07-20-2018, 06:11 PM | #1 |
BMW forever!
1380
Rep 2,417
BMW alignment question
I have got alignment done both at the dealership and by a BMW specialist.
When I compare the target spec from both the dealer and specialist, I see that they are quite different. The target spec is the one that is used as a reference guideline to meet for proper alignment. Can anyone here tell which spec is better (dealer or specialist)? My dealer says that they spend 3 hours to align, whereas the specialist only needed 1.5 hours. Also the alignment machine used by the specialist in top of the line 2017 model, whereas the one at the dealer is a different one and possibly not as new. I don't know if this makes any difference. Please see attached specs. Alignment done by BMW specialist (independent shop) in 2018: align_new.jpg Alignment done by BMW dealer in 2017: align_bmw_1.jpg align_bmw_1.jpg Thank you!
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i Last edited by buckybadger; 07-20-2018 at 06:21 PM.. |
07-20-2018, 06:21 PM | #2 |
Rep 397
I got mine done at the dealer for $142. Took about 2 hours. They just got it in spec for me based on the readout its close to 1 degree camber all four wheels if I remember correct.
The dealer follows manufac guidelines whereas the specialist probably does not. They both look ok, if you're rwd you'll probably find more value in aggressive alignment setups. If you value tire life most likely value conservative setups. Regardless it looks like you're at most at the outer limit on the specs, but within range. |
07-20-2018, 06:27 PM | #3 | |
BMW forever!
1380
Rep 2,417
2020 BMW X5
2019 BMW M2C 2014 BMW 335i 2009 BMW 328i |
07-20-2018, 06:30 PM | #4 | |
BMW forever!
1380
Rep 2,417
Thanks!
2020 BMW X5
07-20-2018, 06:34 PM | #5 |
Rep 397
The last set of photos is more aggressive than the first. I see you're rwd so that looks ok.
So you're current alignment (first photo) is slightly less aggressive than the last set of photos. The independent has you running slight less aggressive, not a whole lot difference. |
07-20-2018, 06:43 PM | #6 | |
BMW forever!
1380
Rep 2,417
2020 BMW X5
07-20-2018, 08:24 PM | #9 |
Rep 134
Drives: 2017 f32 440i coupe
Dealer tends to use the alignment which prolong tire life, but not as good on performance
07-20-2018, 08:26 PM | #10 |
BMW forever!
1380
Rep 2,417
Thanks, based on your comment dealer setup is not as aggressive, correct?
2020 BMW X5
07-20-2018, 09:53 PM | #11 | |
Rep 1,503
The downside of negative camber is that the top of the wheel is leaning in towards the car’s body. That means when you’re going straight you’re riding more heavily on the inside edge of the tire, which gives you uneven tire wear. The “conservative” setup keeps the tire flatter in a straight line for more even tire wear, but then you have less contact patch during heavy cornering. There’s also some considerations with toe, but I don’t know much about that aspect. |
Tribalpinoy91193.00 superdrive32022.50 |
07-20-2018, 10:03 PM | #12 | ||
BMW forever!
1380
Rep 2,417
2020 BMW X5
07-20-2018, 10:07 PM | #13 | ||
Rep 397
