08-07-2020, 11:25 PM | #1 |
Rep 114
N20/N26 oil alternatives to 0w-20...
Hello guys,
As most of us know. BMW is now recommending a LL-14 0w-20 weight oil for their 4 cylinder engine cars. I understand this is mostly done to improve fuel economy. But still I feel it is a really lightweight oil. Especially for cars in warm climates and in the summer. Would it be a bad idea to experiment running a 0w-30 or 5w-30 alternative during the summer months? I use to always run a LL-01 Castrol 5w-30 Euro blend in all my previous BMWs and I would love use this in my N20. However, I worry it is too much of a viscosity difference from the recommended 0w-20 currently in my car. Any of you guys have any experience moving up from BMWs 0w-20 oils? |
08-08-2020, 12:40 AM | #3 |
Rep 5,456
Drives: F30
Im on my second N20 powered F30 and Ive been running 0w40 in both, every 5k miles... with great success.
Castrol or Mobil 1 2014 328i w/ N26 2016 320i w/ N20 |
08-08-2020, 08:40 AM | #5 |
Rep 16,080
It's only one step from 0w-20 to 5w-30, which is insignificant. There's no reason why you can't continue using it. The N20/26 didn't change. The recommendation for 0w-20 as you noted was done purely to realize higher gas mileage without any changes to the engines. They did it after there was enough real world experience with the N20/N26 to suggest that it wouldn't affect the long term reliability of the engines, the timing chain problem notwithstanding, as that doesn't seem to be oil related. As for 0w versus 5w, I run 5w all year long, even in below zero temperatures. If I lived in Socal I'd probably use a 10w.
MacklinUSOB518.00 burg10966.50 |
08-08-2020, 08:58 AM | #6 |
Rep 243
Other day, I was tempted to purchase Kirkland Signature 0W-20 Full Synthetic Motor Oil 5-quart, 2-pack jug for $24.29
You guys think good deal? Costco also sell 5W-30 for the same price. Saw on the box it is manufactured by Warren Distribution Inc. |
08-08-2020, 09:57 AM | #7 |
Rep 681
I tried a couple different oils from Mobil 1 to Liqumoly and others. My n20 seemed happiest with Castrol 0w40 euro blend but blackstone reports for all oils at 5k intervals looked good. I burned the most oil with Liquimoly .5L over 5k miles and more like .2L or so with others. Still within spec but just something to note is all.
2016 328ix F31 - SOLD!
2006 997.1 C4S |
08-08-2020, 10:58 AM | #8 |
Rep 16,080
This is from Warren as well, probably very similar:
http://pqiadata.org/AmazonBasics_0W20.html |
learntocode53.50 |
08-08-2020, 11:30 AM | #9 |
Rep 3,748
The key is the oil change interval.... some might say 5000-7000 miles and some will say 10k miles. Choose your poison
I use to drive 80% highway miles on my commute... I guess you can push 10k on this but I'm still doing 7k.... sspade do 5k interval. You can feel for on your driving routine. Last edited by Gen13 F36; 08-08-2020 at 11:38 AM.. |
sspade2464.50 |
08-08-2020, 12:54 PM | #10 |
Rep 114
It's interesting how BMW was running a 30 weight oil in the N20 all the way up until 2016. Then switching to a 20 weight without any change to the engine...
I know the BMW engineers really know what they are doing but a 20 weight oil just seems much too thin. I think a 40 weight will be too much. I just try my best to not stray away from BMWs recommendations. I think a 5w-30 LL01 Castrol Edge might be the right choice for an all around oil. Close enough too spec but won't cause any harm to the engine. |
08-08-2020, 02:10 PM | #11 | |
Rep 5,456
Drives: F30
That's why there's so many of us using it : |
08-09-2020, 02:06 AM | #12 | |
Rep 3,748
08-10-2020, 05:24 PM | #13 |
Rep 3,680
I run Liquimoly 0W-40, changed every 5k miles. You won't have any problems running 5W-30, 0W-30 or 0W-40.
