BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Photo, Video, Media Gallery, Journals > Just installed GTS OLED Style Tail Lights
      02-09-2022, 11:23 AM   #1
SimSimmaF30
SimSimmaF30's Avatar
Drives: F30 340i Msport
Wassup y'all. I just had these installed on my 2018 F30 340i. They look beautiful! Night and day difference vs. stock. If you're on the fence, DO IT!
Shawn.
rcaso26331.00
Cpark1441.50
      02-09-2022, 12:41 PM   #2
MeisterP
MeisterP's Avatar
England
Drives: Z4
2004 Z4  [0.00]
VLAND?
      02-09-2022, 12:42 PM   #3
SimSimmaF30
Originally Posted by MeisterP View Post
VLAND?
Yessir!!
      02-09-2022, 03:15 PM   #4
kalmuklukas
Drives: BMW F10
Shawn.
Looks nice. Where you buy and how much ?
      02-09-2022, 03:18 PM   #5
SimSimmaF30
Shawn.
I got mine from VLAND directly. I do not recommend buying it directly from them. Amazon sells the same exact product … for approx $280.
      02-09-2022, 04:52 PM   #6
dangerus_car
Drives: F30
do you have the amazon link ? thanks
      02-09-2022, 04:54 PM   #7
SimSimmaF30
Yesssuh! Here you go
VLAND OLED Tail Lights Compatible with BMW 3-Series F30 F35 F80 Sedan 2013-2018( Not for 2015 328i F30) with Amber Sequential Turn Signals and Red 3D Dynamic Animation Lighting (Red Clear Styles) https://www.amazon.com/dp/B08RHVDMRM...CX2T17JM7X3S0X
      02-09-2022, 04:58 PM   #8
SimSimmaF30
I see I was mistaken on the price.. 380. My bad!
      02-09-2022, 05:11 PM   #9
dangerus_car
Drives: F30
yes, thanks, i browsed on amazon prior to my post and only found $390, that's why i asked you, maybe if it's $290, i jump in right away
how's the installation and the quality of the light? everything is sealed nice? i m worried about buying an aftermarket light, i am thinking of buying the euro m performance light and that's $400 (or vland version for $290)
my car is also white, so if i buy the GTS, i m thinking of the smoke version, is yours smoke or red? i can't quite make it from the picture
      02-09-2022, 05:27 PM   #10
SimSimmaF30
Great questions!
I had a friend who owns a BMW shop install it for me. He said it was pretty tricky getting everything lined up. I honestly recommend having a professional installer install this unless you're very handy and good with this type of stuff. It even recommends professional installation on the box.
It looks great. I really have no complaints. Fitment I would give it a 10/10 for my install. Funny thing- when I pulled up to his shop, he had an M3 with the same exact lights… but whoever installed it ( wasn't my guy) didn't line it up properly. As a result, it's raised on one end. It's doesn't stick out, but when you run your hands across you can easily feel where it's not lined up properly. That would bother the hell outta me bc I'm hella anal with that type of stuff lol.
I got the smoked one originally but I returned it and got the red ones. The red ones looks very classy. It looks as if it came with the car. It's the lens is a rad bit darker than stock so it almost looks very lightly smoke but it's not. I'm very happy with the red one. The smoked one on a white car screams aftermarket… wouldn't/doesn't blend well. If you don't mind it looks clearly aftermarket, then it's all good! I wanted a almost stock looking finish if that makes sense.
Sorry for this novel but let me know if you have any question.
Shawn
      02-09-2022, 09:38 PM   #11
dangerus_car
Drives: F30
did you get the v1 or v2? i m not sure the difference betweem the 2
      02-10-2022, 01:12 AM   #12
SimSimmaF30
I got the V2. The V2 has 4 blades on the inner lights and the V1 has 5. Also they have a slightly different start up sequence. From what I understand that's the only difference .
      02-10-2022, 12:17 PM   #13
Samir72
Samir72's Avatar
Drives: 340i
V2 also have the brake light across both the inner and outer lights, where on the V1 it was just the outer part. Was one of the big reasons I choose V2’s and much preferred the light over both inner And outer.
The line across the blades give it more of an OEM oled look aswell.
Still makes me smile when I unlock
      02-10-2022, 03:57 PM   #14
SimSimmaF30
Funny you say that. My boy fucked up the install so when I push the brake, the only brake light that comes on is the outer light. We're gonna fix it on Monday. Apparently the directions that come with it is terrible.
I did have a question for you- I read somewhere that you can code the lights so it's always on like daytime running lights. Did you code yours?
      02-10-2022, 04:03 PM   #15
Samir72
Samir72's Avatar
Drives: 340i
[QUOTE=SimSimmaF30;28573325][QUOTE=Samir72;28572423]
Yes you can code the rear lights to run as DRL's via bimmercode and Carly it's a pretty simple one
. I haven't done so myself as either run mine as auto or don't mind just turning side lights which activates the rears.
      02-14-2022, 04:58 PM   #16
SimSimmaF30
[QUOTE=Samir72;28573355][QUOTE=SimSimmaF30;28573325]
Finally got the brake light fix.. looks so good!
      02-16-2022, 01:14 PM   #17
Samir72
Samir72's Avatar
Drives: 340i
Looking good 👏🏽👏🏽👏🏽 V2's look so nice
      09-11-2022, 07:43 AM   #18
tclm90
Drives: BMW F30 335d M Sport
Gents / ladies
Just installed Vland rears on 2015 BMW F30 pre LCI these are the V2's
Indicators - brake lights - reversing light - hazards all work. But the animation sequence on start up does not. What have I missed ? Plugs are in pre LCI connector on the VLand.
Have I made a mistake or is it a case of returning them.
Thanks Tony
      09-12-2022, 03:11 PM   #19
ravenorxs
Drives: BMW '18 440i M-Perf. Edition
Originally Posted by tclm90 View Post
Gents / ladies
Thanks Tony
Is your light dial set to auto? I believe that’s the only setting that will trigger the animation on startup
      12-13-2022, 07:28 AM   #20
karapet85
sergeant
karapet85's Avatar
Armenia
66
Drives: BMW F30 328 xDrive Nimble
Hi tclm90
Have you been able to find the reason for the animation not functioning? I am on the opposite side, wanting to turn off the start up animation.
Got my smoked version installed yesterday. They are good, but IMO red ones will look way better. So thinking about replacing them.
Gents / ladies
Thanks Tony
      12-13-2022, 01:35 PM   #21
Samir72
Samir72's Avatar
Drives: 340i
Originally Posted by karapet85 View Post
Hi tclm90
The start up animation only happens if you leave your lights in auto If you leave it off you won’t have animation on unlock.
Definitely think the red version look better on a mineral grey car.
      12-13-2022, 03:19 PM   #22
karapet85
sergeant
karapet85's Avatar
Armenia
66
Thank you, Samir72
So i guess if code out ( turn off by coding ) welcome lights for taillights, that should work too?
