10-13-2019, 01:04 AM | #1 |
Rep 179
Need help picking run flats plz
I've got these staggered 624m's
https://www.shopbmwusa.com/PRINT/463...-21DFFF82A648= My current tires are: 235/35ZR19 275/30ZR19 now I've found a good deal on some run flats but they're: 225/40 R19 255/35 R19 Would these be okay? This is a for a 428i xdrive Thanks Last edited by straightdraw84; 10-13-2019 at 01:09 AM.. |
10-13-2019, 04:58 PM | #3 |
Rep 2,805
Drives: F33 430 and F39 M35i
You’re current setup is at 25.47” and 25.49”.
The 225/40 and 255/35 would work and be at 26.08” and 26.02”. It will fill in the xdrive gap a little too if you’re not lowered. The stock wheel tire sizes will be 25.2” and 24.78”. All will work fine for xdrive. Does your current 275 tire look too wide for your wheel? |
10-13-2019, 05:00 PM | #4 | |
Rep 3,748
Your original tires 275/30 for rear how did that fit on an 8.5 with 624m |
10-13-2019, 11:22 PM | #5 |
Rep 179
I bought them used and they came like that, here are the pics of the front and rear wheels:
10-13-2019, 11:53 PM | #6 | |
Rep 3,748
8.5 and 9.5 width wheel are the most common staggered setup replica wheels came with. So I would suggest getting them measure before buying 225/40 and 255/35. |
10-14-2019, 12:25 AM | #7 | |
Rep 179
10-14-2019, 03:28 AM | #8 | |
Rep 4,327
if your (replica?) wheels are 8.5" and 9.5", 225/40/19 and 255/35/19 are the oem staggered sizes on rwd and x-drive vehicles and a more appropriate size combination for your f-series x-drive anyhow. the current size combo diameter is too small and is the reason your fenderwell gaps are extra large. |