08-11-2020, 07:24 AM | #14 |
Rep 221
I have a 2017 N20 F25 X3 sDrive28i, but all the engines are the same. In the photo, blue is recommended (0W20), but there are other options. I choose anything that meets LL01. I just removed the dealer 0W20 fill from our CPO and put in LiquiMoly 5W30 Special Tec.
I use Castrol Edge 0W40 (or 5W40) in my E39, but they lost the LL01 certs somewhat recenetly. I'm sure it's fine, but for our X3, I would rather stick with something that holds LL01.
| 2018 BMW 330i | 30k Miles | M-Sport Package | Driving Assistance Plus | Premium Package | Executive Package | Harmon Kardon | Active Blind Spot Detection | PDC | Mineral Grey Metallic/Coral Red Dakota Leather |
| 2022 Toyota Highlander Platinum AWD | Last edited by shoman24v; 08-11-2020 at 07:31 AM.. |
08-11-2020, 09:50 AM | #15 |
Rep 16,080
alohasurftoad3078.00 |
08-11-2020, 10:34 AM | #16 | |
Rep 221
https://www.newtis.info/tisv2/a/en/f...ply/1VnYpiUbyG Named approved oils Trade name Viscosity Producer Addinol Eco light SAE 5W-40 Addinol Lube Oil GmbH Addinol Super Light 0540 SAE 5W-40 Addinol Lube Oil GmbH ADDINOL Super power MV 0537 SAE 5W-30 Addinol Lube Oil GmbH AKTUAL FULLY SYNTH SAE 5W-40 Petronas Lubricants International AREXONS 3x B4 SAE 5W-40 Petronas Lubricants International AVENO FS Excellence SAE 0W-40 Deutsche Ölwerke Lubmin GmbH AVENO FS Select SAE 5W-30 Deutsche Ölwerke Lubmin GmbH Aral HighTronic M SAE 5W-40 Aral Aral HighTronic M SAE 5W-40 Aral AG Aral SuperSynth SAE 0W-40 Aral Aral SuperSynth SAE 0W-40 Aral AG Aral SuperTronic G SAE 0W-40 Aral AG BNO Diamond 5W-40 SN SAE 5W-40 Lub-rref (Bangladesh) Ltd. BOOSTER 600 PLUS SAE 5W-40 Additive Products (M) SDN BHD BP Super V Plus SAE 5W-40 BP Oil International BP Super V Plus SAE 5W-40 BP Plc BP Visco 5000 SAE 5W-40 BP Oil International BP Visco 5000 SAE 5W-40 Castrol Limited BP Visco 5000 SAE 5W-30 BP plc BP Visco 5000 SAE 5W-30 BP Plc BP Visco 5000 SAE 5W-40 BP Plc Biloxxi SAE 5W-30 MCC Trading Deutschland GmbH CEPSA GENUINE 5W40 SYNTHETIC SAE 5W-40 CEPSA Comercial Petroleo S.A.U Castrol Edge 0W-30 A3/B4 SAE 0W-30 Castrol Limited Castrol Edge Professional A3 SAE 0W-30 Castrol Limited Castrol Edge Professional LL01 SAE 0W-30 Castrol Limited Castrol Edge Professional LL01 SAE 5W-40 Castrol Limited Castrol EDGE Supercar 0W-40 A3/B4 SAE 0W-40 Castrol Limited Castrol Edge 0W-30 A3/B4 SAE 0W-30 Castrol Limited Castrol Edge 0W-40 A3/B4 SAE 0W-40 Castrol Limited Castrol Edge 5W-30 A3/B4 SAE 5W-30 Castrol Limited Castrol Edge 5W-40 A3/B4 SAE 5W-40 Castrol Limited Castrol Edge 5W-40 SN SAE 5W-40 Castrol Limited Castrol Edge Professional A3 SAE 0W-40 Castrol Limited Castrol Edge Professional A3 SAE 5W-40 Castrol Limited Castrol Edge Professional A3 SAE 0W-30 Castrol