03-13-2019, 05:51 PM | #45 |
Rep 40
Pulled the trigger as well after reading this. Being in Georgia I've been wanting to upgrade with the hot summer days. I figure it would be plenty for my driving style and would still work whenever I go BM3 later this year. Cars out of warranty in 2 months so that's when the fun can begin!
sspade2464.50 |
03-14-2019, 08:32 AM | #46 |
Rep 2,671
Instead of creating a new thread figured I'd ask this question in this one:
I have the standard front bumper so this new FMIC isn't getting as much direct air as it would with the more open m-sport bumper. I've debated on getting an msport bumper but then there's painting and headlights. So would air scoops that are typically used to direct air toward intake but instead used to direct air toward fmic be useful/possible? Thoughts? Thx! |
03-14-2019, 11:55 AM | #47 | |
#gotboost
517
Rep 861
2018 F87 M2 (09/2020 - )
Dinan Cold Air Intake |Dinan Axle Back | VRSF 6.5" Intercooler | VRSF Catless Downpipe | VRSF Charge Pipes | BM3 | MST Inlet v2 | Turbosmart VR11 2013 F30 328i (12/2015 - 09/2020) SOLD! |
rjd_F301999.50 |
03-14-2019, 01:47 PM | #48 | |
Rep 2,036
03-14-2019, 02:00 PM | #49 |
Rep 2,671
I guess my bumper issue is that I have halogens and if I go m-sport bumper that means halogens would have to go next, and I'm done modding for a little while. But if I do see an msport bumper in imperial blue hit the market I will prob snatch it up anyway. Appreciate the info.
So back to the FMIC scoop question......... |
03-14-2019, 02:56 PM | #50 | |
Rep 2,036
03-14-2019, 07:14 PM | #51 | |
Rep 3,680
floridaorange10152.50 |
03-15-2019, 03:39 AM | #52 | ||
Rep 2,671
03-25-2019, 04:35 PM | #54 |
Rep 5,456
Skrrtt33515.00 |
03-29-2019, 05:20 PM | #55 | |
Rep 537
The reviewed item is the same height as the OEM and a good deal deeper, with all metal construction and bar/plate. The current model being sold on Amazon is a two-stepped design with similar dimensions on the lower half and additional upper section. I've not seen/heard anyone provide a review of the current model...yet.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
03-29-2019, 05:38 PM | #56 | ||
Rep 239
03-29-2019, 06:19 PM | #57 | |||
Rep 537
I would, but I am waiting until my CPO warranty expires in Sept. before doing bm3. Just waiting on the FTP inlet pipe to get here and then doing FBO installation in one day. CPs, inlet, FMIC and DV+ all together.
alohasurftoad3078.00 |
04-05-2019, 10:02 AM | #58 |
Rep 472
I just tried to get the black stepped GPlus intercooler installed and the outlets are a completely different size then the stock or aftermarket chargepipe. Not sure if the wrong part was sent to me but just a FYI. I have to return.
N26Ghost496.50 |
04-05-2019, 10:22 AM | #59 | |
Rep 5,456
Can you show us pics? I can remember my fittings being VERY tight... I actually installed them by themselves on each side (with a bit of lube) and also using a piece of wood over the edge of fitting so I could tap with a hammer (and not damage). Then once metal fittings were on, I attached the rest of charge pipe outwards. Might not be possible to do this with stock plastic charepipes, not sure. You should try that before returning! They fit tight which is what you want, no boost leaks. ***As mentioned above, mine is the non-stepped version. It is definitely possible you got a defective unit but wanted to share my experience to try and save you the hassle... |
04-05-2019, 11:13 AM | #60 |
Rep 891
I also have the old model and didn't have fitment issues with my stock charge pipe. Putting zip ties on the locking clip made things way easier. A little gorilla strength and the fittings seated nice and tightly.
sspade2464.50 |
04-05-2019, 12:37 PM | #61 | |
Rep 537
I am attempting this job this weekend and you better believe that if there are fitment issues there be flames throughout Amazon. I will line up the FTP CPs with the intercooler inlet later and share pics.
sspade2464.50 |
04-05-2019, 12:55 PM | #62 |
Rep 537
Good News
Using the FTP CPs, the fitment is perfect to the GPlus FMIC. Very tight tolerance, but was able to just wiggle them on and the clips went on without issue. Whew.
sspade2464.50 MacklinUSOB518.00 |
04-05-2019, 12:58 PM | #63 | |
Rep 5,456
I was getting nervous as a huge supporter of the GPlus unit. Dont want to steer brethren wrong |
N26Ghost496.50 |
04-05-2019, 01:01 PM | #64 | ||
Rep 537
floridaorange10152.50 sspade2464.50 |
04-05-2019, 05:38 PM | #66 |
Rep 472
Very weird. I went to Bryan Kies for the install who definitely knows what he's doing. Maybe the model intercooler delivered to me was for a different car but the connections from the intercooler to the chargepipe were way too big. Not even close.
N26Ghost496.50 |
