simply put the 4 series is a wider car than 3 series!
You will need fenders, hood, lights grills, bumper and possibly the radiator support to align everything up. If you want that look get the new M3 rep bumpers they have with wider side vents. Looks close to it and fits well.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
09-29-2018, 07:11 AM | #16 | |
Rep 864
05-31-2019, 03:36 AM | #19 |
Rep 310
https://www.ebay.com/itm/MT4-Front-B...sAAOSwti5cdKZ7
You’re welcome. Here u guys go.. this retains the f30 headlights. |
05-31-2019, 10:21 AM | #20 | |
Rep 8
05-31-2019, 10:23 AM | #21 |
A family of bimmers
2745
Rep 7,741
bmw thought youd like the look too and created the f36...
07-15-2019, 11:39 PM | #22 | |
Rep 90
Drives: 2016 F31 Msport/Track handling
2018 S213 AMG E63S Estate: Diamond White - Money-pit/Garage Queen
2004 CL9 Acura TSX 6-speed: Satin Silver - Peak JDM 2018 BEV2 Chevy Bolt: Nightfall Gray - Daily driver |