Limited Castrol Edge Professional A3 SAE 5W-30 Castrol Limited Castrol Edge Professional LL01 SAE 5W-30 Castrol Limited Castrol Edge Professional LL01 SAE 0W-30 Castrol Limited Castrol Edge Professional LL01 SAE 0W-40 Castrol Limited Castrol Edge Professional LL01 SAE 5W-40 Castrol Limited Castrol Edge Professional OE SAE 5W-40 Castrol Limited Castrol Edge SAE 5W-40 US version SAE 5W-40 Castrol Limited Castrol GTX 5W-40 A3/B4 SAE 5W-40 Castrol Limited Castrol GTX High Mileage SAE 5W-40 Castrol Limited Castrol GTX Professional A3 SAE 5W-30 Castrol Limited Castrol Magnatec 5W-30 A3/B4 SAE 5W-30 Castrol Limited Castrol Magnatec 5W-40 A3/B4 SAE 5W-40 Castrol Limited Castrol Magnatec Professional A3 SAE 5W-30 Castrol Limited Castrol Magnatec Professional A3 SAE 5W-40 Castrol Limited Castrol Magnatec stop-start 5W-30 A3/B4 SAE 5W-30 Castrol Limited Charger Xtreem SAE 5W-40 Bahrain Petroleum Company Divinol Syntholight SAE 0W-40 Zeller + Gmelin Drive Power 37 + SAE 5W-40 Additive Products (M) SDN BHD ELF Evolution 900 SAE 5W-40 TOTAL Lubrifiants ELF Evolution 900 FT SAE 5W-40 TOTAL Lubrifiants ELF Evolution 900 FT SAE 0W-40 TOTAL Lubrifiants ELF Evolution 900 Turbo SAE 5W-40 TOTAL Lubrifiants ENERGY RELEASE 5W-40 RS (ER 5W-40 RS) SAE 5W-40 DKR PETROLEUM CO., LTD. Eni i-Sint SAE 5W-40 Eni S.p.A. Eurol Synergy SAE 0W-40 Eurol BV FASTRON GOLD SAE 5W-40 Pt. Pertamina LUBRICANTS FK European version SAE 5W-40 Ban Hon International Co., Ltd. FK European version SAE 0W-40 Ban Hon International Co., Ltd. FUCHS TITAN Supersyn LONGLIFE SAE 5W-40 FUCHS PETROLUB SE FUCHS TITAN Supersyn LONGLIFE SAE 0W-40 FUCHS PETROLUB SE Feu Vert SAE 5W-40 Motul G-Energy F Synth SAE 5W-30 Gazpromneft-lubricants Ltd G-Energy Service Line MS SAE 5W-30 Gazpromneft-lubricants Ltd GALP FORMULA ENERGY 5W40 SAE 5W-40 PETROGAL S.A. GD 7.1 SAE 5W-40 Additive Products (M) SDN BHD GT-1® Euro Motor Oil SAE 5W-30 Kendall Motor Oil GT-1® Euro Motor Oil SAE 5W-40 Kendall Motor Oil Gulf Formula GX SAE 5W-40 Gulf Oil International Gulf Formula GX SAE 5W-30 Gulf Oil International Gulf Formula GX SAE 0W-40 Gulf Oil International Gulf Formula S SAE 5W-40 TOTAL Lubrifiants HPR 5 SAE 5W-40 Penrite Oil Company Pty Ltd. Havoline Fully Synthetic E SAE 0W-40 Chevron Lubricants Havoline Pro DS Fully Synthetic SAE 0W-40 NV CHEVRON BELGIUM Havoline Pro DSFull Synthetic Motor Oil SAE 5W-40 NV CHEVRON BELGIUM Havoline ProDS Fully Synthetic SAE 5W-40 Chevron Global Lubricants Havoline Synthetic SAE 5W-40 Chevron Lubricants Havoline Synthetic Engine Oil SAE 5W-40 Chevron Global Lubricants Havoline Ultra SAE 5W-40 Chevron Lubricants INA Ultra Sint SAE 5W-30 INA Maziva Ltd. LUBREX VELOCITY NANO PLUS SAE 5W-40 LUBREX FZC LUKOIL GENESIS ARMORTECH SAE 5W-40 OOO LLK-International