BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Blown b58 turbo??
      04-27-2024, 01:02 PM   #1
Dwaynethunk
Drives: f32 440i xdrive
Blown b58 turbo??
Hello I have a 2019 f32 440i xdrive and was on the Highway cruise control at 80mph when the car suddenly started blowing clouds of smoke from the exhaust I noticed in my rear view pulled over and had the car towed. I have only a tu hpfp, catless dp, and stage 2 bm3 tune on the car I believe it to be a blown turbo but would like to hear your opinions
      04-27-2024, 01:03 PM   #2
Dwaynethunk
Forgot to mention when I disconnected my downpipe it was full of oil as well as oil in my throttle body
      04-28-2024, 10:46 AM   #3
sigterm2.0
sigterm2.0's Avatar
Drives: BMW 340i
Without looking at it, it sounds like blown seals...
      04-28-2024, 04:14 PM   #4
B58togo
Drives: M240i
Cooked turbo. Time to buy a DAW.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      04-28-2024, 04:53 PM   #5
lens
lens's Avatar
2080
Drives: 2018 340i xDrive
Check your PCV and replace it first.
If problem persists, then it's the turbo.
      04-30-2024, 05:24 AM   #6
sigterm2.0
sigterm2.0's Avatar
Drives: BMW 340i
Does the ruptured PCV diaphragm cause oil to accumulate in the throttle body?
Hmm... Seems as if it would just cause blow by in the cylinders which could explain a bit of oil in the downpipe that isn't burned off by the exhaust manifold and the turbine housing. But, if it's excessive... It's probably oil in the turbo's center section pushing into the turbine, and burning there due to the heat if the turbine housing itself.
On the intake side of things, I didn't think the PCV is plumbed in such a way as to cause oil to get into the intake manifold. Unless this is this a BMW thing?
...another check on the turbo seals is oil in the charge pipe, but if you're getting it in the throttle body the charge pipe should be a mess. 🤷🏻
...if it's the seals.
      04-30-2024, 08:08 AM   #7
freakystyly
Drives: F22 B58 6MT
https://static.nhtsa.gov/odi/tsbs/20...45282-9999.pdf
Copied from the pdf...
Excessive engine oil in the charged intake tubes or the intercooler on turbocharged engines (can be
misdiagnosed as a defective turbocharger)
One's a 2 or 3 digit repair and one's a 4... I'd look into the cheaper one first, unless you're looking for an excuse to upgrade. Then do both.
Wires1661.50
      05-01-2024, 08:15 PM   #8
sigterm2.0
sigterm2.0's Avatar
Drives: BMW 340i
That's interesting!
Great find! I am certainly surprised by this... Learning new things about this platform every day.
