BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > New CTS Intake...anyone have it yet?
      11-24-2018, 07:52 PM   #221
BigJack75
BigJack75's Avatar
Drives: M5 Dream Car
Originally Posted by Chicken_Joe View Post
I feel like it's just going to heat soak and suck hot air.
This ^^^
435i GC
      11-26-2018, 08:15 AM   #222
JaredG_F30
JaredG_F30's Avatar
1032
Based on logs there really isn't any difference in IAT between an open box intake like the CTS one or the stock intake. The FMIC impacts IATs more than anything. The open box intakes are just a sound mod.
Originally Posted by jack10525 View Post
This ^^^
SPI Films Blog/DIY Vids
      11-26-2018, 10:18 AM   #223
Marlinman
Drives: 2013 335i xDrive
^^unless you are running a larger turbo and pushing a lot more power at which point the stock intake piping becomes restrictive.
Seba77W299.00
      11-26-2018, 10:25 AM   #224
badbread
not good, but bad
Drives: 2013 335i
Exactly, I did a bunch of testing with stock vs cts intake and it didn't make a difference. Once you get moving they even out.
Seba77W299.00
      11-26-2018, 12:57 PM   #225
JaredG_F30
JaredG_F30's Avatar
1032
Ah...good point
      07-22-2019, 11:58 AM   #226
BigJack75
BigJack75's Avatar
Originally Posted by odus View Post
this looks terrible for the price but I am slowly learning they price gouge the bmw community because they believe you guys have the money for this stuff. at the end of the day this thing looks like a 100 dollar intake no thanks.
Hahaha completely agree!!!
      07-22-2019, 12:16 PM   #227
BigJack75
BigJack75's Avatar
Intakes are like jewelry for cars. They look good but donít do much.
      07-23-2019, 04:06 PM   #228
JaredG_F30
JaredG_F30's Avatar
1032
It's not about looks or performance, it's about sound.
Seba77W299.00
nbay8962.00
      07-28-2019, 09:38 PM   #229
Seba77W
Seba77W's Avatar
299
Drives: BMW 435i Xdrive Coupe
Intakes are like jewelry for cars. They look good but don’t do much.
Hahah yep. I love it !
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
      07-29-2019, 04:15 PM   #230
ali820
ali820's Avatar
237
Drives: '15 335i MPE 6sp Suzuka Grey
Any opinions on the difference between CTS or MST intakes?
      07-29-2019, 05:48 PM   #231
alohasurftoad
Drives: 428i gran coupe
$264 shipped to your door is a no brainer.
https://www.ctsturbo.com/product/cts...sedan-435i-ix/
      07-29-2019, 05:49 PM   #232
Gabefuu
Drives: BMW 435i
For anyone thinking about getting the CTS Turbo intake I would totally recommend it. Especially if your looking for one with great sound. Not going to lie though. For the first couple miles it did sound a little okayish, but man did it come alive.
      12-31-2019, 08:48 AM   #233
FAUXSHO
FAUXSHO's Avatar
Panama
45
Drives: 2014 F30 335i, 2011 E93 M3
Just installed this. Wow! What a great and addictive sound! Easy install with the instructions. Totally recommended.
Now time to install the CTS DP and FMIC for Stage 2 to ring in 2020
ali820237.00
      03-05-2020, 04:37 PM   #234
zazoo
Drives: F30, N55, PWG
Hi. I have installed it on my f30, but how have you solved the problem with the high-temperature coming from the cooling hose? The aluminum part almost sits on the cooling hose and the intake pipe takes all the heat from it - the intake air before turbo becomes much hotter (especially in a traffic jam) than with OEM. Contacted CTS Turbo and they said, that the intake temperature before turbo doesn't make an impact on performance... So, it seems like they make it just you to have some great Instagram stories..
      03-05-2020, 05:09 PM   #235
thejeremyman9
thejeremyman9's Avatar
1338
Drives: 2015 BMW 335i
I have seen several people try to argue that IAT at the intake doesn't matter because the car is intercooled, but i completely disagree with that statement. Sucking in higher temperature air is going to have an affect on the IC and overall performance - it may not be immediate in the sense that the IC may be able to cool the air down on the first pull to the same temperature after the IC that it would have been regardless of what temperature the air entered the system at (this also operates on the assumption that the IC has the capacity to cool down air at a higher temperature, which is an assumption), but it is certainly going to contribute to heat soak over time (IC will heat up faster than it would have otherwise).
Most people buy intake's for the noise anyways. If you were really concerned about keeping IATs at the intake down, you would keep a closed intake that doesn't draw hot air from the engine bay (or as you mentioned, heat up the intake air in other ways as well).
      03-06-2020, 09:51 AM   #236
JaredG_F30
JaredG_F30's Avatar
1032
Open air intake + WMI = WINNING!!
      03-06-2020, 05:24 PM   #237
Phantom10R
Drives: 2015 335i, 2015 X3 x35i
Mostly true yeah, but once you get moving the iat's come down pretty damn quick, there is no more or less heat soak than stock. The things we do know is that the stock intake is a restriction with an aftermarket turbo. There was a local guy to me who made 7-8hp with an intake on his 2014 ewg n55. It was mainly above and below the peak of the curve. I believe he had an injen like I have.
All that you guys ever do here is just parrot the same info that other people say as fact, everything ive seen personally shows they help. Whether or not its huge or small, they usually help. Unless its BMS... as soon as someone asks about one, 50 people show up trying to sell them theirs lol
Edit:
https://f30.bimmerpost.com/forums/sh...d.php?t=988489
2015 335i xDrive 11.76 on stock turbo. (dragy) uphill!
2015 X3 x35i 13.26 catless w/bm3 stage1 flash
IG: @N55David
Youtube: @ n55david
      03-06-2020, 06:26 PM   #238
thejeremyman9
1338
Edit:
Not sure what you are saying i parroted... I just laid out my logic for how it could potentially impact IATs. Didnt mention anything in the context of the intake being a restriction, particularly not for a aftermarket turbo application. I think the entire performance discussion for intakes is somewhat pointless anyways given that its +/- a few HP. If you have already done everything else, have a bigger turbo, and are looking to get the last few bit on bolt-on gains that you can, then i guess you might consider an intake and importantly a turbo inlet as well to get that last bit of optimization. In a constantly moving situation, yeah, the IAT considerations are probably be negligible (with an upgraded IC of course). But i know how quickly underhood temps rise when you are not moving.
Bottom line is, some people like intakes, some people hate them. I'm indifferent /shrug.
      03-06-2020, 07:50 PM   #239
Phantom10R
Edit:
true.. good point
IG: @N55David
Youtube: @ n55david
      03-07-2020, 06:08 PM   #240
nbay89
Drives: 2016 435i xdrive Coupe M sport
Just ordered one for my 435. It should be here this coming Thursday. I'll post a video and keep you updated.
      03-12-2020, 01:53 PM   #241
_das_bae_
_das_bae_'s Avatar
Drives: 2015 435i Coupe
Youíll love the sound it makes, itís great!
      03-12-2020, 03:00 PM   #242
nbay89
You’ll love the sound it makes, it’s great!
Installed it last night! Great sound! MPE is on its way.
