01-28-2017, 01:08 AM | #1 |
Rep 953
Max power?
What kind of power can the 328i tranny and n26 handle? Looking into doing a turbo upgrade depending on whether or not the car can handle it without having to build the motor. Thinking around 350-400 whp
2014 328i - FBO/KW v2/VMR v710's IG@F30_Joe
01-28-2017, 04:46 PM | #2 |
Rep 1,739
Check out n54tech.com; generally better technical info on there.
01-28-2017, 10:56 PM | #3 |
Rep 577
With stock internals you can make 330-340lbft of torque. The n26 is practically the same as the n20, just a change in cat. So you can tune to the same heights. The tranny is supposed to be the same as the 335i and they're putting down 600HP so if that's the case we're fine. I was told that our tranny can be coded to run as the M235i tranny.
As I'm sure you know HP is a function of torque and how long you can hold it, so for example 340lbft at 5500rpm will yield 356HP. Not including transmission loss, which is generally accepted to be 15% for a rear wheel drive car. So 400HP at the crank will measure out at about 340HP at the wheel. Anyway my tuner has a customer in Brazil with an n20 putting down 380HP at the wheel. That's on flex fuel (which is like 110octane). With a Built engine he is confident it could put down 500wHP. That's closed deck, 1/2" ARP head studs, forged Pistons & Rods, Upgraded rod bearings, hardened rod bolts, Stage 2 Turbo and a wet shot of Nitrous. |
nemobanks64.50 |
01-28-2017, 11:58 PM | #4 |
Rep 111
Can I find out more information of this tuner? I am looking to upgrade my B48 engine internals and much professional opinion will be extremely helpful. Thank you
01-29-2017, 05:14 AM | #5 | |
Rep 953
01-29-2017, 05:16 PM | #6 |
Rep 577
No 350Hp at the wheels is fine. Even Dinan have Stage 4 tune (which includes a Stage 1 Turbo Upgrade - that's a stock turbine with larger compressor) which gets almost 350HP.
Personally I'm staying at 330lbft and 315HP to the wheels until I get my bottom end done. Then my Stage 2 Turbo will give me 350-380. Wet shot of NO2 to take it over the top. CP Carrillo for the Pistons and H-beam Rods, they also have an option for upgraded Carr rod bolts, which I have gone for. VAC Motorsport for the upgraded Clevite bearings, and ARP head studs. My tuner is Ricardo@ACFPerformance and they can unlock the n20 DME and flash the Bootmod3 patch so you can tune over OBD2. |
01-29-2017, 06:01 PM | #7 | |
Rep 953
01-30-2017, 12:49 PM | #9 |
Rep 577
I just listed all the main things needed. Other than this it's going to be all the normal seals and gaskets. If your engine is pre-2015 I would suggest you do the timing chains and oils pump chains while the engine is apart.
For 500HP you'll need to close the deck. That's because the head is pretty hard to seal up with the sock setup and closing the deck gives more surface area to seal on and also prevents the cylinder walls from moving during the power stroke (which is what prematurely wears the head gasket and leads to it being blown). That means the engine block needs to be machined, which is risky business, since the cylinders are not able to be honed (according to BMW) as the plasma arc spray coating is so thin. According to my research it's anywhere from 0.2mm to 0.4mm thin... so at best you could diamond hone 0.001" or maybe 0.002". Not much at all! When you close the deck (machine the slot and then press in the new support piece) the cylinders can go slightly out of round. If you can't correct it through honing, you will get more blow-by, so I'll be taking a chance on this. My machine shop says they can make the section with a little more tolerance to try limit the effect when it's pressed in. Then hone for the new rings and hope it's enough to get the cylinders into round or at least acceptable. If that doesn't work, we'll then you would need to machine the cylinders for sleeves, and then it's a lot more. You're probably looking at 30-40 hours Labor to pull the engine, dismantle it, send off for machining, reassembly and install back. The guy I would really like to use (Alex at ABR Houston) is too much for me (quoted 7-15k depending on what is done), so I'm pulling everything together myself and will do some of the grunt work myself and get a local BMW tech I know to get it done. Here is my budget. I've already got my Stage 2 Turbo, Downpipe, Exhaust, Intake, Chargepipes, FMIC, Catch can and tune sorted so those are not included. Decking the block $500 Pistons & Rods $1750 Upgraded rod bolts $250 Upgraded rod bearings $350 Upgraded head studs $250 Gaskets $250. Fluids $100. So $3500 plus labor. Goal is to to keep around 5k. If I add the NO2 wet shot it's obviously going to be more. About another $1k with the right controller. |
01-30-2017, 01:43 PM | #10 | |
Rep 953
01-30-2017, 03:59 PM | #11 |
Nemo banks
65
Rep 253
This was Very Informative.
