08-03-2018, 07:11 AM | #596 |
Rep 40,768
PM's sent.
08-03-2018, 02:24 PM | #598 |
Rep 40,768
08-07-2018, 03:02 PM | #599 |
Rep 87
hi guys. do i understand it right, lite is for coding and full one for flashing ie traction control, fuel pump etc etc ? if so co i please have link for full version
i currently have v4.11.20_PSdZData_Lite. do i delete it or just replace with new files from full? |
08-07-2018, 03:17 PM | #600 |
Rep 40,768
Delete psdzdata folder and Replace. PM sent.
08-15-2018, 01:22 PM | #602 | |
Rep 40,768
PM sent.
09-09-2018, 08:39 AM | #603 |
Rep 87
hi guys. thats my setup
- esys 3.28.1 (build 46869) - psdszdata 4.11.20 lite - 2.7.1.135 premium lanuncher when i go into stage where is KIS/SVT target, my i level shipment and i level target are blank. i tried using psdzdata 4.13.11 lite and 4.13.11 full too any clues please? |
09-09-2018, 08:41 AM | #604 | |
Rep 2,302
pcp123427.00 |
09-09-2018, 09:33 AM | #605 | |
Rep 40,768
https://f10.5post.com/forums/showpos...&postcount=330
pcp123427.00 |
09-09-2018, 08:05 PM | #606 |
Rep 87
ok, atzebmw and shawn appreciate fixing my problem. could i ask few questions please?
1. whats the difference between single and complete flash? 2. is shipment = current ? is target = new ? 3. now following steps from shawns quide; KIS/SVT target; shipment and target on my car are the same is that right? because looking at VCM => Master Tab => I-Steps it says F010-13-11-504. do i have to select my current (F010-13-11-504) or do i leave F010-18-07-530 to confirm current setup - esys 3.27.1 build 44813 - psdszdata 4.13.11 - 2.8.2_Build_155 launcher |
09-09-2018, 08:14 PM | #607 | |
Rep 40,768
pcp123427.00 |
09-09-2018, 08:28 PM | #608 |
Rep 87
hi shawn, thats what I mean by saying that my shipment and target is the same. thats after stage 7
https://ibb.co/bUubkU |
09-09-2018, 09:06 PM | #609 | |
Rep 40,768
You should not be using E-Sys Launcher for Flashing. It is needed only for FDL Coding. You should launch E-Sys directly, without Launcher. And why are you connected via Gateway URL, rather than VIN? Are you using an ICOM Interface?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 09-09-2018 at 09:15 PM.. |
pcp123427.00 |
09-10-2018, 04:32 PM | #610 |
Rep 87
its in your step by step quide pal; step 3, Connect via “Connection via Gateway URL".
is vin connection better than gateway? shall i update modules one by one or all of them? if one by one is there an order i must follow ? |
09-10-2018, 10:55 PM | #611 | |
Rep 40,768
https://www.bimmerfest.com/forums/sh...0&postcount=29 The author though used Connection via Gateway URL as for him it was only way his Gateway Module (ZGW) would flash. In any event, as I last wrote, you need to and should be able to change the I-Step shipment. If you cannot, I suggest you bypass E-Sys Launcher and use Connection via VIN, and see if I-Step Shipment opens up. If not, then we need to determine what else can be causing the issue.
09-15-2018, 04:38 PM | #612 |
Rep 87
sorry I was under impression that you wrote it
ok, i followed it and obviously selected connection via vin in order not to repeat update version from-to; was F010-13-11-504 to F010-18-07-530 1. had 18modules to update so I started with ZGW, PDC and JBBF, that took approx 6mins 2. then i updated DSC2, EPS and ICM, that took 7mins 3. FRM module took shy of 5mins 4. FZD module took just over 2mins 5. SZL and EMF just shy of 2mins 6. TBX and ZBE3 in just over 3mins 7. TCB just under 13mins 8. IHKA, two attemps as first one failed, 2x 7mins 9. KOMBI, 6mins 10. CAS - 5.5 mins 11. AMP-tophb - 5mins thats 68.5mins including a fail on IHKA module so far no issues will updates, once I manage to do rest will update the group Last edited by pcp1234; 10-11-2018 at 02:54 PM.. |
09-15-2018, 04:42 PM | #613 | |
Rep 40,768
09-15-2018, 05:25 PM | #614 |
Rep 24
Hi Shawnsheridan, I need your help mate please, I was trying to add code 5A2 for LED headlights retrofit but I was getting this error on E-Sys
"No FP could be generated from FA "". [C002] Not all elements of the FA were found in the FA2FP: SALAPA 5A2 [72]" that's is the error message I was getting but I could easily add 552 for Adaptive LED code with no problem. please advise. cheers |
09-15-2018, 07:27 PM | #615 | |
Rep 40,768
09-16-2018, 06:29 AM | #616 | |
Rep 24
no, its just normal Bi-Xenon i had on my car F06 2014 and already installed the LED Headlight done all the wiring and but won't accept the 5A2 code. i can change it to 552 and also change it back to 522. |
