08-25-2020, 09:55 PM | #1 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
What's your Ideal Winter Setup?
Finally in the position to buy whatever winter wheels I want instead of being stuck running stock wheels in snow half the year (I live In South Dakota)
What wheel/tire combo would you run in snowy conditions with xDrive? I live in a big city (by South Dakota standards) so it does get plowed and driven on pretty regularly but I can usually count on driving in fresh snow or packed snow at least a few days out of every week during the winter. I read through the Winter Tires sticky but it seemed like mostly fitment questions and tire type questions. Right now I'm leaning towards 225/45 R18 on 18x8 square. Sounds like the Michelin X-Ice Xi3 would be a good choice for my area. My question- any recommendations on a wheel manufacturer that makes 8" width wheels? Seems like Apex and most others start at 8.5". I'd rather avoid cheap heavy cast wheels if possible. Secondly, in your opinion which finish is easier to clean and maintain in the winter - black or a hypersilver alloy type finish?
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
08-26-2020, 07:47 AM | #2 |
Rep 849
Drives: BMW 435i
I built a tire/wheel package off of TireRack last winter and was very happy.
My wheels are the 18x8 Rial X10's. They are built and finished well. For tires I went with the Pirelli Sottozero 3 since I only see a handful of snow storms each year and spend most of my time on dry roads in freezing temperatures or rain/slush/ice. If you're seeing/driving on snow on an almost daily basis I'd probably go with Blizzaks or something from Nokian.
08-26-2020, 10:25 AM | #3 |
Rep 1,055
Usually it's the smallest + thinnest wheels you can find with snow tires. If your city plows the roads pretty well, most of the time you can get away with all seasons instead.
Light vs heavy wheels in the snow don't really matter it's more the tire that plays a role here.
MY13: TTE400 Stage 2 turbo, Spec Single Mass flywheel + Stage 3+ Clutch, FTP V2 Turbo Inlet, Evolution Racewerks Charge pipe + Boost pipe + Intercooler, Turbosmart Recirculating Diverter Valve, aFE grill scoop + aFE Magnum Force Cold Air Intake, B58 coil retrofit, eBay Downpipe, Active Autowerke muffler, DW400 LPFP, B58TU HPFP, M5 s63TU injectors, Bimmermilvs, e80 tune by Navardi Tuned. 380 whp/360 wheel torque stock block
08-26-2020, 10:31 AM | #4 |
Rep 10,249
One of the best options for a dedicated winter wheels / tires set is BMW's own 400M Style wheel in a square configuration: 18x8J ET34. These wheels are often sold at a discount on this forum and other e-commerce sites. This wheel will clear M Sport brakes.
Supr3me551.00 |
08-26-2020, 11:42 AM | #6 | |
Rep 849
Drives: BMW 435i
In near- and sub-freezing temps I found the winter tires to have better grip than my AS tires in sane daily driving conditions. Add rain/wet roads to the equation at those temps and the difference in grip is even wider. Even in my well-plowed area, ice becomes a frequent issue. Either from freezing rain or melting snow. In this situation it's no contest between the winter and AS tires.
Supr3me551.00 |
08-26-2020, 12:02 PM | #7 | ||
Rep 1,055
You have to remember to dismount and take off your winter set of tires at around 40F otherwise you'll burn them up just driving around. Between to two tire types are night and day, but many people get around on all seasons just fine 100% of their life driving slow and defensively in the snow.
08-26-2020, 04:12 PM | #8 | |
Rep 849
Drives: BMW 435i
Lately our winters have seen huge swings in temperatures from day-to-day and even during the day. Swapping out the tires because it is 60 degrees is not and option. You'd be swapping them out almost daily or end up stranded on a day when it's pushing 70 around lunch time and an ice storm blows through by the time you get off work. I found my "performance winters" held up really well when doing road trips in 60~65 degree weather. No tread destruction or chunking of any kind. They handled terribly and I had to be gentle on them, but showed no real signs of wear. I feel choosing the right winter tire (they aren't all the same) will always put you in a better position than trying to run an AS in certain parts of the country. Another option I find interesting are the "all weather tires" like the Nokian WR G4 hitting the market. Even more flexibility for those who live in the "shoulder areas" of the snow belt.
Supr3me551.00 |
08-27-2020, 08:37 AM | #9 | ||
Rep 611
Personally, I really like BMW's 397 wheels as 18" winter setup - they look good and are easy to maintain. Any reason you want aftermarket wheels? Quote:
Indeed, the Hakkapeliitta's are a whole different story - had them fitted on a car during hot Scandinavian summer and spotting the skid marks in the rearview mirror during braking was nothing special |
Supr3me551.00 |
09-02-2020, 10:24 AM | #10 |
Modder of everything I own
147
Rep 491
I just used my stock wheels with 225./45/18 Blizzaks, wouldn't change a thing. I leave them on until the temp gets above 40 degrees consistently which is usually later in March and of course then we get an early April 12" snowfall and I'm stuck at home lol.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
Supr3me551.00 |
09-03-2020, 09:46 PM | #11 |
Rep 65
M3 ZCP replica wheels (18x8" +35 square setup) - Bought off ebay for like $600 shipped. Tons of wheel weights but they drive fine and have taken a beating lol.
Nokian Hakkapelitta R2 Tires (225/45/18 stock size) - Overkill for sure, but when theres snow and ice on the ground this car is a tank. Last edited by Regulator; 09-03-2020 at 09:55 PM.. |
Supr3me551.00 |
09-03-2020, 10:05 PM | #12 |
Rep 684
Thanks for all the replies. I actually just sold my stock 18" M-Sport wheels recently because I didn't care for their appearance. Not sure on the style code but I included a pic. Just not a very aggressive wheel IMO.
I think I've almost definitely settled on FlowOne F3 18x8 wheels in gloss black with 225/45R18 Blizzak WS90s. I think the wheel design will be easier to clean than split spoke styles and the width of the tire will provide some rim edge protection, but narrow enough to give good bite in the snow. Maybe the only thing that gives me pause is that I'm worried about destroying the Blizzaks on bare pavement days. It doesn't get very much over freezing here during the winter but I'm making about 600 WHP right now. I'll probably be on a lower boost winter map but it's still going to push these tires way beyond what a snow tire is designed for. I'm really going to have to restrain myself lol
2020 X3M
09-04-2020, 07:31 AM | #13 |
Rep 849
Drives: BMW 435i
I like those wheels for a winter set. They look really easy to clean.
Based on what you've said about driving on fresh snow several days a week and the temps steadily staying below freezing most of the winter, you should do just fine on the Blizzaks. It's when they too warm that the accelerated wear starts to happen. A more performance oriented tire like what I run would hold up better in the dry, but probably not ideal for most of the conditions you encounter. How you handle the 600hp while they are on your car is a totally different story!
09-05-2020, 05:19 AM | #14 | |
Rep 774
09-05-2020, 05:20 AM | #15 | |
Rep 774
I got BBS SR 18x8 for my winter setup
09-05-2020, 10:45 AM | #16 | ||
Rep 1,055
