BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Stopping the blue Brembo's from squealing. Possible?
European Auto Source
      06-20-2018, 02:04 PM   #23
willjames
willjames's Avatar
Drives: F31 330d M Sport Touring Auto
Mine sounds like a 20 yr old Vauxhall. Fookin embarrassing rolling up to the lights!
      06-20-2018, 03:03 PM   #24
muffking
Regular user
muffking's Avatar
Drives: F31 330D M-Sport Auto
Do you have a plan? I guess that's what I need before I start aimlessly throwing money at disc and pads.
      06-20-2018, 03:29 PM   #25
teaston
teaston's Avatar
Drives: 335d M Sport Plus
Take the pads out, clean them and inside the calipers & the guide pins with brake cleaner & mini wire brushes, then use ceratec brake grease on all surfaces that come into contact with others.
If the squealing comes back then use some of this:
Current: LCI F30 335d M Sport Plus in BSM/CR
      06-20-2018, 03:47 PM   #26
muffking
Regular user
muffking's Avatar
Looks a bit hard to get hold of that stuff. I have Ceratec on the back omy pads at the moment, although I have shims stuck to the back of them so I can't just the CRC stuff yet.
      06-20-2018, 03:53 PM   #27
teaston
teaston's Avatar
Yes it appears BDQ is hard to find now! Used to be easy to get on ebay for about £7 delivered!
      06-20-2018, 04:41 PM   #28
willjames
willjames's Avatar
Mines due a service in the next two months and brake service is due also. Gonna mention it at the stealers, see what happens.
      06-20-2018, 04:50 PM   #29
A15X
Drives: BMW 430d M sport Convertible
I had the pads replaced on mine around 5k ago due to squeaky brakes and hasnít returned yet! Apparently itís a different pad to what was installed at the factory...
      06-20-2018, 05:08 PM   #30
muffking
Regular user
muffking's Avatar
Any idea what pads they fitted?
      06-20-2018, 05:37 PM   #31
A15X
They are a revised bmw oem pad, they did attempt to chamfer the original pads but didnít cure it but the new pads did...
      06-22-2018, 02:27 AM   #32
djcowlin
djcowlin's Avatar
Drives: F31 340i M Sport
I mention this problem to the dealer every time I have my summer wheels swapped to winters and vice versa. Each time they clean the brakes thoroughly, and the squeak goes away (for a time).
2016 F31 340i | EB II | Black Dakota/blue stitching | M Sport Plus | Adaptive suspension | Icon LED lights | Interior comfort pack | Pro Plus Media | Electric seats
2016 High Up! 75PS | Red
Gone: 2013 F31 330d Luxury | MG
Gone: 2014 Golf GT 2.0 TDI | Black
      06-22-2018, 12:20 PM   #33
fat dog
fat dog's Avatar
England
Drives: 435d Gran Coupe
A15X is spot on. BMW have changed the pads for the blue brakes in an attempt to cure the squealing. The new pads are apparently slightly smaller. Local dealer explained this when I had my pads changed a couple of weeks ago. The good news is that they havenít squealed once since they were changed. The bad news is that there is now a slight clunk when braking during low speed manoeuvres. One step forward, two steps back...
      06-22-2018, 12:42 PM   #34
Pobsey
Drives: 2017 F31 330d
Mine are the factory fit from Oct 17 so unsure if they are the revised ones, but they squeak and clunk 😳
      06-22-2018, 02:30 PM   #35
jenshb
Drives: 2016 340i MSport
I had new pads fitted that were supposed to cure the squealing. They still do, but not as much as the old ones.
      06-22-2018, 02:42 PM   #36
Vinboyblue
Drives: BMW 335
Apparently its always recommended to replace the rotors and pads at the same time to avoid squeaking. After hitting 40k kms recently I have a slight squeak once in a while.
      06-22-2018, 03:43 PM   #37
teaston
teaston's Avatar
Both my F30ís have squealed from new!
      06-22-2018, 03:48 PM   #38
TiredGeek
First time BMW owner
TiredGeek's Avatar
Drives: 335dx F31 Shadow in EB
I think that might be a recommendation from someone with a vested interest in parting you from your money !
Ear defenders are very cheap, certainly much cheaper than a new set of pads and discs every 30k.....
      06-22-2018, 04:08 PM   #39
teaston
teaston's Avatar
Or turning up the HK!