LUKOIL GENESIS POLARTECH SAE 0W-40 OOO LLK-International LUKOIL GENESIS SPECIAL SAE 0W-40 OOO LLK-International LUKOIL GENESIS SPECIAL POLAR SAE 0W-40 OOO LLK-International Leichtlauf High Tech LL SAE 5W-30 LIQUI MOLY GmbH Liqui Moly Leichtlauf High Tech SAE 5W-40 Liqui Moly GmbH Liqui Moly Pro-Engine M900 SAE 5W-40 Liqui Moly GmbH Liqui Moly Special Tec LL SAE 5W-30 Liqui Moly Lotos Syntetic Plus SAE 5W-40 Lotos Oil Mol Dynamic Synt SAE 5W-30 MOL-LUB Lubricant Ltd. MOTOREX XPERIENCE FS-X SAE 0W-40 BUCHER AG LANGENTHAL MOTUL 6100 SYN-NERGY SAE 5W-30 MOTUL MOTUL 8100 X-MAX SAE 0W-40 Motul S.A. Meisteröl LL SAE 5W-30 Epro GmbH Midland synqron SAE 5W-40 Oel-Brack AG Miocar MX Syntra SAE 5W-40 Migros Genossenschafts Bund Mobil 1 Formula SAE 0W-40 ExxonMobil Mobil Formula X2 SAE 5W-40 ExxonMobil Mobil Super 3000 Formula B SAE 5W-40 ExxonMobil Mobil Super 3000 X1 SAE 5W-40 ExxonMobil Mobil Super 3000 X1 SAE 5W-40 Exxon Mobil Mobil Super 3000 X2 SAE 5W-40 ExxonMobil Mobil Super Synthetic Euro SAE 5W-40 ExxonMobil Mobil Super Synthetic Formula B SAE 5W-40 ExxonMobil Motul 6100 ECO FLEX SAE 5W-30 Motul S.A. Motul 6100 Flexmax SAE 5W-30 Motul S.A. Motul 6100 Flexmax SAE 5W-30 Motul SA Motul 8100 X-CESS SAE 5W-30 MOTUL Motul 8100 X-CESS SAE 5W-40 MOTUL Motul 8100 X-cess SAE 5W-40 Motul S.A. Motul Expert M SAE 5W-40 Motul S.A. Motul Specific LL-01 SAE 5W-30 Motul SA Motul Synergie SAE 5W-40 Motul S.A. OLEOBLITZ PULSAR C.R. SAE 5W-40 Petronas Lubricants International Omera Lube 1 SAE 5W-40 MJL Bangladesh Ltd. PENTOSPEED SUPER PERFORMANCE SAE 5W-40 FUCHS SCHMIERSTOFFE GMBH PETRONAS SYNTIUM 3000 SAE 5W-40 Petronas Lubricants International Pennzoil Platinum Euro SAE 5W-30 Shell International Petroleum Company Pennzoil Platinum Euro SAE 5W-40 Shell International Petroleum Company Pennzoil Platinum Euro SAE 5W-30 Shell International Petroleum Co.Ltd. Pennzoil Platinum Euro SAE 5W-40 Shell International Petroleum Co.Ltd. Pennzoil Ultra Euro SAE 5W-40 Shell International Petroleum Company Pennzoil Ultra Euro 5W-40 Full Synthetic Motor Oil SAE 5W-40 Shell International Petroleum Company Petronas Syntium 7000 SAE 0W-40 Petronas Professional Series Full Synthetic Motor Oil SAE 5W-40 Red Line Synthetic Oil QS Ultimate Durability European SAE 5W-40 Shell International Petroleum Company QS Ultimate Durability European SAE 5W-30 Shell International Petroleum Company Quaker State Ultimate Durability European SAE 5W-40 Shell International Petroleum Co.Ltd. Ravenol HCL SAE 5W-30 Ravensberger Schmierstoffvertrieb GmbH RAVENOL HST SAE 5W-40 Ravensberger Schmierstoffvertrieb GmbH RAVENOL RSP SAE 5W-30 Ravensberger Schmierstoffvertrieb GmbH RAVENOL Super Synthetik Öl SSL SAE 0W-40 Ravensberger Schmierstoffvertrieb GmbH RAVENOL VollSynth