06-07-2023, 10:40 PM | #1 |
Rep 928
trouble code 10BA49
Where is my intake air temp sensor located? Is it my maf sensor? I already tried cleaning my maf sensor but code has returned? Anyone deal with this code and what was the fix thank you?
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
06-07-2023, 10:45 PM | #2 |
Rep 928
Heres a pic of the code with description.
06-29-2023, 07:03 AM | #5 |
Rep 928
Yes I cleaned the maf sensor with the special spray maf sensor cleaner. Cel still came on afterwards?
06-30-2023, 06:35 PM | #6 |
Rep 1,579
Is your car stock or modded?
May be an air leak going to the turbo.
06-30-2023, 07:01 PM | #7 |
Rep 928
Factory except for vader solutions turbo inlet mod and a vrsf boost pipe, and a Turbo dmart dv valve. Im hearing my tmap sensor may have oil on it since the aftermarket boost pipes mount the tmap sensor in a way to get dirty way more than factory. 90 deg or 180deg from factory location. Thanks for your help or anyones for that matter.
06-30-2023, 08:38 PM | #8 | |
Rep 1,579
https://www.2addicts.com/forums/show....php?t=1557568
07-01-2023, 04:56 PM | #9 |
Rep 928
Thanks brother for the input. It maybe my tmap sensor maybe some oil on it? I have a vsrf charge pipe and im hearing most of the aftermarket charge pipes have the tmap sensor mounted in a susceptible way for oil contamination unlike the plastic factory charge pipe.
