10-29-2019, 11:10 AM | #1 |
Rep 6
2013 335i M-Sport limp mode issue (i guess)
I recently bought this 2013 335i M-Sport w/ sport automatic ZF8 (61K miles) and I'm new to this Form, I apologize if I'm not in the right thread.
This car had been running super strong (without any issues) until last night coming back from work when the oil temp dropped to around 180 F from ~245 F and cooling fan was blowing like there's no tomorrow and the performance dropped off as well...So I turned it off and then restarted it about 20 mins later, the car ran okay but I feel like it's running a bit sluggish, perhaps more like 90-95% of what it was before. It feels as if the engine is a bit draggy, there is no CEL or any drivetrain malfunction message in the car...please advise! |
10-29-2019, 12:10 PM | #2 |
Rep 1,499
there might be some shadow codes. Scan for trouble codes and report back.
10-29-2019, 12:50 PM | #3 |
Rep 755
check your coolant hoses, my return line cracked a few months ago, started seeing a little smoke from under the hood and temps started to climb a bit. it was the skinny 1/8" hard plastic return line, and has happened to quite a few people.
PSA for high mileage 335's, check your coolant hoses... https://f30.bimmerpost.com/forums/sh....php?t=1547622
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
10-29-2019, 01:52 PM | #4 | |
Rep 7,555
10-29-2019, 04:01 PM | #5 | ||
Rep 755
10-29-2019, 04:24 PM | #6 |
Rep 141
This used to happen every so often when I was using the jb4 piggyback. But turning the car on and off fixed it. If I recall restart was a little rough, but the car returned to normal quickly. Do you have a way to reset adaptations?
10-29-2019, 04:34 PM | #7 |
Rep 6
Yes, my car is not overheating. I already drove like 80 miles today and the temperature is back to normal ~ 245F without any fluctuations...but I think I'm down on power slightly or maybe I'm just paranoid. Could it be a misfire?
10-29-2019, 06:07 PM | #8 | |
Rep 7,555
I assume you dont have any way to read codes, no tuning software, no data logging/monitoring, etc? Hard for us to help with no additional data. A misfire shouldnt really cause or result from those symptoms... |
10-29-2019, 08:09 PM | #9 |
Rep 10,329
The loud fan seems like a telltale sign of a failing electric water pump.
I'm assuming this occurred during normal driving and not aggressive/hard driving.
"Drive more, worry less. "
10-29-2019, 09:03 PM | #10 |
Rep 939
The 2013 m sport is known for the limp mode issue. The loud fan is the part of the issue. No power, fan on high(loud), and glitchy bad acceleration. Like I posted on the other board, my same car had done this for years but I found out what made my car go into limp mode. AC off and in sport + mode. That would eventually cause a limp mode. The code is -1A2108- electrical fan- minor fault . Turning off the car clears it or using MhD will, of course, also clear the code.
10-30-2019, 10:39 AM | #12 |
A family of bimmers
2744
Rep 7,741
I had this happen and it was a fault in the electric cooling fan. That had to be replaced to the tune of $1600 as the fan part is $900.
10-30-2019, 12:53 PM | #13 | |
Rep 1,934
https://www.newtis.info/tisv2/a/en/f...parts/IJDZ6vvr
10-30-2019, 01:25 PM | #14 | |
A family of bimmers
2744
Rep 7,741
10-30-2019, 04:28 PM | #15 | |
Rep 6
12-30-2019, 01:49 PM | #16 |
Rep 8
I am having this issue occasionally as well on 2014 335i base model. I did some search and found out the fan was replaced on some cards several time but the issue reoccurred.
I am thinking it's a software issue rather than the fan itself. Maybe I should just let the dealer to update the software and I will do the fan myself... |
01-01-2020, 01:46 AM | #17 |
Rep 372
Same symptoms happened last week on my 58k mi 2015 335xi - temp gauge ice cold, fan running on high, sluggish acceleration, won't go past 3k rpm.
I'm still under CPO warranty, took it to the dealer and they diagnosed it as a stuck open thermostat. They replaced the thermostat and the skinny coolant hose that runs from the coolant reservoir, so all good now. |
01-02-2020, 02:22 PM | #18 | |
Rep 7,555
01-03-2020, 01:06 AM | #19 | ||
Rep 372
01-04-2020, 07:22 PM | #21 |
Masterchief
352
Rep 1,001
just hope your valvetronic system doesnt fail on you. mine did last month and was 3k for eccentric shaft and servomotor replacement.
based on what iv seen, alot of 2013's and older are encountering this issue regardless of mileage.
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
03-02-2020, 09:47 AM | #22 | |
Rep 1,168
Drives: 2020 M340i
Really annoyed as I have a M340i that's arriving this week and will be ready for pick up next week...Also, my warranty just ended a couple months back on my 335i. Instead of purchasing extended warranty, opted to just buy an entirely new vehicle. |
