12-15-2023, 10:39 AM | #1 |
Rep 25
F30 2016 LCI does not see Pendrive for an update
Hello guys.
I just wanted to update my Idrive (nbt evo 4) via USB port. I just have one port which is located in the center. Unfortunately, the car does not see any pendrive (8gb and 32gb does not work). Yes, I did format both USBs to FAT32, even few times. Do you have a solution for me? Greeteings from PL. |
12-17-2023, 07:06 PM | #3 |
Rep 1,754
1. Try this formatter: https://www.sdcard.org/downloads/formatter/
or 2. Did it work before via that USB? Is that USB enabled for data in the code?
12-21-2023, 04:05 PM | #4 | |
Rep 25
2. I don't know, i had never checked it before. |
12-21-2023, 07:41 PM | #5 |
Rep 1,754
If you do not know if your USB works (or even is connected) as a USB port, it may be a good idea to check. Both USB port (if connected) have to be enabled for data etc communications. Search in the forums for "enhanced bluetooth" where they share the codes for enabling USB ports. I would also check first, if your USB port's cable is even connected to your HU.
