10-20-2018, 08:24 PM | #1 |
Rep 30
Apex FL-5 Fitment Questions
Hey guys! I've dug through many posts and I couldn't find much on the setup I have in mind. Looking for some tips on fitment so any help would be appreciated especially if you've run a setup similar to this!
I will have adjustable coils, camber plates but I'm not looking to run more than -3 camber. Trying to run 18x9.5 +28 front on 255/40/18 and 18x9.5 +22 in the rears on 275/35/18. Not trying to run square setup because I want the deep profile in the rear. What size spacers will I need? Thanks! |
10-20-2018, 08:30 PM | #2 |
Rep 707
won't work sorry dude. Far too aggressive for the f30 chassis.
19x8.5+30mm 245/40/19, front and 9.5+35mm 265/35/19 rear is pretty much as aggressive as you can go with the f30 without crazy modifications to body. |
10-20-2018, 11:12 PM | #3 |
Rep 30
10-20-2018, 11:31 PM | #4 |
Rep 4,322
it'd be easier if you do 18x9 +30 front and 18x10.5 +40 rear with one of these tire size combinations...
255/40/18 & 285/35/18...OR 245/40/18 & 275/35/18...OR 245/40/18 & 285/35/18 |
10-21-2018, 09:44 AM | #5 |
Rep 707
10-21-2018, 07:28 PM | #7 |
Rep 707
10-21-2018, 07:51 PM | #8 |
Rep 463
Hopefully the owners don't mind me linking these.
https://f30.bimmerpost.com/forums/sh...postcount=1135 https://f30.bimmerpost.com/forums/sh...&postcount=112 https://f30.bimmerpost.com/forums/sh...&postcount=113 |
10-22-2018, 12:35 PM | #9 |
Rep 6,701
Happy to jump in here. The 18x9.5" ET28 and 18x9.5" ET22 is a bit too aggressive for the F30 chassis, and will require serious modifications to your fenders to fit properly. We typically recommend going with our FL-5 18x8.5" ET35 wheels as a square setup for customers looking for a direct fit. Paired with 245/40-18 tires, this is a great direct fitment.
If you are willing to run some negative camber up front, and a fender roll in the rear, you can get the 18x9" ET30 with 245/40-18 tires to fit up front, and the 18x9.5" ET35 with 255/40-18 tires in the rear. Here are some recent pictures from a recent customer running that fitment: -Matt |
elliottl5.50 |
10-24-2018, 12:55 AM | #10 |
Rep 51
I just put on some Apex EC-7's 18x9 et31 with 245/40/18's all around. I'm 100% stock and was able to fit them without any issues. They run very flush against the fenders. In order for you to run the your wheels you'll have to stretch tire and run camber to get them to fit.
daniel.d.tran0.00 |
10-24-2018, 10:47 PM | #11 |
Rep 1,934
10-25-2018, 05:33 PM | #12 |
Rep 6,701
This customer is currently running stock camber with this setup, but is on aftermarket coilovers, so lowering the car will give a touch of natural camber. Very minimal camber is needed to run the 18x9" ET30 up front with a 245 tire. Going with a 255 tire will require additional negative camber to be dialed in.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
Logicoeur989.50 |
10-25-2018, 05:59 PM | #13 | |
Rep 1,934
It's very much like what I have in mind for my own vehicle, but with probably 5mm of added clearance fender to ground (Looking to stay around 25.5"-25.75"). Does the added clearance negate the need for more camber to fit a 255 tire at all? I do plan to attend HPDEs in the future just to give you some more detail as to my use case, as well. If you know the clients FTG measurements in the photos that would be greatly appreciated as well.
07-17-2019, 11:07 AM | #14 | |
Rep 12
Fitment help
02-01-2021, 10:20 AM | #15 |
bt5000
Rep 45
02-01-2021, 10:32 AM | #16 |
Rep 4,322
widest FL-5 setup would be 18x9 ET30 front, 18x10.5 ET40 rear with 255/40/18 & 285/35/18 or 245/40/18 & 275/35/18 if you feel the 1st combo is too beefy and want a slight stretch to tuck the shoulder.
