07-02-2020, 08:07 PM | #309 |
Rep 3,535
Maybe, my channel is "FaRKle0079" (link in sig). Thanks for the compliments. I'll have more to come as I (or friends) need work done, haha.
07-07-2020, 04:26 PM | #310 |
Mini Cooper, Present F15 Owner
Rep 90
Latest update: 2015 328D Touring. 61,000 miles. I've had it for 6K miles. Changed oil, air + filters. Flushed brakes. Windshield wipers and windshield. Did the EGR recall - it was needed and replaced. No cost. Replaced front & rear Nox sensors. No cost under extended warranty. Replaced giubo & transfer case under recall. No cost.
Today - first day since I brought it back home from the recall, threw a CEL for a P0670 code. I don't have Carly, but my Torque reader says likely Glow Plug Control Module. Have one ordered... I'll be glad when I get all the gremlins shaken out of this otherwise beautiful looking, running wagon! |
haagm58809.50 |
07-07-2020, 04:35 PM | #311 | |
Rep 1,797
Check the wire running right by the Left side engine cover tab by the back of the engine. Is it damaged? It runs to the glow plug control module. Sometimes the wire gets crushed by the engine cover and it can be stripped of the insulation.
haagm58809.50 |
07-07-2020, 04:58 PM | #312 | |
Rep 90
07-08-2020, 08:43 AM | #313 |
Rep 90
Ah, the saga continues. Driving home the CEL was on (for the P0670) but after a couple of minutes, the battery light came on. Not charging...a new battery.
Time to find out what all has to come off the engine before the alternator! |
Enabled1406.00 |
07-08-2020, 09:59 AM | #314 |
Rep 1,797
Well that's suspicious of their work on the battery install......
07-08-2020, 10:15 AM | #315 | |
Rep 90
Starting the car yesterday morning, first time I had started the vehicle after the 280 mile trip home from the dealership and all the recall work and new battery installation, I immediately got the check engine light. Ran Torque and pulled up the P0670 which pointed to the glow plug control module. So if the alternator took a hit during all the work done on it, but we had a new battery for the 280 mile trip home, the battery was probably discharging all the while I was driving home. The first component the cpu probably looks at when starting is the glow plugs (for a start) and if the voltage at that point, yesterday morning, wasn't high enough, I guess that would explain that code it threw. But the engine started fine and I was able to drive it another 25 miles to work without a problem. Only when I started it to return home did I start getting the battery lights. I haven't seen much in this forum on alternator issues but know that when one goes out (and they do, for brushes, etc.) they create all kinds of weird symptoms as the car begins to shut down electrical systems to preserve power. I'm told that the last system that gets shut down are the lights. We'll see what today brings. BMW alternators are a little pricey. The alternator is on top of the engine but at least in my model (2015 328d) it is shrouded by lots of pieces and parts. I've replaced the alternator in my F350 but it's a 2002 and there's very little between the alternator and the mechanic! |
07-08-2020, 11:01 AM | #316 |
Rep 1,797
When it's running, what volts do you see at the post under the hood?
These typically run around 14.4-14.8V with engine running. It does have variable control via the engine computer. Engine off would have to be 12.6-12.7V for a full battery. These alternators haven't been a common item, I'd be questioning it.
07-08-2020, 02:58 PM | #317 | |
Rep 90
For some of the forum's readers, I have no doubt they would troubleshoot the car in their own garage, order the parts, double-check their Bentley manual and dive in. I'm comfortable changing my own oil, filters, tires. Beyond that, I just get myself into deeper trouble. I traded a 2002 Mini Cooper to get this 328D Touring because the Mini was becoming more of an adventure, in terms of reliability. Totally fun to drive but we're way too far from parts and knowledgeable mechanics. I think I may have made a mistake. "This is why we can't have nice things, honey..." We live in the styxx! |
07-08-2020, 04:10 PM | #318 | |
Rep 1,797
How good are you with computers?
07-08-2020, 04:48 PM | #319 |
Rep 90
Really good, although that's a biased opinion. I'd have to say I'm more mechanically inclined. I rebuilt the engine in my first car, a '67 Chevy Impala and that made me cocky about cars. You could slop together an old GM V8 engine and it would still run, fairly well.
The trouble now is that we have become so dependent upon computer diagnostics and the systems are so complicated and wrapped in proprietary code that it's hard to figure these things out correctly. Why? Tell me where you were headed with your question! |
07-13-2020, 09:28 AM | #320 | |
Rep 90
07-15-2020, 01:56 PM | #321 |
Rep 3
Just picked up a 2014 328d with 150k on it. Going to start with all the filters and fluids, go from there. Will be posting pictures soon...
Updates: Ordered Spyder LEDs, matte black grill 😁 |
07-15-2020, 05:10 PM | #322 |
Rep 90
07-16-2020, 09:31 AM | #323 |
Rep 424
07-16-2020, 09:36 AM | #324 |
Rep 424
07-16-2020, 09:52 AM | #325 | |
Rep 90
The car is otherwise in beautiful condition. Interior is pristine, paint is pretty good for a daily driver. I've attended to all the other service interval maintenance - maybe a transmission flush is all that is needed. I bought some spare 18" BMW rims to be ready for snow season and Blizzaks. I'm really planning on enjoying this car in the years to come. I love the torque of the diesel, especially pulling up mountain grades! |
07-21-2020, 12:38 PM | #326 |
Rep 90
The alternator is installed!!!
Old one was definitely shot and not putting out any voltage/charge into the battery. The P0670 "Glow Plug Control Module" error is cleared and I'm about to put the old alternator back into shipping to recoup my $210 core charge. That's more than the last new Ford alternator I put into the F350! They must really want it back! |
haagm58809.50 |
07-21-2020, 01:15 PM | #327 | |
Rep 1,797
07-21-2020, 04:20 PM | #328 | |
Rep 90
It's not a bad job. Next time will go faster! Really appreciate the supportive comments I got from others. I find myself tensing up when I start the car as I wait to see if I'm going to get a clean "no CELs" startup or not. About the same time I bought this car, my wife bought a 2015 MINI Countryman. She hasn't had any trouble, whatsoever and just smirks at me as I reach for my credit card... |