FBO N20, G-Plus Oil Cooler , Injen Cold Air Intake, MST turbo inlet, AFE Charge Pipe, BMS Oil Catch Can, Forged Motorsport Blow of Vavle, Wanger FMIC, Circuit Werkes Catless Downpipe, Full Straight 3inch exhuast. Stage 2 Active Auto Werke.
01-30-2017, 04:06 PM | #12 | |
Nemo banks
65
Rep 253
01-30-2017, 05:36 PM | #13 | ||
Rep 577
I would say at the minimum you need a high flow Downpipe, Stage 1 Turbo and tune. You can look at Dinan's website too to see what they mean by Stage 4. I would definitely do your FMIC and chargepipe. Without the FMIC the added mass flow and higher temps will heat soak your stock unit after 1 pull. Also at 22PSI your stock chargepipe will likely go pop. |
02-08-2017, 07:04 PM | #14 | |
Rep 51
If aiming for more than 400 crank HP, then I'd have to agree that a rebuild would be required to install ARP bolts/studs and forged pistons and possibly rods. Flame ringing the heads is a good idea too, so it provides a better seal between the cylinders and head.
James
Sapphire Black MY13 BMW F30 328i M Sport |
02-08-2017, 08:02 PM | #15 |
Rep 577
Yes 328iMSport 350HP to the wheels on stock internals is possible. That's over 400BHP (crank) though, so not smart.
There is a FBO + Stage 2 turbo n20 in Brazil that put 380HP down to the wheels on flex fuel (about 110 octane). Amazed it didn't go bang. That said I still think knock kills the n20, more so than any other BMW engine. And with the 10:1 CR, high AIT temps you get turning up the boost (especially with a heat soaked stock FMIC) on a stock turbo (which is not efficient at higher PR and mass flow, putting out more heat), the relatively low octane fuels here, and plugs that run hot, detonation is likely. Also higher than expected temps and ring gaps that aren't matched accordingly cause cast Pistons to crack (we've seen a few of those too). The on top of that I'm pretty sure the standard oil isn't good for higher output. I'm going to Motul from now on. the failures I've read about can be attributed somewhat to lubrication (spun bearings, stretched rod bolts - though Rod bolts stretch in the exhaust stroke not power stroke, so that's an interesting one, and seized cam shafts). So worth watching carefully. Anyway I agree that over 400HP at the crank (~335HP at wheels) is not smart, and I'm not going there without Forged Pistons & Rods, upgraded Rod bolts and rod Bearings, head studs and closed deck. It's kinda overkill I know, but then I can throw much much more at it. |
smallba73.00 |
02-08-2017, 08:27 PM | #16 |
Rep 3,211
Your ZF tranny can only handle 400Nm
as been said before you'd need to upgrade many other parts the car hasnt been sourced with parts rated for that power.. yer car would be at greater risk of parts failure If you want 360 hp consider moving up to 340i |
02-08-2017, 08:34 PM | #17 | |
Rep 577
Also no one is saying we should go above that limit. If we can keep the torque at 332lbft and hold it up higher we can get above 350HP. For example: HP = (TORQUE x RPM)/5252 HP = (330 x 6000) / 5252 = 377HP Finally there has been a lot of discussion about this, and from what I've read and heard from a couple BMW techs, the 335 and 328 with the sports automatic transmission actually have the same ZF gearbox, but just coded differently. So they both have the same rating. In which case given the power and torque tuned 335's are putting down we have more than enough head room. |
smallba73.00 |
02-08-2017, 10:55 PM | #18 | |
Rep 1,693
02-08-2017, 11:17 PM | #19 | ||
Rep 577
02-08-2017, 11:45 PM | #20 |
Rep 1,693
02-09-2017, 04:19 AM | #21 | |
Grand Poobah
173
Rep 305
2014 328i XDrive N26 (F30), bootmod3 Stage 2 AGG, VRSF Catless Downpipe, K&N Drop In Filter
02-09-2017, 04:41 AM | #22 |
Rep 1,693
That applies the "Sport Auto" option for faster shifts, but not the higher torque limit on the 335i TCU flash.
