BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > ☛ MHD Flasher F Series (F2x F3x) discussion ☚
      11-03-2019, 02:48 AM   #3521
Tommix
Tommix's Avatar
Finland
Drives: F20 M135i xDrive
Originally Posted by thejeremyman9 View Post
The above post from MHD back in their June update says thats the full E85 maps are the "most powerful Stage 1 and 2 maps" [for N55 EWG]. Has anyone tried these out? I thought i read in other posts that the full E-85 maps were not really for power but rather for people who have access to E85 and want to run it for fuel price reasons.
I try full e85 map in my ewg car.
Full e85 map do only 12 psi (HPFP capasity is poor)
Stage 2+ do 17 psi
So, witch map do more whp:s?
      11-03-2019, 07:05 AM   #3522
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Stage 2+ do 17 psi
Full E85 is not a power map. It's suited for those that have easy access to E85 and the price being cheaper than 93 octane.
For power go with the highest ocane map in whichever stage your setup for or E20 tunes.
Phyrexia456.50
      11-04-2019, 01:04 PM   #3523
thejeremyman9
Drives: 2015 BMW 335i
Stage 2+ do 17 psi
Was that the stage 2 E85? or stage 1? The E85 will run less boost but probably more timing.
Stage 2+ will probably be the highest power. As mentioned below pick the highest octane for your fuel or use a ethanol mix map (since it seems you have access to E85).
      11-04-2019, 04:22 PM   #3524
AmuroRay
Drives: M235i
Iíll keep saying it. The stock maps are ok - a custom tune in worlds better.
      11-04-2019, 06:34 PM   #3525
Jnat
DisplacementReplacement
Jnat's Avatar
Drives: 2015 M235XI
Originally Posted by AmuroRay View Post
I’ll keep saying it. The stock maps are ok - a custom tune in worlds better.
You're correct but they're much better then many other OTS maps from other manufacturers, from what I've used in the past.
2015 M235XI - MHD E20 - XHP STG 2 ***
      11-04-2019, 07:08 PM   #3526
torkles
Drives: 2013 335i MSport 6mt
any word on the ios version of the mhd app? i assume that would work using the wifi adapter to load the tune and you wouldn't need a cable or android/laptop to load the tune or unlock the dme?
2013 335i M-Sport 6MT, MPE
2006 330i 6MT, Sport Package - sold
      11-04-2019, 09:59 PM   #3527
blissdev
Drives: 2013 335xi M-Sport
Is anyone using an OTS map with a Pure Stage 1 turbo with FBO? Curious what your experience has been like.
      11-05-2019, 05:39 PM   #3528
AmuroRay
Drives: M235i
MHD maps are not what I would consider good on the EWG N55.
      11-05-2019, 10:01 PM   #3529
ChrisFulton
Drives: m235i
Why? Extremely happy with mine.
      11-06-2019, 02:31 AM   #3530
harkes
harkes's Avatar
China
709
Drives: M135i, NSX and AE86
Post some logs. Hard shifts, throttle too sensitive, surging power on steady throttle, other drivability issues? Whether it is a good map for WOT can be read from a log.
M135i PWG, MHD, Pure Stage2, Torqbyte CM5-LT, xHP
(A Dane in China)
      11-06-2019, 08:43 AM   #3531
AmuroRay
Drives: M235i
I have a custom map, so what I post isnít going to represent what the OTS maps can do.
The standard tunes are less powerful than their BM3 counterparts, producing 350ish whp at best, and the E tunes arenít much better. I just think they are incredibly weak - but a good stepping stone if you want to go to a custom tune.
      11-07-2019, 05:24 PM   #3532
jaypayne05
Drives: 435i Gran Coupe M Package
I have a custom map, so what I post isn’t going to represent what the OTS maps can do.
The standard tunes are less powerful than their BM3 counterparts, producing 350ish whp at best, and the E tunes aren’t much better. I just think they are incredibly weak - but a good stepping stone if you want to go to a custom tune.
Who did your custom tune
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
      11-08-2019, 01:58 PM   #3533
Phyrexia
Resident Pedant
Drives: '15 335i 8AT
I ran a 12.218 @ 114.94 on MHD Stage 2+. I haven't seen anybody with BM3 trapping higher than that. What kind of times and traps are BM3 folks running?
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+
      11-08-2019, 03:06 PM   #3534
AmuroRay
Drives: M235i
Pump gas only?
No idea, but there is a BM3 group on FB, and I think you can compare times on Dragy.
I will say a guy I went to the track with a M235i - FBO, JB4 and some race gas did 12.2 @ 113 as well.
FBO - Stage FP Custom tune with MHD.
Phyrexia456.50
      11-08-2019, 03:07 PM   #3535
AmuroRay
Drives: M235i
Stage FP - 18PSI tapering to 16 at redline.
      11-08-2019, 04:53 PM   #3536
f32_027
Driver
f32_027's Avatar
Drives: 435i
Pump gas only?
Despite the almost identical weight, the M235i seem to run quicker than their equally modded f30/f32 counterparts.
There is a thread about this.
      11-09-2019, 10:28 AM   #3537
Phyrexia
Resident Pedant
Pump gas only?
Yah 93 octane. Thanks for the heads up. I'm not really interested in moving to BM3. I'm exceptionally happy with MHD in terms of both driveability and power. But more data points are always interesting.
      11-09-2019, 02:27 PM   #3538
bqik
Drives: 435i
I am new to MHD and have 1 easy question
I will go directly to stage 2 but if I need to revert and go to stock map, the stock map will be my original stock map? ( mppk ) , a generic mppk or a mhd map with same adjustments as the stock mppk?
thanks.
      11-09-2019, 02:29 PM   #3539
chaungo
=D
chaungo's Avatar
Drives: 13' 335ix
There was a guy who ran the 93 OTS map with BM3 with his M235xi that did 12.0 @ 117mph with the timeslip.
2013 335i xDrive
Bootmod3, Pure Stage 2, Pure Inlet, GFB DV+, AFE Pro Dry S Drop-in Filter, ER CP/TIC CP, ER Catless DP, ATM FMIC, Borla ATAK, Dinan Springs, Dinan Shockware, XHP ZF8AT Stage 3, xDelete
      11-09-2019, 05:50 PM   #3540
Phyrexia
Resident Pedant
Pump gas only?
Buncha BS on the BM3 FB group. Oh well
      11-09-2019, 06:21 PM   #3541
AmuroRay
Drives: M235i
I have MHD. Iím just telling you and anyone else who will listen, a custom map on MHD will do more than a Custom on a BM3 car - I would recommend it it both.
Phyrexia456.50
      11-19-2019, 04:05 PM   #3542
FastF30
FastF30's Avatar
288
I haven't logged my car in about a year... updated the maps ... log is ots Stage 2+ 95octane... There is 50 more Torque act. clutch nm's than before!... very very happy... ... this is with a stock Cat... still have to put my fabspeed on...
https://datazap.me/u/fastf30/log-157...30-31-32-33-34
P.s. wish MHD would increase top-end a little still... at least for the American market...
P.s.s. The IAT's were the same as my last log so this is apples to apples comparison...
Here is my old one...
https://datazap.me/u/fastf30/log-154...0&data=4-17-27
Much more linear
flash, mhd, tune
