09-18-2017, 01:08 PM | #45 |
Rep 2,029
As if by magic, I appear
Certainly no expert but can give you my experience of the RaceChip XLR throttle tuner. I fitted it just over a week ago having purchased direct from RaceChip. I did a bit of research on the subject of tuning FBW throttles and thought it would be worth giving it a go. RaceChip do a 30 day money back so even if it was pants, nothing ventured, nothing gained etc. How they work? As JLR has mentioned, the module adjusts the amplitude of the signal at a given setting. For example, if you press the accelerator 1cm, the signal may normally send out a value of 10 (potatoes, apples etc), at 2cm it sends 20 potatoes etc etc. With the pedal box, that value will be 15 at 1 cm, 30 at 2 cm. It not only changes the signal strength but also appears to be a rate change amplifier too. I.e the speed rate change is also increased. Why you may ask? Some say pedal boxes are Snake Oil and dont really do anything, some say 'just press the pedal more/quicker'. All I can say is; they really do work. Sure, they dont give you any more power whatsoever but the response in that early stage of the throttle is very quick and responsive now. The RaceChip XLR has seven settings. Eco+, Eco, Normal, Sport, Sport+, Race and Race+. Eco+ and Eco are akin to having a small damp sponge under your foot so I haven't used those settings. Normal basically reverts the throttle to the OEM setting of the car. Sport and Sport+ make it nice and crisp. Race and Race+ make the throttle telepathic and sharper than a very sharp razor blade. To give you a comparison. When you select Sport in the usual way on the car, the throttle response sharpens, the gearbox sharpens its gearchange mode and the steering stiffens. All the box does is gives you independent control over that throttle sharpness in any vehicle mode. Comfort mode makes the car nice and comfy but throttle response is normal. Flicking the controller on XLR to Sport or Sport+ means you have the comfort but the quickness of throttle. The XLR box is simple to fit. Unscrew the throttle pedal (one torx bolt), unclip it from its rear housing. Disconnect the pedal connector. Fit the XLR connector in to the throttle pedal and in to the disconnected harness. On the XLR box, fit the rotary remote controller and fit that somewhere to hand. Refit pedal and et voila. I got the XLR connected which has the ability to change modes via an app from the phone but I wouldnt bother with that as its easier to just spin the rotary controller. Highly recommend. In Sport+, manual gearshift and XLR set to Race+, my Stage 1 435d is fucking bonkers now! Diagram to show how the signal is modified from demand on pedal. |
JLR19691882.00 Danny Fireblade748.00 |
09-18-2017, 02:08 PM | #46 | |
Village idiot
748
Rep 1,237
We know you're very brainy, as you fly heliwopters, no need to really rub it in. Now go and laser some cows eh PS. thanks |
Darth Helmut1780.00 JLR19691882.00 |
09-18-2017, 02:51 PM | #47 |
Rep 2,029
Danny Fireblade , just for you;
Loud pedal better cos of wiggly amp stuff, yum yum, need food, burp. |
09-18-2017, 02:56 PM | #48 |
Village idiot
748
Rep 1,237
Darth Helmut1780.00 |
09-18-2017, 03:25 PM | #49 |
Rep 7,000
09-21-2017, 03:25 AM | #51 |
Rep 709
Rather than reply from the classifieds thread.
Early days, it's only been fitted for less than a day so not a great deal to report. Fitting was straight forward and took less than an hour, most of that was reading the instructions and figuring out where to put the box,which is behind the headlight and below the coolant expansion tank. It was set up on program 2 when I install it and took it for a short spin. Everything was running well and a noticeable difference on pickup. Pulled over and increased it to +1 which is where it's been at since. Again a bit more pickup but smoother too. I'm still trying to calibrate my right foot to the increase as pulling out from junctions on the damp roads has had a bit slipping and the traction control coming on without being lead footed which it wouldn't do before. I've reset the MPG to see how it translates to the economy too. Again early days but usual commute is showing around 10-12% improvement but will see how it pans out over a tank full for more realistic values. I think Ashley (SquireTolley) who I bought it from summed it nicely in that comfort mode has now become sport. Over time I will see what Sport and Sport+ have become. For the price and ease of fitting it's a no brainer. Only downsides is the auto gearbox seems a little confused at time and jumping down and up again with a little increase in the throttle. A gearbox reset may cure this which I'll try later to see how that goes. This is on an F30 320D 184ps MSport for reference. Last edited by Craig-SM; 09-21-2017 at 03:40 AM.. Reason: fat fingers |
Squiretolley48.50 JLR19691882.00 |
09-21-2017, 05:33 AM | #52 | |
Rep 7,000
Just remember that the OBC will not work correctly now so you need to brim the tank and run it through and measure that way. I also put Millers EcoMax in the tank now to keep everything clean and smooth. |
06-13-2018, 11:14 PM | #54 |
Rep 2
Hi all. I've just bought a 430d and one of these DTUK boxes but have yet to install it. I'm just wondering if the sports dials of BHP and Torque on the OBC give a true reading? I'd just like to know how best to measure the actual effects of the tuning box changes. I have used a torque app on my phone previously and an OBD2 connector but don't feel that works accurately. Really hoping the OBC still works.
I'd also like to thank the forum member for the discount code. I checked the forum just before I clicked buy and found the code. £30 saved. Result. Thanks |
06-14-2018, 02:32 AM | #55 | |
Rep 1,446
Only way to measure effect of the tuning box is to get to a dyno and do some before and after runs, but if you search on here you'll see others have done just that. Expect about 30bhp increase / 100nm of torque. These boxes do make good torque but I've yet to see one achieve advertised power.
Gone: G05 X5 40d M Sport, F15 X5 30d M Sport, F30 330d xDrive, F21 M135i, E87 123d
06-26-2018, 07:02 AM | #56 | |
Rep 3
Hi, I’ve just purchased a 320xdrive F31 and reading through the thread, I’d be interested to see how the DTUK box is and if it worth getting one fitted. Thanks |
06-26-2018, 08:43 AM | #57 | ||
Rep 4,932
06-27-2018, 01:05 PM | #59 | ||
Rep 7,484
DTUK and Blue Spark are the main players for a box. Personally, I would say get a decent remap. |
06-27-2018, 01:56 PM | #60 |
Rep 3
Thanks Surg_Capt_R, the issue is I had a 330d and miss a bit of the noise and fun, I just wondered how much it improved it.
I couldn’t find a decent replacement 330d so went with 320. I still have an option of returning the 320 and looking for a 330 or 335; they would just have a lot less kit ie sat nav, heated seats, tow bar etc It would also be older or more mileage. Last edited by Burt4; 06-27-2018 at 02:04 PM.. |
Soul_Glo13346.00 |