Turbo VST SAE 5W-40 Ravensberger Schmierstoffvertrieb GmbH REPSOL ELITE COMMON RAIL SAE 5W-30 REPSOL LUBRICANTES Y ESPECIALIDADES S.A REPSOL ELITE COMPETICION SAE 5W-40 REPSOL LUBRICANTES y ESPECIALIDADES S.A REPSOL ELITE COSMOS HIGH PERFORMANCE SAE 0W-40 REPSOL LUBRICANTES Y ESPECIALIDADES S.A REV-1 TITANIUM SAE 0W-40 Spare-Parts Zone Pte Ltd ROWE HIGHTEC SYNT RS HC-D SAE 5W-40 ROWE MINERALÖLWERK GMBH Repsol Elite Common Rail SAE 5W-30 Repsol YPF Repsol Elite Competicion SAE 5W-40 Repsol YPF SINOPEC JUSTAR J700F Premium SAE 5W-30 SINOPEC LUBRICANT CO.,LTD. SPC SYN ACE SUPREME API SN SAE 5W-40 Singapore Petroleum Company Ltd. SRS ViVA 1 ecosynth plus SAE 0W-40 SRS Schmierstoff Vertrieb GmbH SRS ViVA 1 Longlife SAE 5W-30 SRS Schmierstoff Vertrieb GmbH SRS ViVA 1 topsynth SAE 5W-40 SRS Schmierstoff Vertrieb GmbH SRS ViVA 1 topsynth plus SAE 5W-40 SRS Schmierstoff Vertrieb GmbH SRS Viva 1 Longlife SAE 5W-30 SRS Schmierstoff Vertrieb GmbH STAR GOLD SAE 5W-40 Orlen Oil Sp. z o.o. STAR SYNT S SAE 5W-40 Orlen OilSp z o.o. Shell Helix HX6 SAE 5W-40 Shell International Petroleum Company Shell Helix Ultra SAE 5W-30 Shell International Petroleum Company Shell Helix Ultra SAE 5W-40 Shell International Petroleum Company Shell Helix Ultra SAE 5W-30 Shell International Petroleum Co.Ltd. Shell Helix Ultra SAE 5W-40 Shell International Petroleum Co.Ltd. Shell Helix Ultra Professional ABB SAE 5W-40 Shell International Petroleum Company Shell Helix Ultra Professional ABB SAE 5W-30 Shell International Petroleum Co.Ltd. Shell Helix Ultra Professional ABB SAE 5W-40 Shell International Petroleum Co.Ltd. Shell Helix Ultra Professional AM SAE 5W-40 Shell International Petroleum Company Shell Helix Ultra X SAE 5W-30 Shell International Petroleum Co.Ltd. Shell Helix Ultra l SAE 5W-30 Shell International Petroleum Company Shell Helix Ultra l SAE 5W-40 Shell International Petroleum Company Shell Helix Ultra l SAE 5W-30 Shell International Petroleum Co.Ltd. Shell Helix Ultra l SAE 5W-40 Shell International Petroleum Co.Ltd. Shield® Euro-Tech Motor Oil SAE 5W-40 Phillips 66 Company Shield® Euro-Tech Motor Oil SAE 5W-30 Phillips 66 Company Swd Rheinol Primus CVS SAE 5W-30 Swd Lubricants GmbH & Co.KG Swd Rheinol Primus VS SAE 0W-40 Swd Lubricants GmbH & Co.KG SynPower engine oil SAE 5W-30 Valvoline EMEA SynPower engine oil SAE 5W-40 Valvoline Synthetic PC SAE 5W-30 eni S.p.A. TNK Magnum Ultratec SAE 5W-40 TNK Lubricants, LLC TOTAL Quartz 9000 SAE 5W-40 TOTAL Lubrifiants Total Quartz 9000 Energy SAE 0W-40 TOTAL Lubrifiants Titan Supersyn Longlife SAE 5W-40 Fuchs Petrolub AG TongYi SN SAE 5W-40 TongYi Petroleum Chemical Co., Ltd. Total Activa 9000 SAE 5W-40 Total Total Activa 9000 Essence SAE 5W-40 Total Total quartz 9000 SAE 5W-40 