07-12-2016, 01:46 PM | #89 |
Rep 8
07-12-2016, 03:42 PM | #90 |
Rep 263
8,8" retrofit is only possible if you have newer radio professional from 7/2014 on (HU Entrynav). Therefore you need the L7 High 8,8 screen.
But this is a different story. This thread is about "BMW Integrated Navigation" retrofit. No clue whether this is compatible with 8,8" and split screen etc. Noone seems to have tried it here... |
07-13-2016, 09:06 AM | #91 |
Rep 8
07-15-2016, 04:58 AM | #92 |
Rep 24
Hello everyone,
I will start by thanking Shawnsheridan and Radair Successfully installed integrated navigation to my 2013 F10. I worked straight away, but without voice. My car have HU_CHAMP2 instead of HU_ENTRY Tried all setting in of MUTE but with with no effect. Then tried to add Ho-Word "NAVI" to but bit confused how to do..... I read the thread on HIFI coding (how to change FA ) and followed it step by step now I am stuck at step 5 I can see HO-wort but was not able to figure out how to add "NAVI". Do i have to press right click on Ho-wort and then click edit to add "NAVI" Secondly do i have to add NAVI in inverted comma's or only NAVI. I attached 2 pictures, first is of the mute which i coded Second is of Ho-Wort...... Please help Thank you GSB Last edited by drguru; 07-15-2016 at 01:46 PM.. Reason: spelling mistake |
07-15-2016, 07:01 AM | #93 | |
Rep 40,668
07-15-2016, 12:00 PM | #94 | |
Rep 24
I successfully added NAVI to Ho-Wort but with no effect still no voice by integrated navigation. suggestions please ? Thank you gsb Last edited by drguru; 07-15-2016 at 01:47 PM.. Reason: spelling mistake |
07-15-2016, 12:05 PM | #95 |
Rep 40,668
What did you do after adding NAVI to FA? By itself, that does nothing. You still need to Load Modified FA, Activate FA, and Code car.
07-15-2016, 12:13 PM | #96 |
Rep 24
Thank you Shawn for the quick response.
I did load FA. last step was write FA FP , but haven't activated after that. i will do it. What coding do i need to do ? thank you GSB Last edited by drguru; 07-15-2016 at 12:18 PM.. |
07-15-2016, 12:18 PM | #97 |
Rep 92
07-15-2016, 12:20 PM | #98 |
Rep 40,668
At a minimum, you need to VO Code your Head Unit (HU_CHAMP, HU_ENTRYNAV, etc.), so start with that.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 07-15-2016 at 01:00 PM.. |
07-15-2016, 12:58 PM | #99 |
Rep 24
Thank you for your lightning response
I coded few options of one by one on HU_champ2, but nothing worked for me till now..... Will try again after a moment and let you know the result. thank you gsb |
07-15-2016, 01:45 PM | #100 | |
Rep 24
I am posting some pics please let me know what to code. i will delete pics later as they take too much space.. i will b highly obliged thank you gsb Last edited by drguru; 07-15-2016 at 02:29 PM.. |
07-15-2016, 01:53 PM | #102 | |
Rep 40,668
VO Code: Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Right-Click on ECU (the ECU itself not the underlying CAFD) => Select CODE. You need to VO Code your Head Unit control unit.
07-15-2016, 06:45 PM | #106 |
Rep 40,668
07-15-2016, 07:54 PM | #108 | |
Rep 40,668
After you added HO-Wort = NAVI to FA, did you write the updated modified FA to car VCM? See the complete VO Coding Process here: E-Sys - VO Coding Guide.pdf: https://mega.nz/#!1xpU2DqY!eVG7F6k0d...dVSDBnKk8Rzg90 We need to be sure that when you VO Coded your Head Unit (HU_CHAMP), HO-Wort = NAVI was in the FA that was activated at the time of VO Coding.
07-16-2016, 01:55 AM | #109 |
Rep 208
07-16-2016, 05:02 AM | #110 | |
Rep 24
Will post the picture which i took after connecting wires... orange--- pin 40 voilet ---- pin 34 white which you can see lose was later connected to pin 10 please correct me if i am wrong. thank you gsb |
Tags |
integrated, navigation |
