02-13-2018, 06:46 PM | #1 |
Rep 765
F30 pre lci halogen to lci full led headlight retrofit
First let me just say I kno there is a lot of info on the board about this and I have been studying and reading for months now but I'm still confused on a few things I'm hoping someone could help me out since now I'm about to build my own wire harness n install. My f30 has halogen headlights and build date is 5-14, I have this PDF but says is only for f30s built from 7-14 and on. Could someone please please PLEASE tell me what would b different. I have been looking on ista and newtis but can't find diffinitive answers also on newtis I can't find the pinouts n wiring diagram for halogen, only xenon and led. My headlights are non adaptive btw and this is the instructions I was gonna follow if someone could again please tell me what would b different from an f30 built 5-14 instead of 7-14 like the PDF says. Thank you!!!
http://f80.bimmerpost.com/forums/att...7&d=1490600365 |
02-13-2018, 06:47 PM | #2 |
Rep 765
Gonna post this in the headlight modification forum too, if that's not allowed or can b linked I apologize I wasn't sure which one this should go into since this is a diy too. Thank you.
02-13-2018, 09:12 PM | #3 |
Rep 5,457
Drives: F30
Honest to goodness... also own a 5.14 produced F30 with halogens. Definitely been trying to figure out the smartest lighting upgrade for a few months now... appreciate people's input on their experiences with improving visibility and brightness from stock halogens.
02-22-2018, 04:36 PM | #4 |
Rep 765
I haven't made the install yet but I kno there are other threads here where ppl went the aftermarket route. I much rather have oem when possible. I still need help on the fem wiring different from pre lci f30 to lci's. Newtis doesn't show lci f30s.
02-23-2018, 03:05 AM | #5 | |
Rep 277
Then you have to look better , here is part the adaptive led connection https://www.newtis.info/tisv2/a/en/f...eft/1VnZ4nMOi3 |
02-23-2018, 02:43 PM | #7 |
Rep 765
When u pick the chassis on say realoem u can pick between f30 and f30 lci so obviously there's a difference in parts and trying to find if there's a difference in the fem wiring.
02-23-2018, 03:08 PM | #8 |
Rep 277
04-17-2018, 05:20 PM | #9 |
Rep 765
https://youtu.be/n_Fpjv-ulaA
Well after a lot of research and a lot of hard work and headache my pre lci f30 to lci full led headlights is complete. Thanks to everyone that helped n no thanks to those that didn’t. If anyone needs help with similar retro let me know. Could even make u a wire harness if needed. Didn’t install level sensors tho I may at some point. Coded out the vertical aim error n couldn’t b happier. Things retrofitted everything oem: alarm (with fzd with sensors), 6wa, nbt, touch controller n touch ecu, LCI LED Headlights, auto dim rearview mirror with garage door opener and compas and alarm led. Retrofits I have parts jus waiting to do: pdc, sport steering with heat, tcb (have tcb that came with nbt I retrofitted, and asd (have ecu jus not sure if worth it) Anyone need any help with anything listed feel free to hmu, can’t promise I’ll get back to u same day tho. Last edited by Jhnblckwood; 04-17-2018 at 05:35 PM.. |
04-18-2018, 01:13 PM | #10 |
Rep 2,044
Hi John,
Congrats on the success, it is very cool! I assume you had to run new wires from the headlights to somewhere. Could you tell me about that, pls? Thanks, Murf |
04-18-2018, 03:36 PM | #11 |
Rep 765
Thank you. Yea I ran 3 New wires for each headlight. Power, kcan hi n low. Then I switched two wires on the fem so I could take pin 12 on the headlight connector and moved to pin 8 or 10 I forget off hand but whatever one is the lin. So pin 1 n 2 stay the same, pin 3 is New power line, 8 9 10 is the kcan + n - and lin. The rest of the wires was isolated n tied back.
That may b confusing but any specific questions feel free to msg me. |
04-18-2018, 04:04 PM | #12 |
Rep 2,044
Way to go, John!
I might have to PM you because that was over my head. But I'm doing E-sys now, so come spring (which hasn't gotten here yet), or maybe summer...! Murf |
04-28-2018, 09:54 PM | #14 |
Rep 167
Drives: '18 540i '15 X5 '03 530i
Jhnblckwood;23072449]https://youtu.be/n_Fpjv-ulaA
Things retrofitted everything oem: alarm (with fzd with sensors), 6wa, nbt, touch controller n touch ecu, LCI LED Headlights, auto dim rearview mirror with garage door opener and compas and alarm led. Retrofits I have parts jus waiting to do: pdc, sport steering with heat, tcb (have tcb that came with nbt I retrofitted, and asd (have ecu jus not sure if worth it) Anyone need any help with anything listed feel free to hmu, can’t promise I’ll get back to u same day tho.[/QUOTE] I was researching for ASD coding and ran into your post about alarm. I have 2014 f30, did not come with alarm and had wanting to add. Can you share some info how to add oem alarm system ? Thanks in advance. |
04-28-2018, 10:00 PM | #15 |
Rep 765
Not trying to be a dick but others might not b as nice as me, just use the search function next time before posting. :-p
http://f30.bimmerpost.com/forums/sho...Alarm+retrofit Any questions tho feel free to lmk goodluck. |
04-28-2018, 10:15 PM | #16 |
Rep 765
Like if u have a specific question msg me.
zeroxartworks0.00 |
10-24-2018, 04:45 PM | #17 | |
Rep 7
I am doing the same, retrofitting full led lci to pre lci, but my car is 12/2012. Can you tell me what are the differences you had to do in harness if you compare with the official pdf from bmw upgrade that told for cars 07/14? As I understood the connections on FEM are not the same Thanx, this will help me a lot |
10-25-2018, 03:03 PM | #18 | ||
Rep 765
This is what I followed. I'm pretty sure the wiring is the same, u just have to change the build date on the fem and rem when coding to 7/15. |
10-25-2018, 03:05 PM | #19 | |||
Rep 7
12-27-2018, 02:04 AM | #20 |
Rep 16
Hello,
where did u put the new wires of the kcan in the fem ( i mean in which plug and in which pin ?) and what is the code you did ? Have you added the led headlight option to the vehicle order ? or changed the build date for the fem ? Thanks |
12-27-2018, 05:16 PM | #21 |
Rep 765
Read the first post n the post above. I did add 5A2 to Fa.
12-28-2018, 11:41 AM | #22 |
Rep 16
