08-31-2020, 07:32 PM | #1 |
I even mod my cereal
246
Rep 3,441
Drives: 11 ZCP DCT M3 14 328d 21 GT4
Windshield Wipers Chattering
Hey guys,
Has anyone had wobbling or chattering wipers regardless of new or broken in? I am having this problem with my F31 and its become annoying. I've tried cleaning the windshield, even with a razor blade at a low angle and the blades are still wobbly. Has anyone tried a windshied sealer that actually works? Any tips or remedies would be greatly appriceciated.
2011 Mineral White M3 ZCP - Opticoat, Ventureshield, some CF, B&B exhaust, AFE Intake Vorsteiner VFF 101s Ohlins
2014 Mineral White 328d Xdrive Wagon - Opticoat, Ventureshield, B8s, H&R, Apex SM-10s Hawk Pads 2021 718 Cayman GT4 - Fire extinguiser |
08-31-2020, 09:07 PM | #2 |
Rep 16,082
I don't know about a windshield sealer, but I polish mine yearly with cerium oxide and a buffer. Then I apply Aquapel, which is by far the best rain repellent. If the blades start to chatter I clean them with alcohol.
09-01-2020, 06:57 AM | #3 |
246
Rep 3,441
Thanks for the tip. Where are you buying cerium oxide?
09-01-2020, 09:58 AM | #4 |
Rep 16,082
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Don't bother with small buffing pads, they'll take a week to do a windshield. I use a 6" pad, like this: https://www.amazon.com/Meguiars-DMX6...omotive&sr=1-7 It takes an aggressive pad because cerium oxide has minimal cutting, to prevent scratching the glass. |
09-01-2020, 10:17 AM | #5 |
246
Rep 3,441
Thanks for the product direction!
09-01-2020, 12:06 PM | #6 |
Rep 16,082
When you use cerium oxide cover everything with old sheets. Even when wet it's so light that it's as light as dust and will go everywhere, and it's a PITA to get off paint.
09-01-2020, 12:27 PM | #7 | |
246
Rep 3,441
I do change my own oil, tire rotations and other maintenance items....so you don't think I'm a complete squid.
09-01-2020, 02:47 PM | #8 |
Rep 16,082
It's almost impossible to screw up with cerium oxide, because the polishing process is very slow. It's not like rubbing out with paint, where you can go through the finish in just seconds. The only way you can run into a problem is if you try to polish out a deep scratch. To do so you'd end up overheating the glass, causing it to warp.
09-01-2020, 06:46 PM | #9 |
Rep 113
Just out of curiosity how old are your wipers and have the been changed recently ? With that being said I have found P&S beadmaker works well for me usually after every maintenance wash I spray the windshield down with it work it in see you later. Seems to hold up well between washes some rainy days I don't even need to run my wipers it beads so well.
09-02-2020, 06:36 AM | #11 | |
246
Rep 3,441
Thanks for the product suggestion.
09-02-2020, 04:50 PM | #12 |
Rep 113
No problem OP its really easy to use stuff been running it for over 2 years now. as my rim topper, sip and sill protectant, and all the glass.
09-07-2020, 11:25 AM | #13 |
Rep 495
Cerium Oxide is the nuclear option for windshields btw.
Maybe try something 'softer' like this: https://www.1z-usa.com/glass-polish-6-8-oz/ I applied mine with a porter cable and red lake country pad, it totally eliminated hazy marks and waxy deposits left by the dealer that was causing squeak. Did the mirrors, windscreen, rear glass and sunroof. |
