11-28-2024, 02:04 AM | #1 |
Rep 6
Bmw 440i f32 blind spot ( change line) problem
Hello, I had a blow to the rear left corner of the car where the blind spot module (left) was damaged. I ordered another module with the same number and put it in the car, but the blind spot does not work, as soon as I turn it on, an error appears on the screen and it turns off. Is some coding of the other module required or ?
11-29-2024, 03:11 AM | #2 |
![]() ![]() 458
Rep 1,295
Drives: 2018 F48 X1 xDrive 18D
Maybe needs coding to work. Die you read for error codes? Could say something like «not initialized»
11-29-2024, 07:01 AM | #4 |
![]() ![]() 458
Rep 1,295
Yes, programming data faulty. REcode / Reprogram it, should solve it.
You can recode with E-sys
Retrofits done: 2TB, 235, 313, 430 459, 508, 5DP, 322, 674 , 6CP, 323
Other mods: Central Locking button on both sides, Add extra trunk lights Other info: F48 Fuseguide, CarPlay 6CP - OEM way |
11-29-2024, 10:19 AM | #6 |
![]() ![]() 458
Rep 1,295
Free for your purpose.
11-30-2024, 04:15 AM | #8 |
![]() ![]() 458
Rep 1,295
Coding tab
Connect => Read FA => Activate FA => Read VCM => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE Of you have to inject CAFD first: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on ECU => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE
