06-11-2018, 11:40 AM | #1 |
Rep 585
Chassis error message help!!!
So I have just jumped in the car on fire up I got the chassis ewsrming error message pop up. What could this be ? I’d like to add I have adaptive suspension so I’m guessing if it’s suspension related it’s going to be expensive ?
Has anyone had this problem and where should I start with making sure I can cross off possible causes Thanks |
06-11-2018, 11:50 AM | #2 |
Supreme Being
1804
Rep 5,425
Bimmerlink or ISTA will give you the error code.
Some of these errors come from the fuel cap not being tight (believe it or not) and it's less likely to be an expensive damper, rather a sensor. Where in the world are you?
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
06-11-2018, 11:52 AM | #3 | |
Rep 585
I'm Hoping It's something as simple as a sensor etc how do I get the codes I don't have a code reader |
06-11-2018, 11:56 AM | #4 | ||
Supreme Being
1804
Rep 5,425
Someone on here should be able to help you out.... Anyone???
06-11-2018, 11:59 AM | #5 | |||
Rep 585
06-11-2018, 12:07 PM | #6 |
Supreme Being
1804
Rep 5,425
It's probably worth downloading Bimmerlink and picking up a WiFi dongle to check for yourself tbh
Vgate iCar 2 WiFi OBD OBD2/OBDII Scanner Scan Tools Interface Adapter Check Engine Lights Car Diagnostics Tool for iOS iPhone iPad, Android Auto Sleep https://www.amazon.co.uk/dp/B01JO9NR...=yo_pop_ma_swf
06-11-2018, 12:09 PM | #7 | |
Rep 585
06-11-2018, 12:18 PM | #8 |
Rep 548
I had that error last week!!
I've had the car (adaptive also) for 9 months and covered 17k miles … first time I'd seen it & was a day after its first official service (had done interim oil & filter change at 9k myself). Was peed off at the time, but it never came back again & have covered about 800 miles since (Touch wood!)
Current: 2017 F31 335d M Sport - Estoril Blue, ACS Sports Suspension (Springs & Dampers), Black Grill, HK Sound & some other bits'n'pieces
Gone: 2015 F31 320d M Sport Xdrive Auto |
06-11-2018, 12:20 PM | #9 | |
Rep 585
06-11-2018, 12:30 PM | #10 | ||
Supreme Being
1804
Rep 5,425
Not free or cheap - £20 ish - but worth having for sure.
06-11-2018, 12:40 PM | #11 | |
Rep 548
Mine has never reappeared though.
06-11-2018, 12:41 PM | #12 | |||
Rep 585
https://rover.ebay.com/rover/0/0/0?m...2F222734131123 Will that adaptor dongle work? |
06-11-2018, 01:18 PM | #14 |
Supreme Being
1804
Rep 5,425
Yes that adapter is the same (they come in different colours for some unknown reason) but the Amazon one is cheaper.
I think Bimmerlink is available for Android...?
06-11-2018, 01:22 PM | #15 | |
Rep 585
Hopefully isn't a damper or anything too costly car is out of warranty * |
06-11-2018, 01:34 PM | #16 |
Rep 1,800
MarkG_M3CP Bimmercode has always been for android. Bimmerlink is IOS only.
I'm giving Deep OBD a go. It's got 2.5gb of codes in its database so I'm hopeful. I'll nip out to the car in a bit and see what it says. It could be good for free. |
06-11-2018, 01:43 PM | #17 | |
Supreme Being
1804
Rep 5,425
I have the ISTA software on a PC for running more thorough error checks - it shows the ECU 'tree' and links to some of the test you can run. You can also clear the error log completely.
06-11-2018, 02:48 PM | #18 | |
Rep 548
Luckily mine is still under warranty, although I'm not looking forward to issues with the suspension if the error comes back. I will be interested to find out what the error was if you can get a fault code.
06-11-2018, 02:53 PM | #19 |
Rep 585
yehh seems to be i will see again in the morning im out of warranty so hoping its an easy fix
06-11-2018, 02:57 PM | #20 |
Rep 548
I'm keeping my fingers crossed for you!
06-11-2018, 02:59 PM | #21 |
Supreme Being
1804
Rep 5,425
I had a damper fail while IN warranty on my 335d...
I'm guessing you don't want to know the cost they wanted to charge me because of the ACS springs?
06-11-2018, 02:59 PM | #22 |
Rep 585
Cheers buddy my next option would be to do away with the adaptive set up and run coilovers if I can code the adaptive out