Total Total Quartz 9000 Energy SAE 5W-40 Total Triathlon Formula LL SAE 5W-30 Adolf Würth GmbH & Co. KG Triathlon Premium SAE 5W-40 Würth International Trading ( Shanghai) Co,. Ltd. VR 7.1 SAE 5W-40 Additive Products (M) SDN BHD Valvoline Advanced SAE 0W-40 Valvoline Valvoline SynPower SAE 5W-30 Valvoline Valvoline SynPower HST SAE 5W-30 Valvoline Valvoline SynPower HST SAE 5W-40 Valvoline Valvoline SynPower motor oil SAE 0W-40 Valvoline EMEA WOLF VITALTECH SAE 5W-40 Wolf Oil Corporation NV. Weco TXI Syntholube SAE 5W-40 Weco Westfalen Gigatron SAE 0W-40 Westfalen AG Westfalen Megatron SAE 5W-40 Westfalen AG Yacco VX 1000 SAE 5W-40 Yacco S.A.S. Yacco VX 1000 LL SAE 5W-40 Yacco S.A.S. eni i-Sint SAE 0W-40 eni Schmiertechnik GmbH eni i-Sint PC 4AM SAE 5W-40 eni Schmiertechnik GmbH eni i-Sint PC 4AM SAE 5W-30 eni Schmiertechnik GmbH maxxpower 5W30 Synergie SAE 5W-30 Swd Lubricants GmbH & Co.KG Megol Motorenoel High Condition SAE 5W-40 Meguin GmbH & Co. KG Megol Motorenoel Quality SAE 5W-30 Meguin GmbH & Co. KG
| 2022 Toyota Highlander Platinum AWD | |
08-11-2020, 12:30 PM | #17 |
Rep 114
Thanks for all the info guys. I'm going to swap out the factory 0w-20 to my preferred Castrol Edge 5w-30 A3/B4. It worked fine in my other cars. It meets LL-01 which is enough in my opinion. The hard part is just finding it in stores. Why is Castrol doing gold bottles now? Last edited by zuckuss07; 08-11-2020 at 12:42 PM.. |
08-11-2020, 08:35 PM | #18 |
Rep 384
i get from some tuners, that they recommend to use 40 weight oil if you tune your car, for extra protection due to extra pressure from tuning the car.
But i still use 0w-30 on my tuned car, and no problem so far
Instagram: nightfall.f30
08-12-2020, 11:15 AM | #19 |
NewFinishColumbia/detailer
604
Rep 2,096
So I used the Castrol Syntec 0W-40 in my 228 N20 with a stage 1 tune for 98K with 8k changes and OEM filters. I put the same tune on my F31 328 N20 for the last 45K miles with the same schedule. I've also used Mobile1 0W-40 here and there.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
sspade2464.50 |
08-12-2020, 10:45 PM | #20 | |
Rep 3,748
Anyone can do whatever they want with there car.... You can spend $$$$ on Motul if that's what they like |
SteveInfante604.00 |
08-13-2020, 09:10 PM | #21 |
David
786
Rep 2,009
Thinking of switching to 5w-40 my next change. It's non-stop 100+ here in socal and the oil has the viscosity of water pretty much when I change it or see it drip off the oil cap running 5w-30
08-14-2020, 12:32 PM | #22 |
Rep 5,506
You should be fine. Unless you're doing laps on a race track non stop or oil is burning between oil changes, 5w30 is fine. It may look thin to you but that's what the car is designed to run.
Auto Detailing Enthusiast!
